Old Jul 10, 2010, 11:08 PM
heliboy88 is offline
Find More Posts by heliboy88
HK--Phils.
Joined Dec 2006
Originally Posted by jetinteriorguy View Post
I find it much more fun to fly an airplane that performs better, if that means a lighter battery and shorter flight times, just buy more batteries. These smaller batteries are generally cheap if you shop around, and if you are flying hard the shorter flight times give you a small rest in between flights which helps with fatigue and helps avoid doing dumb things and destroying your plane. Lighter flies better and slower.
jet, thanks a lot for the headsup, yes i'll be keeping the plane as light as possible, i don't need too long flight time per pack anyway.
heliboy88 is offline Find More Posts by heliboy88
Old Jul 11, 2010, 05:44 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
@boxhead - I picked up one of the Turnigy 2204-14T motors like you have but am stuck with trying to figure out how to get a GWS EP8040 prop mounted on the bloody thing...
Can you throw me a clue and maybe post a detail photo of the new motor on your plane?
Cheers.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Jul 13, 2010, 07:19 AM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Dirt, mate I use an 8043 on mine. Fits and flys well.
Bx
Boxhead is offline Find More Posts by Boxhead
Old Jul 13, 2010, 05:40 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Cheers.
I have use the Suppo version of this motor on several planes, it's a great little motor, very powerful and durable. I drilled out the prop so I could insert a 10x32 rivnut, then I drilled out the inside of the rivnut to the dia. of the motor prop mount. It has been a while since I did this so I don't recall the size drill bits I used to accomplish this. I am sure you can figure that out, if not just pm me and I will go check this for you and let you know.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jul 14, 2010, 04:11 AM
josh109 is offline
Find More Posts by josh109
Australia
My 3d-hawk arrived yesterday bought on the 3-7-10 arrived 13-7-10 that was with the cheapest shipping very happy with that.building it at the moment when unpacking i noticed that both my kits came with 7x3.5 unlike boxheads hopefully finish it tonight.
josh109 is offline Find More Posts by josh109
Old Jul 14, 2010, 04:54 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hi Josh. My kit was supplied with an 8040 Prop and the instructions said a 7035 is supplied with the Kit. Mine might have been kitted on a friday afternoon knock-off time . Had a 7035 so tried both and liked the 8040 better on the C-20 motor. Individual taste I suppose. Good Luck with your Hawk.
Bx
Old Jul 14, 2010, 05:16 PM
Joined Mar 2010
I think the kits are thrown together in a sloppy rush. Mine showed up with yellow heat shrink that would barely slip over the pushrods and no way I was getting the z-bends on at the same time. The foam also varied from 6.2-8.4mm (even on single pieces) which made assembly a bit fussy.
Mine came with the 7x3.5 prop, but that self-destructed on my first power-off landing (not rough, it slid) with the stock motor.
Thanks for the motor/prop tips guy. I'm looking forward to getting it back up in the air, harriers and controls felt pretty good on the first flight.
Old Jul 14, 2010, 05:25 PM
Joined Mar 2010
I did drill out the DD-8040 and I'm thinking to fill it with hot glue or acrylic glue and then jam it onto the motor boss/shaft to set the pocket. If that doesn't cut it I'll see about making a better insert.
Old Jul 15, 2010, 06:49 AM
josh109 is offline
Australia
I know what you mean about the heatshrink and zbends after about 30 mins of fiddling with them and trying to get them set up right i gave up and bought some control connectors and longer bits of carbon rod
Old Jul 19, 2010, 08:11 PM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
Mine arived last week and I have put together, but I have to say that as of now I'm not impressed with this bird. But I will still try a few more things before it gets stripped.
oldfish is offline Find More Posts by oldfish
Old Jul 19, 2010, 10:45 PM
micman75 is offline
Find More Posts by micman75
Joined Aug 2009
what's wrong with yours?
micman75 is offline Find More Posts by micman75
Old Jul 20, 2010, 07:47 PM
oldfish is offline
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
I'm hoping that I just don't have it trimed just right , also seems short on power, I'm going to play with it more, before stripping it for the Electronics. I have an UZI X coming and if it flies like its big brother the UZI XXL whitch I have then this plane will just go away. I have never flown anything that flies like it.
Old Jul 20, 2010, 10:40 PM
micman75 is offline
Joined Aug 2009
got no issues with mine. enough power for me. pretty good for the price.
Old Jul 21, 2010, 02:23 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Sorry to hear that Oldfish. I'm the same as Micman. Still Happy with mine. Is their anything we could help you with.
Bx
Old Jul 21, 2010, 03:48 PM
retiredbri is offline
Find More Posts by retiredbri
United Kingdom, England, Ludlow
Joined May 2008
Need experienced guide please
Hi I'm new to the 3-D flying and do not have any experienced people around to help me with the first flight so need to get as good a flyer first time. This thread is great – thanks for the information .
Question to Boxhead
Do you have the dimensions and locations of the ESC, the Rx and battery for your plane please so I can copy them to get a good start out with your “known flyer”
I've seen the pictures that you included on this site (post 1) and also the ones that are included on the HobbyKing for this plane and notice that the servos on the HobbyKing picture http://www.hobbycity.com/hobbyking/s...dProduct=11339 are placed behind the trailing edge of the wing whereas on Boxheads pictures, they are underneath the wing.
I've read in the articles that there isn't a defined centre of gravity position but would believe that the 70 mm from the leading-edge would be achieved if the servos were placed behind the wing. (micman75 Post 31) whereas 56-58mm would be achieved ( Boxhead Post 30) with the servos under the wing
Do you have any comments or observations?
Also on the HobbyKing site it shows that the aileron horns are not placed close to the hinge but are set back. Again does anyone have any data about Servo travel and positioning of all the horns to achieve 3-D flight?
Looking forward to your responses.
Retiredbri
PS: is the tape for the aileron/elevator and rudder hinges applied to both surfaces?
retiredbri is offline Find More Posts by retiredbri
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 340 Dec 28, 2015 07:49 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
