Old Oct 08, 2010, 06:27 PM
DaxFX is online now
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Originally Posted by beginner4life View Post
I lost the z bend for the rudder servo today. What should i use as a replacement?
pushrod connectors.
DaxFX is online now Find More Posts by DaxFX
Old Oct 08, 2010, 08:21 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Well is there anything i can do that i might like already have on hand? I would like to be able to fly again tomoro
beginner4life is offline Find More Posts by beginner4life
Old Oct 09, 2010, 01:35 AM
wishawhunk is offline
Find More Posts by wishawhunk
scotland uk
Joined Jan 2005
Originally Posted by DaxFX View Post
pushrod connectors.
Do these fit on the servo arms?
wishawhunk is offline Find More Posts by wishawhunk
Old Oct 09, 2010, 01:42 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
yes ! you can used in all of the arms and horns, better for trim than "Z"'s
Old Oct 09, 2010, 08:22 PM
Joined Mar 2008
These? http://www3.towerhobbies.com/cgi-bin...&I=LXAHE6&P=ML
Old Oct 09, 2010, 11:19 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
not all linkage connector are safe. they are few of them that you just snap in the hole oh the arm or horn. the one i show in picture the bolt goes one side and the nut with pushrod in the other side. so is very secure.
Old Oct 11, 2010, 12:20 AM
Da FrOg is offline
Find More Posts by Da FrOg
Joined Apr 2007
would a 3s setup with 8*3.8 APC prop be too much for a 12A esc to handle?
Da FrOg is offline Find More Posts by Da FrOg
Old Oct 12, 2010, 08:18 PM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
hey guys. with the stock motor and esc this bird can hover? mine get home toda i just finish the assamby and doing some test does not have power to hover. i went full throtle and push it up verticaly with my hand and does not stay or climb just went down like underpowered.. any idea.
i am using a 900mah 2s i add a carbon rod to main wing. i dont think is too much weight. servos 1x9g and 2x7g
Old Oct 12, 2010, 08:30 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Hmm...that is a little unusual. I use an 800mah battery and mine hovers with a 7X3.5" prop. It would be a lot better with an 8X4 though. Your servos are probably a little overboard for this plane, as 5g servos should do. Unfortunately, this plane is a little heavier than most 3D's its size, but it still has plenty of power for aerobatics.
T-CAT is offline Find More Posts by T-CAT
Old Oct 12, 2010, 09:19 PM
Joined Mar 2008
Mine only hovers at full throttle
Old Oct 13, 2010, 03:23 AM
masehare is offline
Find More Posts by masehare
masehare's Avatar
Cape Town
Joined Oct 2009
Mine hovers at about 2/3 throttle. GWs 8x4 prop, Zippy 500mah 2S, stock motor & ESC, 1 x 9g and 2 x 5g servos.
As T-CAT said, this plane is slightly heavier than it should be, so try to cut down on weight where you can. Batteries are the most obvious place to start.
masehare is offline Find More Posts by masehare
Old Oct 13, 2010, 06:21 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
I ordered a weight scale last week hope to get it soon. also a HK wattmeter.
almost everybody is close to 210g correct?
a 3D plane have to hover at 1/2 thats the standar.
Old Oct 13, 2010, 07:37 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
i want to buy some props. i was thinking on 9x3.8sf. any recomendation. i want this get to hover.
Old Oct 14, 2010, 03:02 AM
masehare is offline
masehare's Avatar
Cape Town
Joined Oct 2009
I tried a 8x3.8SF and the stock motor struggled to start swinging it. Once it got going the plane flew fine, but the GWS 8x4 performs the same.
Old Oct 16, 2010, 06:49 AM
DaxFX is online now
AIMDROIX
DaxFX's Avatar
Joined May 2008
ok guys o made my maydem today. last night i made a power test and this was the result.
6.4a at wot, after goes full throttle went down to 5.9-6.1
37 watts
53mah in like 40 seconds
stock 8.4 prop
900mah 2s pack mistery
since my batt is a little bigger and over weight I try first pulling it back to not get too much nose weight but this bird want to harrier and hover by its own. then i keep trying different CG and found all the way front almost touching the motor.
wow very stable at low speed. very responsive. i was my first flew on 60% no expo rate.
and still have lots of throw, i went at the point that I look directly at the sun and lost my vision and bird came down very hard nose in. thanksfully was earth and only a bended prop. this bird looks softy but can handle some hard crash.
i have an order placed for some GWS ep8x4.3 & sf8x4.3 ill have to wait. (sad)
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 340 Dec 28, 2015 07:49 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
