Old Jun 05, 2003, 10:14 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Pat Tritle's Wright Flyer 03, Jenny Info
E-mail from Pat yesterday:
The 03 Flyer is finished, and the wing warp worked just as planned. The cover is silk and dope, like on the 09. The trick to getting the aged linen look is to soak the silk in STRONG HOT coffee for 10-15 minutes. Lay it out flat on a towel and let it dry. Then, apply it to the model wet, and finish it with 4 or 5 coats of Sig Litecoat. By preshrinking it doesn't warp the airframe, and using non-taughtening dope, it cures out nice and uniform but not real tight. It took a few tries to find the right combination, but this method has worked out well for me.
BTW, we have a tentative kit release date from Dare for the 65" (1/8 scale) Jenny. I'll be buttoning the plans up soon and we'll get the show on the road. It's been a long time coming, and is admittedly long overdue. The model is powered by a Dymond 05 with an Olympus belt drive and a 12-6 APC E prop on 7 2400 cells and 4 channel radio.
I noticed the discussion of the 1/12 scale Dare jenny concerning using ailerons. I've talked to guys who have done it with good success, but bear in mind, it's still very much a rudder airplane, even with reduced dihedral. The Titanic 3:1 S-280 on 8 cells using the Gunther prop is more then adequate power, and if you use an 8-6 APC Slow Fly prop it turns into a guided missile! Using the recommended 3:1 S-280 system and 3 channel, it keeps all the charm deserving of those graceful old airplanes.
Thanks, PAT
E-Challenged is offline Find More Posts by E-Challenged
Old Jun 05, 2003, 11:23 AM
Joined Oct 2000
Bigger Jenny Pic
Sorry, here's a bigger shot of 65" w/s Jenny
Old Jun 06, 2003, 01:52 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Pat's Jenny was incredibly graceful and realistic in the air over SMALL.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Discussion Pat Tritle's New Curtiss Pusher E-Challenged Scale Kit/Scratch Built 12 Apr 28, 2009 09:15 PM
Discussion Pat Tritle's Fairchild 24 E-Challenged Scale Kit/Scratch Built 6 May 08, 2002 09:52 AM
Foam Wings For Pat Tritle's F9F? ARA Electric Plane Talk 0 Apr 12, 2002 12:25 AM
Discussion Pat Tritle's SE-5a knight of Ni Scale Kit/Scratch Built 0 Jan 14, 2002 11:19 PM
Discussion Pat Tritle's B-17 J Bergsmith Scale Kit/Scratch Built 4 Sep 21, 2001 08:39 PM
