Old Oct 05, 2010, 06:02 PM
DaxFX is online now
Find More Posts by DaxFX
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Originally Posted by T-CAT View Post
I just build this plane tonight and veryjong works perfect and it even floes pretty good. However, my rudder pushrod bends A LOT. I can physically move my rudder back and forth withou much effort. My linkage and pushrods are glued correctly and my rudder is taped pretty close to the fuselage so that can't be the issue. When I move the rudder back and forth, I can see my rudder carbon pushrod bend like crazy and keep in mind the servo doesn't move while I do this. It has to be the pushrod. I don't know how to fix this easily. Any suggestions??
the guy from nitroplanes.com made a support with the foam you cut for servos. he made a little square put the rod thrue and glue at the center of the rod to fuselage. glue the foam not the rod !! DUH !!.
DaxFX is online now Find More Posts by DaxFX
Old Oct 05, 2010, 08:28 PM
TheTrashMan is offline
Find More Posts by TheTrashMan
TheTrashMan's Avatar
Joined Jul 2009
HHhhhmmmmmm very tempting!!
TheTrashMan is offline Find More Posts by TheTrashMan
Old Oct 05, 2010, 09:40 PM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
That's funny you said that, because that's exactly what I did. I should post pictures. It works PERFECT, and I didn't spend a dime since I already has scraps of foam I could cut into rectangular slim pieces.
T-CAT is offline Find More Posts by T-CAT
Old Oct 06, 2010, 09:54 PM
mazb is offline
Find More Posts by mazb
Joined Sep 2007
Do anybody knows how to programm this ESC ??
mazb is offline Find More Posts by mazb
Old Oct 07, 2010, 10:04 AM
sNstRflyEr4G3 is offline
Find More Posts by sNstRflyEr4G3
I NEED MORE FOAM...LOTS MORE
sNstRflyEr4G3's Avatar
United States, MA, Webster
Joined Mar 2009
subscribed
sNstRflyEr4G3 is offline Find More Posts by sNstRflyEr4G3
Old Oct 07, 2010, 09:10 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
After doing a bit of damage I'm now using a 1/2"x3/8" light balsa 'n hot glue motor mount. Much tougher now. This little motor is a lot quieter than the stocker and is powerful enough.
The AUW is 240g on 2S800, and 6 minute flights on 8x4.3 are running around 60% discharge. Vertical pull out from a hover is a little slow toward the end of a flight but this is still a fun little beater and I think I prefer it over ultra micro, even if I can't catch an Su-26xp.
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Old Oct 07, 2010, 10:19 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Okay, I just received the GWS 8X4 props that come in a package of 6, and the props don't even fit the standard motor housing. THe prop hole is too big and it moves a ton and can't really be secured enough. What's the deal? It doesn't come with any adapters. Hmm...
Old Oct 07, 2010, 11:41 PM
DaxFX is online now
DaxFX's Avatar
Joined May 2008
most gws does not have adapters. that is why i use apc. use a bullet mount.
Old Oct 07, 2010, 11:53 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
A bullet mount? I'm going to have to look for that. I've never heard of it. Thanks for the suggestion Dax. I'll look for a picture as well.
Old Oct 08, 2010, 01:31 AM
DaxFX is online now
DaxFX's Avatar
Joined May 2008
http://www.hobbyking.com/hobbyking/s..._4mm_to_6.35mm
make sure you know the size of the motor shaft.
that spinner can hold several size of prop holes.
this is not the size is just to show you.
Old Oct 08, 2010, 01:57 AM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Awe, I understand. Sorry for the confusion. I've never heard the name bullet mount, only prop spinner adapter. That's a great idea and I'll have to look around for one. Even though the adapter will secure the prop on the shaft, the prop hole is still to large for the motor shaft. Do I need to find a small plastic ring adapter to fit inside the prop opening, and then fit the prop on the shaft and secure it with the aluminum spinner/prop adapter? Thanks!
Old Oct 08, 2010, 06:30 AM
Joined Mar 2010
I made the same mistake as you and was informed (a few pages back) that the GWS 8x4.3 works just fine, and it does, on both the stock motor, and on the Turnigy 2204-14T that I'm using.
Old Oct 08, 2010, 12:19 PM
DaxFX is online now
DaxFX's Avatar
Joined May 2008
sorry for the "bullet" term. i know that is not the name but in my field we called like that. and i use to called like that. they are a few spinner adapters that have like a cone were the prop goes that can fit diferent prop hole sizes. also all apc's came with some adapter that fit into the hole for bigger or smaler holes.
Old Oct 08, 2010, 01:14 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Thanks for the info guys. I'll have to look around for something that will fit the motor shaft so I can use these larger props I have sitting around.
Old Oct 08, 2010, 01:59 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
I lost the z bend for the rudder servo today. What should i use as a replacement?
beginner4life is offline Find More Posts by beginner4life
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 340 Dec 28, 2015 07:49 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
