Old May 03, 2012, 09:16 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Originally Posted by Limited flyer View Post
Was it really THAT strang of a question?
Yes, it was.
lol
shunyata is offline Find More Posts by shunyata
Old May 03, 2012, 09:38 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
I haven't tried to bind two at the same time and I do not know why you would.
So my questions is why?
Do you need more channels or are you going to fly 2 planes at the same time?
Eagle202 is offline Find More Posts by Eagle202
Old May 03, 2012, 10:07 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Well, i guess i sort of had in mind behind the idea is to bind two similar type plaines togeather{such as two 4 chanell warbirds} that would be a stones throw in simularities, that at the time your flying one of them, nothing would have to change between the two of them,{other than having the one turned off at the time your not using it
Well at least it makes sense in my noodle.
Limited flyer is offline Find More Posts by Limited flyer
Old May 04, 2012, 12:28 AM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Originally Posted by shunyata View Post
Hey Geotete,
Those numbers look pretty good. You should have plenty of power to get it in the air launched off a cliff as you mentioned.
Basic setup for our heavy-lifter Bixler.
Stock brushless motor
6x4E APC prop, about 24amps WOT static
Castle Thunderbird 36a
Castle 10a BEC
HS-65HB servos for rudder and elevator
stock aileron servos
HXT900's for flaps
Qty 2 Spyder 2200mah 3S bats in parallel, slipped into little holders under the wing. Each bat weighs about 180 grams.
AUW is about 3.5lbs, 1600 grams
Futaba RX, Immersion OSD, GPS, etc..
Gaffers tape used for extra hold. Gaffers tape rocks!
Must be tossed off cliff to get airborne. LOL
This beast is pretty much maxed out which is why we're building up a new 1900mm Skywalker. New plane will be much cleaner. And it will have a belt-driven gimbal for camera, gimbal will mounted in a very unique way. Got it all figured out. Should be awesome!
edit: GoPro mounts on the nose.
Shunyata,
Whats the recomended CG the manufacture sugest and what is everyone adjusting there CG too for best performance?
What flight times were you getting with one 2200mah.
Eternalflight is offline Find More Posts by Eternalflight
Old May 04, 2012, 01:00 AM
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
Originally Posted by timtimtim View Post
Which esc should i use for bixler with stock motor and 2200 25C Zippy battery? is this any good? http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
anyone?
That's the exact one I bought for mine. It's still in the mail though together with my Bixler. I chose that one on the recommendation of having a 3A UBEC, and considering it's rated 30A, it should be more than enough for the stock motor even with a 6x4e prop (which is also what I ordered)
fabric8 is offline Find More Posts by fabric8
Old May 04, 2012, 01:53 AM
JoshB is offline
Find More Posts by JoshB
Novice in training
JoshB's Avatar
United States, NC, Statesville
Joined Aug 2011
Servo question. Is everyone using the HXT900's? http://www.hobbyking.com/hobbyking/s...?idProduct=662
If so how? From what I have read they are very power hungry and with 4 you would need something with at least a 3 amp bec. Thats kind of crazy they draw that much in my opinion. Are there any other options?
I bought this ESC http://www.hobbyking.com/hobbyking/s...5_40A_ESC.html to use with the stock BL motor, but now I'm wondering if its enough.
JoshB is offline Find More Posts by JoshB
Old May 04, 2012, 01:58 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I bought this ESC www.hobbyking.com/hobbyking/store/__6461__Hobbyking_SS_Series_35_40A_ESC.html to use with the stock BL motor, but now I'm wondering if its enough.
They pull about 0.6 at peak, for 4x you are looking at 2.4 pull if all 4 are running hard at the same time.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 04, 2012, 02:07 AM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
That ESC had a built in 3 amp bec but I doubt it will actually work that high since they are usually overrated from my experience. I guess I might just have to hook it up and try it. HK just got a shipment in of them. I have some other 9g servos but they are from HPz. Idk what they pull amp wise.
These are the ones I have now. www.hobbypartz.com/9gmiseexis1.html
Old May 04, 2012, 02:46 AM
makind is offline
Find More Posts by makind
makind's Avatar
Australia, QLD, Coorparoo
Joined Apr 2011
Im using them in all my planes (4 servo per plane) with no UBEC, ESC rated for 2A. No problems so far.
makind is offline Find More Posts by makind
Old May 04, 2012, 03:12 AM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
1 ail or 2 ail?
which work best or just the same.....1 ail or 2 ail setup (T8FG)?
CPMBOY is offline Find More Posts by CPMBOY
Old May 04, 2012, 06:50 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
HXT 900s are fine. Unless stalled you should have no problems. Besides, when have you used all 4 servos at the same time? This plane is a glider not an aerobatic plane.
Your esc choice is suspect with a 2000 kv limit and Bec that's probably linear. A 30 amp Hobbywing Pentium with a switch mode Bec is a better choice.
Prof100 is offline Find More Posts by Prof100
Old May 04, 2012, 07:02 AM
elcid79 is offline
Find More Posts by elcid79
elcid79's Avatar
Joined Apr 2012
How long do your Servo lead extensions need to be? I bought 500 but someone told me those where going to bay way to long, and that some voltage drop may occur, rendering them useless. Do y'all agree?
Thanks!
elcid79 is offline Find More Posts by elcid79
Old May 04, 2012, 08:14 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thanks!
Nonsense.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 04, 2012, 08:15 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
It is more than enough.
AJ
Old May 04, 2012, 08:18 AM
JoshB is offline
Novice in training
JoshB's Avatar
Joined Aug 2011
Your esc choice is suspect with a 2000 kv limit and Bec that's probably linear. A 30 amp Hobbywing pentimento with switch mode Bec is a better choice.
Ok. I might just order several of those servos and a new ESC thats rated more. Not sure what the factory BL kv is though.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
