Old Jun 28, 2010, 01:06 AM
tailslide5_0 is offline
Find More Posts by tailslide5_0
Hangar queen hoarder
tailslide5_0's Avatar
Denver, CO
Joined Jul 2006
Don't lose that cable, you won't find anything else like it! It's more flexible than any other cable out there, which is perfect for fussy little retracts like these. Kevlar thread may be a good alternative if you have to...
And if you have to redo the cables or anything, little brass tubes work great for replacing the original crimp tubes...
tailslide5_0 is offline Find More Posts by tailslide5_0
Old Jun 28, 2010, 01:09 AM
Denver, CO
Joined Jul 2006
If you have a big enough nose door, you could put the steer servo here
Old Jun 28, 2010, 01:51 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Great mines do think alike that is where i was looking ,and it will be setting at a 45 degree angle so i can get a ball driver in there. the nose gear dor in narrow .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 28, 2010, 02:05 AM
Denver, CO
Joined Jul 2006
What I did with both of my Sapac retracts was make the outboard cable permanent, and made the inboard one adjustable... If you are running a rudder too, any changes you make to tension that will tweak the nose wheel can be corrected with radio trim and re adjusting the rudder connector...
Old Jun 28, 2010, 02:31 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
no rudder at this time ,just going to fly it stock but with retracts and custom ducting,Het 6904 and a BI 3600 60amp esc and XPS 3200 and or 5000 4s batts.800 to 1000 watts depending on batt
Old Jun 28, 2010, 04:41 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I am looking forward to this one. I reckon it is light enough and slippery enough, especially with those little intakes to do 140 mph plus with 1000 watts and gear up. And with the stiffening of the fuse with your ducts and wing spar mods it would not be a hard model to crank the power up to 2000 watts or more too. j
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jun 28, 2010, 10:55 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
well i dont think 140 with the stock wing ....it has some under camber ...but with the scale wing it going to rip
Old Jun 28, 2010, 11:02 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
By scale wing you mean replacement not just modified, with different airfoil and planview? I haven't really had a good look at mine. After taking the photo of the damaged wing I boxed it up. J
Old Jun 28, 2010, 02:01 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
the stock wing looks like it would be perfect for a 90mm size plane ,the scale wing will be a complete different wing ,we'll test a foam core version and if it works i'll make a mold.
Old Jun 29, 2010, 11:42 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
ok i got the nose wheel steering done up just like T.S showed and i epoxied the whole thing into the fuse ...i did add a strip of 1" wide fiberglass at the rear bulkhead just to strengh'n the area.....cause i know how i land . so im ready for some retract hoses and valve then bond the wings and tail install the power system ...shooting for maybe mon. as i have the day off.
Old Jun 30, 2010, 02:44 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Getting close.
Are you going to maiden it up there, or down here?
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jun 30, 2010, 02:54 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i think up here. i just touched up the duct plugs that i made some changes on so sand them tomarrow and maybe lay up a production set .im am getting close ....just going to madien without paint ,and only gear leg doors .still this will prove to us what we have here .not sure how i will affix the wing due to the fact they need to come off for the scale wing after we ring the stock ones out ,i think it will fly great with the big wing and it wil be a hot bugger on the scale wing
Old Jun 30, 2010, 03:23 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
heres the nose gear set up ...tight fit i'll have to drill a small hole to tighten/adj the one side. i used the stock servo holder just modded it to fit the 9 gram Turngy servo ,used fishing leader with a plastic coating on it.had to glue the cables in th eholes on the gear because they would fold under and not allow the retract to lock down
Old Jun 30, 2010, 03:37 AM
efflux RC's Avatar
Joined Aug 2009
Looks sweet Rodger. I'll have to get some of that fishing leader.
Site Sponsor
Old Jun 30, 2010, 04:31 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i rigged up the retact valve and tank and fill valve ....not impressed with the fill valve ...you have to hold it in and pump...so it will take 2 people to fill it up ...plus the air would'nt even raise the gear into the plane. not real happy with this ...and that was just the nose gear ...they actually go down faster than they go up.
For Sale Air Sally T45 (v1) F/G ducts $48.00 jzuniga Aircraft - Electric - Jets (FS/W) 0 Jan 01, 2010 01:36 PM
Sold NIB Sapac T-45 V1 Composit with Air Sally ducts mickydee Aircraft - Electric - Jets (FS/W) 7 Dec 11, 2009 05:57 PM
Sold Phase 3 F-16 w/ Air Sally fiberglass NIB mflander Aircraft - Electric - Jets (FS/W) 6 Nov 27, 2009 02:21 PM
Wanted Air Sally Ducts for BAe Hawk jzuniga Aircraft - Electric - Jets (FS/W) 0 Oct 23, 2009 08:05 PM
Sold E-flite BAE Hawk and Air Sally Ducts bfischer Aircraft - Electric - Jets (FS/W) 3 Jul 25, 2009 03:39 PM
