Old Oct 27, 2010, 05:22 PM
United Kingdom, England, Saffron Walden
Joined May 2008
Originally Posted by georgerm View Post
cureentyl i have a gws slowstick and i can fly that very well. i was thinking of modding it for ailerons but thought this would just be cheaper and easier.
Even if you could get the Hawk with batteries (some suppliers include them, some don't) you still need to buy the receiver. If the GWS slowstick has a 5 (or more channel) Tx and Rx (plus you have the batteries and chargers) the extra cost to add ailerons would buy one or two servos and some control arms/links.
Regards
retiredbri
retiredbri is offline Find More Posts by retiredbri
Old Oct 27, 2010, 08:48 PM
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Regards
retiredbri
SLOWSTICK with ailerins is not a good idea. you will not be able to do rolls or inverted or any thing related to aileronsyou will not enjoy them as it supouse.. you were only be able to use ailerons on slowstick to make turns. the slowstick have a lot of diedhral to prevent the plane to roll so inverted are imposible. Rolls are possible but you will need to take out the diedral by cutting the wing in 2 and putit back more straight less diedhral. . so if you really want the aileron to go the next step. get an aileron plane that is designed with ailerons.
DaxFX is offline Find More Posts by DaxFX
Old Oct 28, 2010, 01:14 PM
USA, OH, Columbus
Joined Oct 2010
i thought about adding ailerons to the stick but then i searched and read it wasnt a good idea like you said. so thats why i thought this would be cheep and good to start
georgerm is offline Find More Posts by georgerm
Old Oct 28, 2010, 08:47 PM
DaxFX's Avatar
Joined May 2008
hey guys any of you have made any landing gears for the HAWK. any imput will be great. i want to fly in front of my home but i will need wheels for landing.
Old Oct 30, 2010, 06:58 AM
Careful, Im dangerous when wet
Dellagd's Avatar
Pennsylvania, USA
Joined Aug 2010
Personally landing gear wouldnt be a good idea cause it would set off the balance of the plane for those 3D aerobatics
Dellagd is offline Find More Posts by Dellagd
Old Oct 30, 2010, 09:21 AM
DaxFX's Avatar
Joined May 2008
deleted
Old Oct 30, 2010, 11:12 AM
USA, OH, Columbus
Joined Oct 2010
do you guys know of any other place to buy this plane thats not hobbyking or nitroplanes?
Old Nov 04, 2010, 06:06 PM
USA, OH, Columbus
Joined Oct 2010
how have you guys made the cut in the wing for the carbon spar?
Old Nov 04, 2010, 09:15 PM
DaxFX's Avatar
Joined May 2008
I did not make any cut. I glue it to the bottom of the wing and then I put a strip of hinge tale to cover it. I made a little cut in fuselage so wing can pass thru with the rod. Iam using a round rod not flat.
Old Nov 05, 2010, 07:37 AM
USA, OH, Columbus
Joined Oct 2010
do you think there is any downside to doing it this way?
Old Nov 05, 2010, 07:48 AM
DaxFX's Avatar
Joined May 2008
i i have not found any problem with that.
Old Nov 05, 2010, 09:56 AM
USA, OH, Columbus
Joined Oct 2010
well i will try it your way then. what glue did you use foam safe ca?
Old Nov 05, 2010, 09:20 PM
DaxFX's Avatar
Joined May 2008
yes CA foam. dont use hot glue you will make an ugly mess.
Old Nov 05, 2010, 09:37 PM
USA, OH, Columbus
Joined Oct 2010
ok thanks
Old Nov 09, 2010, 06:26 PM
USA, OH, Columbus
Joined Oct 2010
well i got the hawk it was a very easy build. flys great for someone that is basicly just learning how to fly. crashed it today and crunched the nose pretty good but fixed it all up and its good as new.
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 339 Oct 23, 2010 05:29 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
