Old Apr 23, 2012, 02:27 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by fabric8 View Post
It looks like they are sold in 2oz bottles. How many would you say i'd need to build the plane?
I dunno honestly, I got a tube of it cheap from HK when I bought the plane, and even after using it many a times for various things I still have more then a half of tube left. I can't locate it at the moment to let you know how big it is...
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 23, 2012, 02:39 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Glue
You could assemble about 8 planes with one bottle.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 23, 2012, 02:41 PM
fabric8 is offline
Find More Posts by fabric8
Fixed and rotary wing flyer
United States, NV, Las Vegas
Joined Sep 2011
AJ
WOW!!!
fabric8 is offline Find More Posts by fabric8
Old Apr 24, 2012, 12:15 AM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
Originally Posted by NorCalMatCat View Post
My plane is completely held together with foam tac :P Foam tac is VERY flexible stuff and works well for foam, and isn't that hard to separate either if you want.
I might have to give that stuff a try. I don't much care for CA (and hate foam safe varieties), and epoxy is messy. I'm always looking for good adhesives. Do you know if foam tac works on depron? In particular, will it mate porous cut edges?
On another note, I took my SS out on Saturday and noticed something weird. The leading edges of my APC 6x4 sport are turning green. I'm puzzled as to what is causing this discoloration, and no, I don't land upside down on grass. It must be some contaminant in the air or something, I've put at least 20 hours and probably 400+ miles on this prop.
Dkumagai is offline Find More Posts by Dkumagai
Old Apr 24, 2012, 12:24 AM
marhar is offline
Find More Posts by marhar
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
Originally Posted by Limited flyer View Post
No, i am not patiant, yes i know lipos can't travel by air,and yes it is ems via swiss post, and last, i would have went through the us ware house but they did not have every thing i wanted and only wanted to pay shipping from ONE place, any thing else?
On the up side, battery delivery from HK International warehouse will give you lots of practice in Patience!
marhar is offline Find More Posts by marhar
Old Apr 24, 2012, 06:44 PM
ceandre is offline
Find More Posts by ceandre
Joined Jul 2010
Hi ppl,
Someone tried use a oversized ESC islead make holes on Bixler to cool down ESC?
Like using 50A (I got one 50A Red Brick) ESC for a 30A motor (Turniy 2826-6 2200kv), and switched external BEC?
Thanks!
ceandre is offline Find More Posts by ceandre
Old Apr 24, 2012, 07:18 PM
Joined Oct 2011
Originally Posted by ceandre View Post
Hi ppl,
Thanks!
I originally used a 30a turnigy-ae ESC which was mounted on the side of the plane, I have since upgraded to a 40-50hk ESC which is now mounted inset into the foam above the wings near the motor. Doesn't matter what size ESC you use as long as the amp rating is higher then what you need, though of course the higher the ESC can handle the bigger it will be and the more weight it will contribute.
On a secondary note, my 2200kv motor and new 6x4 prop came in, prop was about as horribly out of balance as my current one is, though this time I did not dremel it out to fit the prop holder , actually there is no insert that fits this RCTimer shaft perfectly, it's slightly lose with the closest fit one, has anyone ever tried to use a piece of electrical tape on the shaft to make the prop fit nice and snug?
Old Apr 24, 2012, 08:34 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Prop and confusion
The RCTimer output shaft should be 3.17mm. I don't know of any way to mount a prop directly onto the output shaft without some kind of adapter. What am I missing here?
BTW-What prop was it that you had so much trouble balancing? I want to make sure to avoid ordering them.
AJ
Old Apr 24, 2012, 08:42 PM
Joined Oct 2011
AJ
The fit on the adapter that came with the motor, the closest fitting adapter ring for the prop is just slightly bigger opening, 3.175 apparently :P.
The actual prop is this one: http://www.ebay.com/itm/120456260486...84.m1497.l2649 Which is the same as the one I originally got from HK.
Old Apr 24, 2012, 09:20 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
prop & adapter
I bought this two props for my Bixler but it doesnt fit well with the stock adapter. Whats the suitable adapter for this two?...
1. http://www.hobbyking.com/hobbyking/s...idProduct=7936
2. http://www.hobbyking.com/hobbyking/s...idProduct=9873
CPMBOY is offline Find More Posts by CPMBOY
Old Apr 24, 2012, 09:39 PM
Alpha35 is online now
Find More Posts by Alpha35
Joined Feb 2008
3.175 mm = .125 " (1/8") exactly, if that's any help.
Alpha35 is online now Find More Posts by Alpha35
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
You need a collet adapter like the below and you need a reamer to size the prop inner diameter to fit the collet. A reamer keeps the hole centered, a drill does not. You can buy these at HeadsupRC.com for a few dollars. He only ships in the USA.
Prof100 is online now Find More Posts by Prof100
Old Apr 24, 2012, 11:22 PM
Jerry Campbell is offline
Find More Posts by Jerry Campbell
Jerry Campbell's Avatar
United States, OR, Blodgett
Joined Apr 2011
NorCalMatCat wrote:
"there is no insert that fits this RCTimer shaft perfectly, it's slightly lose with the closest fit one"
Has anyone else had this problem?
I'm having trouble centering the prop so it doesn't vibrate.
Jerry
Jerry Campbell is offline Find More Posts by Jerry Campbell
Old Apr 24, 2012, 11:55 PM
LawnDartMike is offline
Find More Posts by LawnDartMike
LawnDartMike's Avatar
United States, OR, Salem
Joined Jan 2012
Get a good prop balancer. I have yet to buy a prop that was in ballance. Some were close but none were dead on.
LawnDartMike is offline Find More Posts by LawnDartMike
Old Apr 25, 2012, 12:48 AM
marhar is offline
Mark Harrison
USA, CA, Piedmont
Joined Jun 2010
+1... I had a prop last year that came balanced. It actually cost me more time coz I couldn't wrap my head around that the prop was balanced and that I wasn't making a mistake!
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
