Old Apr 20, 2010, 10:20 PM
Boxhead is offline
Find More Posts by Boxhead
Look outside the Square
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Hobby City's EPO 3d-Hawk
Well, I bought one of these when HC put them up on their website.
http://www.hobbycity.com/hobbyking/s...dProduct=11339
The Price I thought was good with the inclusion of motor ESC, prop and prop saver and added bits and pieces. Like most things we buy from the net the price of the item is great its the postage that can be the killer.
Anyhooo here's my review of the 3D Hawk.
EPO 3D Hawk.wmv (2 min 25 sec)
3 Hawk (2).wmv (1 min 47 sec)
W/Span - 650mm
Fuse length - 720mm
Flying weight - 210 - 220 grams
Servos . 2X 5gram, 1X 9 gram ( towerpro )
Motor C20 2050 kv / 8X4 prop
ESC 10 amp
It came double boxed . Upon opening the Box everthing was in plastic and neat and tidy. No damage . Even comes with Chinnese/English instruction sheet in color . The instructions are basic but work in well with the color Picy's. You can see them in Post 9
Now what was in the Box ?
The 3D Hawk EPO airframe, C-20 2050 kv motor, Engine mount, 8X4 prop, prop saver' Double sided Tape, Adhesive tape ( Like Blenderm for hingeing ailerons etc), all the stickers to make it look nice, all linkages ( control rods, wire prebent, shrink tube, control horns ) and a 10 amp ESC.
For my part I added 2 x 5gram servos, 1 X 9 gram servo for the ailerons and an Assan 4 channel Rx. I used a 800 mah 2 cell Batt for the maiden. For Batt power anything from 500mah - 800mah 2 cell would be fine.
Assembly. It goes together quite quickly and easily. I used CA and acelerator for the most part but also used a dab of hot glue around the motor mount and wing area. Once finished the weight W/O electronics ( airframe only ) was 71 grams. Weight with electonics was 156 grams without Batt. All up with Batt 200 grams final weight.
Please Note, on the instructions it says a 7035 prop included but an 8040 was supplied with the Kit. Have tried both and I like the 8040 that was supplied.
The 3D Hawk in flight. Well, it flies and flies well. Does all the tricks. So it was a thumbs up .
Conclusion - Well in conclusion it looks and flys Great. The 3D Hawk went together easy, all the Bits and Pieces that where supposed to be supplied where. It had instuctions in Color and in English which is a good thing. The motor/prop and Esc supplied work fine. The stickers make it look nice, and the EPO foam so far is standing up to my abuse. so for the price, its a thumbs up.
The only thing I added was a 2mm carbon spar for the wing. I think it definately needs it. I have also tapped the nose with Blenderm Tape for strength. A Groovejet idea that works well.
My CG is 56mm from Leading edge of wing or 17cm from front of Fuse.
Heres some pics and hopefully I'll have a video up shortly.
If you made it this far Thanks for reading my review .
Bx
Boxhead is offline Find More Posts by Boxhead
Old Apr 22, 2010, 09:41 AM
pilotpie4 is offline
Find More Posts by pilotpie4
Joined Feb 2010
How does this fly?
pilotpie4 is offline Find More Posts by pilotpie4
Old Apr 22, 2010, 02:25 PM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Looks like it would be nice to paint.
Hows the aileron movement? Looks to me by the design that it might be better to assemble with the wing upside down, so the aileron servo pulls on the hinge line. Only bad thing about upside down mounted aileron servos.
Dan5.0 is offline Find More Posts by Dan5.0
Old Apr 22, 2010, 02:43 PM
Joined Feb 2010
Really? I have not noticed that.
Old Apr 22, 2010, 07:17 PM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
PP4. Mate it flys really well. I'll have to pull my finger out with the video.
Dan, I dont know how it would go painting the EPO. It has a greasy feel to it. Might be some info on here on how to prep it for painting. I just used the stickers provided. The aileron movement I've found to be fine. The rolls are good.
I've tried using a 450mah 2 cell Batt with the setup up provided this morning and only got 3 1/2 min run time with it. I have been also using 800mah 2 cell batt and have been getting a run time of between 5 - 6 min. So the C20 might be a bit hungry on juice. I've read that the 19 gram turnigy motor is a lot better for power and run time on 2 cell than the C20 provided. Might stick one in and see.
Video is up in Post 1
Bx
Old Apr 23, 2010, 05:02 AM
Dan5.0 is offline
Dan5.0's Avatar
Joined Dec 2008
Maybe those hinges are double bevelled, can't tell from the photo, but it does make a difference, in movement, deflection, and speed.
Old Apr 23, 2010, 06:10 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Dan, the hinges aren't double bevelled. Just single bevelled.
Bx
Old Apr 23, 2010, 10:31 AM
Dan5.0 is offline
Dan5.0's Avatar
Joined Dec 2008
The hinge tape was already done or you have to do it yourself?
Old Apr 23, 2010, 05:12 PM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Dan, it comes as a flat pack. All hingeing is done by you. Hingeing tape is supplied in kit. I used my Blenderm tape I had on hand instead off the supplied tape. Also here's the Instruction sheet that come with the Kit. I had to scan it in 3 parts.
Bx.
Old Apr 28, 2010, 04:46 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
Well I thought I'd swap motors over and see how the Hawk performs. I replaced the C20 with a 19gram Turnigy Motor still using the same ESC and 800mah Battery. http://www.hobbycity.com/hobbyking/s...idProduct=6547
I put a 8043 prop on it and it flew well. I have no motor data figures but the little Turnigy seems to have the same maybe a bit more grunt and the flight duration is longer than the C20. So it seems both motors work well with the Hawk. Its a great little plane to leave in the car so when an opportunity arises just whip it out and have some fun.
Bx
Old Apr 28, 2010, 05:29 AM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Bx
Hello
I'm building this model and I'm in a serious thinking of changing the motor with the one I've already have:
http://www.hobbycity.com/hobbyking/s...idProduct=8619
I saw your video and I believe the stock motor is power enough. (very good flight )
Do you know which motor is?
Also can you tell me in which position did you put the rudder and elevator servos? (Distance from the from of fuse)
I saw that your CG is 56mm do you think that it needs any change. Is it tail heavy or nose heavy? The manufacturer doesn't points the CG.
I've already 3 610mAh Rhino from your review I think I'll have about 4.5 min of flight time too small.
kstmark is offline Find More Posts by kstmark
Old Apr 28, 2010, 07:05 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
kst, mate this is the motor that comes with the Kit. http://www.hobbycity.com/hobbycity/s...idProduct=6634
The motor you have mentioned I reckon will do really well. The specs look good and it has good write ups in the discussion thread on HK.
The picture below shows where I have put the servo's in the fuse. By reading about your motor I think you might get a little bit more flying time than what you think you will. Only flight testing will tell what you will get. With the 19gram Turnigy motor and 800 mah 2 cell battery I got 10 mins flying time and with 450mah 2 cell I got about 5-6 min flying time this morning.
The CG I have put up maybe if anything tail heavy. But it gives you some where to start. Adjust to suit your flying style. Hope this helps and I wish you luck.
Bx
Old Apr 29, 2010, 12:48 AM
kstmark is offline
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
Bx
thanks Bx
I'll post mine motor results when I'll finish.
Old May 01, 2010, 02:17 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Shame on you Box for not building a 3D model from plans! I've only recently finished Leadfeathers Yak55
http://www.rcgroups.com/forums/showt...64237&page=137. Mine is the one in post 6828 & 6856. Like yourself, I'm now finding a use for my left thumb other than the go lever. Sure does nice flat turns.
I noticed the HK offering after I started my Yak build. It looks to fly really well. You could try Multiplex primer on the foam if you want to add more colour.
Head
headlessagain is offline Find More Posts by headlessagain
Old May 01, 2010, 03:29 AM
Boxhead is offline
Boxhead's Avatar
Gosford, Australia
Joined Jan 2006
SHAME.... SHAME you say Headlesss....Hahahahahahahhaa Well let me tell you fella ....... Hahahahhahhahahahahahha
Mate if you have a look at page 250 Post 3744.... http://www.rcgroups.com/forums/showt...0#post12977092 Ah their it is, my LF Yak. Its a definate Ball Tearer, Head. It put me on the right track to teach my left digit that it wasn't their for its looks. Still have it and fly it regularly. She's a beaut.
The HK Yak is very similar almost identical to Leads Yak. And Leads Yak was here first ....Mmmmmmmmmmmmm. The HK Yak is made from EPO and Leads Yak is from EPP. Thats about it as far as I can see. I still look into the Scratchbuild most days. Good to hear from you mate
Bx
Discussion the hobby city YAK55 .50e 3D ARF 98% whos got one???/ brett1984 3D Flying 340 Dec 28, 2015 07:49 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion Problems with batt's from Hobby City?? Dagwood_55 Batteries and Chargers 27 Dec 21, 2009 07:06 AM
Sold 3D Hobby Shop 47''Extra 300SR LPU Iowa City area CptnBE20 Aircraft - Electric - Airplanes (FS/W) 1 Nov 14, 2009 10:38 AM
Sold HObby city Techone "unbrakeable" 3d planes or Hyperion Sniper XL muskis2 Aircraft - Electric - Airplanes (FS/W) 2 Oct 21, 2009 10:02 PM
