Old May 01, 2012, 12:47 PM
ceandre is offline
Find More Posts by ceandre
Joined Jul 2010
Originally Posted by RVA View Post
have them in mine. Work like a charm. Be sure and make sure you have them positioned correctly (facing same direction, opposite as you would for ailerons) BEFORE you glue. (ask me how I know? )
Heheh! Thanks for tip!
ceandre is offline Find More Posts by ceandre
Old May 01, 2012, 12:50 PM
ceandre is offline
Joined Jul 2010
Originally Posted by wic View Post
I have also installed flaps on my bixler with the HXT900. And I set a other SBEC in the Bixler because I also have two gyros installed.
But its fly very nice with the flaps. I made it at the same size some ailerons.
Best regards from finland
No probs I'll use external SBEC to power 4 servos (2x HXT900 + 2x 922MG - Ailerons/Rud/Elev.) and internal BEC from ESC to power 4x servos (2x HXT900 + 2x HXT500 - Flaps and Pan-Tilt camera servos).
Old May 01, 2012, 01:12 PM
shunyata is offline
Find More Posts by shunyata
'tis nothing
shunyata's Avatar
United States, CA, Napa
Joined Dec 2011
Originally Posted by ceandre View Post
Hi ppl,
I'm going to install flaps in my Bixler.
Since I dont want cut so much foam from wing, I thinking to use HXT500 for flaps, anyone see any problem with those lower torque servos just for flaps?
Thanks!
I'd use the HXT900's if you can. Else, try those. They just might not work well when flying at speed. Think about it this way. Like in a scale plane, deploy only at the rated speed, ie. going slow.
Also, I would recommend a UBEC to power the servos now that you'll have six. No way the stock ESC's BEC circuit is rated for 6 servos. A 3 amp UBEC is all you need. I've been using Exceed 3amp BECS on several planes, including my SS. Under $10.
On our FPV planes, Castle 10amp - those run about $22. There are others.
edit: I see you got it covered.
shunyata is offline Find More Posts by shunyata
Old May 01, 2012, 02:41 PM
AmishLou is offline
Find More Posts by AmishLou
AmishLou's Avatar
United States, VA, Quantico
Joined Mar 2012
I'm working on putting the two fuselage halves of my Bixler together with double sided tape eventually. I have this ESC: http://www.hobbyking.com/hobbyking/s...arehouse_.html
I'm looking for tips or ideas on where to place/secure the ESC inside the body and how to do that? It seems that it would be difficult to access/install the ESC if I waited until after I taped the halves together, but if I do it before, I can only think of velcroing it to one of the inside walls a little ways back in the fuselage.
Also, with the 40A ESC and using the stock motor at the moment, do you think there will be any need for cooling duct(s)?
AmishLou is offline Find More Posts by AmishLou
Old May 01, 2012, 02:47 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
I'm siting mine outside, but that thing's a beast!
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old May 01, 2012, 02:54 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Wing warped??
Originally Posted by Prof100 View Post
Mine is straight on center and no torque rolling. Go figure. Maybe my wings are warped.
Maybe with someone else. But, not you. I think your "go figure" covers it pretty well.. Next time I fly it, I will watch it very closely at WOT and see if it rolls or yaws. Maybe I am just correcting for it so fast that I don't know it is doing anything (even slightly) wrong.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 01, 2012, 03:01 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Wing warp most likely
Originally Posted by CPMBOY View Post
I do set channel 3 (throttle) to control the timer. That is a great feature!
A haaa.....how2?
..I wasnt joking at all.....if she's up there..the tx will still be with me not with her.......so its logic right..............
oo..here's mine and FYI, my Bixler was turning right w/o any stick input.
Hmmmm.... Your situation is different than Prof100's or my setup. With no motor power at all, your wing almost has to be warped (best guess). Other possibilities (even though remote) - warped/misaligned horizontal stabilizer, warped/misaligned vertical stabilizer, twisted fuselage, or CG too far back. Since the motor is not powered on, it cannot be part of the problem. Let us know what you found when it is fixed.
AJ
Old May 01, 2012, 03:11 PM
shunyata is offline
'tis nothing
shunyata's Avatar
Joined Dec 2011
Originally Posted by AmishLou View Post
I, but if I do it before, I can only think of velcroing it to one of the inside walls a little ways back in the fuselage.
A few ideas. Like many, I used a plastic spoon for an air intake on the top of the nose a few inches in front of the canopy. It vents to the rear on both sides of the fuse.
ESC is velcroed in place. There is a BEC mounted a ways back on velcro. Everything is on velcro! LOL.
edit. I also tape plastic tubes and run the RX antennas inside them so they don't flop around nor need to be taped. Easy to remove RX that way.
Old May 01, 2012, 04:12 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ
AJ,
Are his decals lifting up?
Bill
Prof100 is offline Find More Posts by Prof100
Old May 01, 2012, 04:19 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Oh yeah....
AJ,
Bill
Excellent suggestion. Of all people, I should have guessed that one. And, we both know why.
AJ
Old May 01, 2012, 07:53 PM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
A haaa.....how2?
oo..here's mine and FYI, my Bixler was turning right w/o any stick input.[/QUOTE]
I would trim your rudder then. If you're not torque rolling I would suspect the yaw is coming from your rudder which may be out of trim. Your tail may also be slightly warped which could be causing your vertical stabilizer to be out of alignment.
Dkumagai is offline Find More Posts by Dkumagai
Old May 01, 2012, 08:15 PM
Dkumagai is offline
Joined Oct 2011
Whoa, decal on nose, different cockpit position, did BH put out another version?
Old May 01, 2012, 08:26 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
AJ
ok ...actually what I meant was w/o any aileron input but the motor is ON. the wings, hor&ver stabs are in perfect shape. emm...do you think this has to do with the motor angle thrust?.....btw yesterday I hvnt had a chance to glide it (w/o motor power) and observe.
CPMBOY is offline Find More Posts by CPMBOY
Old May 01, 2012, 08:33 PM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
straight?...do you mean your motor angle thrust?
Old May 01, 2012, 08:57 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Yes, looking from the top the motor centerline is parallel with fuselage centerline.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
