Old Jun 30, 2010, 08:00 AM
micman75 is offline
Find More Posts by micman75
Joined Aug 2009
I've toyed around with the CG and find that 70mm is right for me. able to fly inverted without any down elevator. harriers and hovers are easier too. I tried the ca trick but my slop still seems to be there. might try again with a fresh tube of ca. I like this plane!
micman75 is offline Find More Posts by micman75
Old Jun 30, 2010, 06:00 PM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Good stuff Micman. Glad your got it where you want it. Give it a try again and see how it goes with the CA.
Bx
Boxhead is offline Find More Posts by Boxhead
Old Jul 04, 2010, 05:07 PM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
They are back in stock and I have mine on order along with 5 bats will add more when it arives
oldfish is offline Find More Posts by oldfish
Old Jul 05, 2010, 12:01 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hi 'Old Fish ", luv the name .... Looking forward to your review on the Hawk when you get it
Bx.
Old Jul 05, 2010, 05:10 AM
heliboy88 is offline
Find More Posts by heliboy88
HK--Phils.
Joined Dec 2006
Hey Boxhead,
Thanks a ton for the great review, i'm looking at this plane now, just a few Qs, how slow do you think it can fly, i want something slow so i can fly(hover) it in my small front yard. Or any way to make it fly slower? Changing prop and what else? Anyone done that? Please share your thoughts and probably with some indoor or tight area flying vids will be great.
Thanks a lot for any tip i can get.
heliboy88 is offline Find More Posts by heliboy88
Old Jul 05, 2010, 07:26 AM
josh109 is offline
Find More Posts by josh109
Australia
Hey guys I have also just bought this plane I decided to go with these servos http://www.hobbycity.com/hobbyking/s...idProduct=9549 for ailerons and http://www.hobbycity.com/hobbyking/s...idProduct=7475 for the rest because the hxt servos were out of stock what do you think? This is my first 3d plane and foamy can't wait to try some 3d moves what glue do you recommend for construction? Thanks
josh109 is offline Find More Posts by josh109
Old Jul 05, 2010, 08:02 AM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Good servo choice. Don't wait for HTX there is no such different in this size of bird. You cαn use hot silicon glue or epoxy. Don't use big amounts of glue you're adding unecessary weight.
kstmark is offline Find More Posts by kstmark
Old Jul 05, 2010, 06:38 PM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Kstmark, thanks for chiming in. Josh, Ks is on the money . I used a bit of hot glue and Foam Safe CA on mine. As Ks said keep the glue to the minimum.
Heliboy, the Hawk is a good plane and will do 3D stuff, but it all depends on your flying skills. Your the only one that can guage if it will fly in the area you have etc with your flying skills. As you can see by my Video's I need a bit of room to move. You might leave my flying for dead and can fly it in a really tight area. As for flying slower that's something you will have to play with. Have a look at the motor spec's. It might shed some light on what you can do with the moter.
Bx
Old Jul 05, 2010, 07:13 PM
micman75 is offline
Joined Aug 2009
agreed Boxhead. I wouldn't be able to hover this in my frontyard but I can imagine an experienced 3D pilot could. You'll need to keep it as light as possible for indoor use
Old Jul 06, 2010, 05:35 AM
HK--Phils.
Joined Dec 2006
Box and mic,
Thanks a lot for the heads up, i'm not really a good 3d pilot yet, that's why i want it to fly as slow as it can, if i'm going for this plane, maybe i'll try some motor prop combo, or even put a speed break on it.
Old Jul 06, 2010, 06:07 AM
micman75 is offline
Joined Aug 2009
not sure if a speed break will be effective. Might just end up stalling the plane. what combo were you thinking of using?
Old Jul 06, 2010, 06:26 AM
HK--Phils.
Joined Dec 2006
i'm not sure about the combo yet, still thinking about it, any suggestion?
Old Jul 06, 2010, 06:51 AM
micman75 is offline
Joined Aug 2009
perhaps if you kept with the stock motor /esc, but used a smaller batt, like a 400mah? might be an easier way to cut the weight down?
Old Jul 07, 2010, 07:39 AM
HK--Phils.
Joined Dec 2006
Yes, maybe you're right, just don't know what the flight times will be. Or a smaller pitch prop too?
Old Jul 10, 2010, 11:40 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
I find it much more fun to fly an airplane that performs better, if that means a lighter battery and shorter flight times, just buy more batteries. These smaller batteries are generally cheap if you shop around, and if you are flying hard the shorter flight times give you a small rest in between flights which helps with fatigue and helps avoid doing dumb things and destroying your plane. Lighter flies better and slower.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 340 Dec 28, 2015 07:49 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
