Old Jun 30, 2010, 05:43 PM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
You have to hold it together?
It should be a screw-in attatchment, remember one connection is for a QD application (wings) and the other is the fill valve. Each pair comes tightened together and you have to unscrew them from each other.
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Jun 30, 2010, 07:38 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i have no quick release ...just a brass needle that goes into the fill valve ...and you have to hold it ...there are no threads...these are Maps
AIR SALLY is offline Find More Posts by AIR SALLY
Old Jun 30, 2010, 08:49 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Roger these will make life a lot better
hole digger is offline Find More Posts by hole digger
Old Jun 30, 2010, 10:20 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah but the wing dont come off so thats not the issue right now ...i could'nt air in the tank cause the fill valve has to be held on .....i will try my trusty tiny valve from them itty bitty etracts that were'nt any good ..the fill valve was the best part on that system
Old Jul 01, 2010, 02:19 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
ok i switched the fill valve ....it takes more than 100 psi to get the nose gear up ...i guess the small dia clyinder require high pressures to lift the weight of the strut hope it can lift 3 ...or else i 'll have to do the ole C/N roll it over and retract the gear there are no threads on this brass piece it just goes in and you have to hold it .....wonder if they forgot to thread it ??
Old Jul 01, 2010, 02:25 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
You should have gotten the SAPACS. they will do 8-10 cycles at 100 psi.
That's with the scale struts attached. Nose gear comes up at 50-60 PSI min. And no messin' with the fill valve.. Just screw it on. Fill. Screw it off.
Where did you get those retracts your using?
That fitting you have is good if you mount the fill valve in the fuse, and fill using a compressor.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jul 01, 2010, 02:36 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah yeah i know ...next time i'll listen ...if these wont work i'll get some
Old Jul 01, 2010, 10:28 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
ok i got it to work better ...i had about 2 ft of hose going to the NG after i cut it down to size it works down to 80psi . the manual said pressures of 70 to 110 are needed . so can any one out there tell me if your fill vavle is threaded? i may need to talk to MAP
Old Jul 01, 2010, 10:49 AM
hole digger
Joined Aug 2002
The fill valve that goes in the plane is threaded with a nut for mounting. The one to the pump is a pressure fit.
Old Jul 01, 2010, 12:04 PM
efflux RC's Avatar
Joined Aug 2009
Having to hold the the fill valve nozzle in the the fill valve is the intention with that design Rodger. but is easiest to accomplish if you either mount the valve in the jet, have a compressor...or have 3 hands.
The screw together valves are easier if you are using a hand pump. (only two hands required)
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jul 01, 2010, 12:07 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
but no threads on the brass needle that goes into the valve mounted to the plane ....you have to hold it in with hand pressure.
here the production Ducts .the added bell mouth makes it easier for the customer to fit the ducts .
Old Jul 01, 2010, 10:34 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i got the fan mounted and a tail pipe made ,extened the batt wire to the front for power .the esc will sit on the center duct .i have a ole in it with screen ove it so some air will be pulled over it from the intake. ducting ready to go in then thee is one former to go in the fuse with a brace for the spar then bond the wings on.
Old Jul 01, 2010, 11:04 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Should be ready to fly in an hour or 2 then ??
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jul 01, 2010, 11:08 PM
Denver, CO
Joined Jul 2006
PLEASE tell me you didn't use the Wemo pipe... I assume that when you say you made a tail pipe, you made one out of mylar or something...
Old Jul 01, 2010, 11:46 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yeah the long wemo was 2" short .....i used one in my Draken with a mylar extesion on it ...that one worked ok ...they sure are purtty.
For Sale Air Sally T45 (v1) F/G ducts $48.00 jzuniga Aircraft - Electric - Jets (FS/W) 0 Jan 01, 2010 01:36 PM
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 05:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 02:21 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold E-flite BAE Hawk and Air Sally Ducts bfischer Aircraft - Electric - Jets (FS/W) 3 Jul 25, 2009 03:39 PM
