Old Apr 13, 2012, 05:11 PM
Landiin is offline
Find More Posts by Landiin
Joined May 2011
Originally Posted by Eagle202 View Post
Gimmer
You are a plain idiot. You flew into the flock that was coming at you head on not once but twice. You could have hurt a bird & destroyed your Bix.
I believe that following a flock of birds is ok but not driving right through them. You are sharing the sky with them and being the "intelligent" species you should have avoided or stayed outside for safety and humane reasons
It's too bad they weren't a more aggressive bird. They should have torn your Bix apart.
Please they are just birds, I do the same thing with buzzards all the time. They even come out now when I go flying to glide along in the sky with me. Granted when I throttle up they tend to flee. then the chase is on.
Landiin is offline Find More Posts by Landiin
Old Apr 13, 2012, 05:23 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I have followed birds but I do not get too close, I don't care so much about the tons of seagulls and other rat birds around here, though they are big enough to cause me lots of money in damage so I don't get very close to them :P.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 13, 2012, 07:53 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
I call them hawks,.
Limited flyer is offline Find More Posts by Limited flyer
Old Apr 13, 2012, 09:52 PM
elcid79 is offline
Find More Posts by elcid79
elcid79's Avatar
Joined Apr 2012
This will be my first model A/C in years. Also my first electric. Hows this for ordering stuff? Do I need anything else? Thanks!
So this is what all I am looking at ordering. Is there ANYTHING that I am missing that I should get also? Thanks in advance...
Bixler
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Turnigy 9x
35A brushless ESC (Is this one okay, it calls for a 20A.)
Balance charger... (How do you power this stupid thing...)
Batteries.
Any other thoughts concerns or considerations? Thanks!
elcid79 is offline Find More Posts by elcid79
Old Apr 13, 2012, 09:56 PM
Joined Oct 2011
Bixler
Turnigy 9x
Batteries.
Only thing I see missing to make it a complete system is a power supply for that big 10a charger, heck you could charge 4 of those batteries at once with that thing at full 1C and still have some power left over :P.
The ESC is an OK choice, though I would also use a 3A switching UBEC instead of the built in one of the ESC, also you should get a 6x4 prop as the stock prop is not the best.
Old Apr 13, 2012, 10:00 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Bixler
Turnigy 9x
Batteries.
The ESC has a linear BEC. You want an ESC with switchmode BEC ( less heat generated when stepping down the voltage). Keep shopping.
A couple of the items are out of stock.
Prof100 is offline Find More Posts by Prof100
Old Apr 13, 2012, 10:02 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
Yeah,, I saw.. I don't mind waiting a while. What ESC would you recomend. Are the ones from ebay et all okay?
Old Apr 13, 2012, 10:04 PM
Joined Oct 2011
Turnigy Plush ESC's tend to treat people well, I am using an Opto 40A-50A from HK currently and I love this ESC, it doesn't even get WARM :P (The larger the ESC is in capacity above that which is required will mean less heat), though I wouldn't use anything any bigger then I am using, then you are just wasting weight :P.
Old Apr 13, 2012, 10:23 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
Like This one??? http://www.completeheli.com/Turnigy-...roller-TR_P25A Have any of you ordered from them?
As per the charger, I picked that one bc. it has some grow room. But if thats just way to much wiggle room. Whats a good cheaper one to start with? I saw a ton on ebay but I am scared to get some crap that catches my house on fire. What are y'alls thoughts..
Old Apr 13, 2012, 10:35 PM
Joined Oct 2011
It's a good charger, just realize you will need a good power supply for it, that thing will need a 12v 10amp supply which isn't going to be easy to find, BUT you can put any 12v supply on there just don't ever try to charge any higher then what the supply is rated, I.E. if you have a 2A supply don't use more then 2 amps in charging...
I have the 5 amp version of that same charger, but I only have a 3.25 amp power supply, I am still looking for a good 5amp supply myself :P
Old Apr 13, 2012, 10:55 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Hobbywing Pentium ESC (make sure it says switchmode BEC).
Ebay is friggin crap shoot. Buy one from Hobbypartz.com.
Old Apr 13, 2012, 10:57 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Bixler
Turnigy 9x
Batteries.
Remember the easily forgotten items, like connectors etc! its a pain when these are forgotten.
Also get some 6x4 props.
Thats all I can think of for now
sammyc is offline Find More Posts by sammyc
Old Apr 13, 2012, 11:00 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
Which connectors would I need. I honestly havn't built a model in years. Trying to do as much research as I can but its difficult.. Thanks in advance!
Old Apr 13, 2012, 11:05 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
If you are talking about wiring connectors (motor to ESC) you'd buy a set of three 3 mm connectors with male-female pieces. You can buy them at HeadsupRC where they have good prices and unbelievably reasonable shipping prices.
If you buy your batteries from Hobbyking you'd probably get them with XT60 (yellow) female connector. You need a male one to solder to the ESC.
Old Apr 13, 2012, 11:29 PM
elcid79 is offline
elcid79's Avatar
Joined Apr 2012
Okay, cool. I will look at adding those. Thanks, there is an aweful lot to learn about this again.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
