Old Apr 11, 2012, 04:28 AM
Skribbles is offline
Find More Posts by Skribbles
Australia, TAS, Old Beach
Joined Oct 2010
Originally Posted by ajbaker View Post
Prof100 gave you some excellent suggestions, IMO. I would just add that you could use double-sided scotch (cello?) tape to make it a bit easier to separate the fuselage if you ever need to do that.
AJ
Cool, not a bad idea at tall, thanks.
If/when I get another bixler (or that style plane) I'll be sure to do that.
Skribbles is offline Find More Posts by Skribbles
Old Apr 11, 2012, 08:42 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Flypoppa View Post
Hey AJ I wish you had edited that vid. My iPad screen went black and I thought that the iPad had gone legs up. Blo*dy frightened me.
Nice landings.
<grin>. I did edit it. It started out to be 12 mins long. I think we all pretty much agree that a video should be around 3 minutes or less to avoid boredom. Even at that, I had too many "speck" shots which I do not like. But, thanks for the props on landings.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 11, 2012, 11:45 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
I took it out because is was such a great day for flying.
AJ
http://www.youtube.com/watch?v=hRkM8DyQSfM
Thought i was blacking out for a sec,in your past vids i have never seen your cam darken like that, good landings and rolls thogh.
Limited flyer is offline Find More Posts by Limited flyer
Old Apr 11, 2012, 05:24 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Upload the video again.
You are the 2nd person to mention this. So, I watched it through the link that I posted. Utube definitely hosed my video. So, I re-uploaded it and hopefully it is OK now. Thanks for the heads-up and props for the landings. Please accept my apologies for any panic that I caused (I'll take the blame because I should have checked the entire video AFTER the upload).
AJ
Sky Surfer_4-9-12.mov (3 min 14 sec)
Old Apr 11, 2012, 05:36 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
The Optimal engine for the Sky Surfer - OT but only 1 post
Any suggestions on how to mount this?
AJ
CIMG3464.MOV (3 min 0 sec)
Old Apr 11, 2012, 06:39 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
AJ
Duct tape.
Sounds like Bill's Rambler.,
2500GENE is offline Find More Posts by 2500GENE
Old Apr 11, 2012, 06:41 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
AJ
http://www.youtube.com/watch?v=pDa87tWzInM
GWS 10mm stick mount.
Aeronca
aeronca is offline Find More Posts by aeronca
Old Apr 11, 2012, 06:52 PM
ands is offline
Find More Posts by ands
wottree
United Kingdom, England, Exeter
Joined Nov 2011
I wouldn't use hot glue that's for sure.
ands is offline Find More Posts by ands
Old Apr 11, 2012, 07:20 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
AJ
Wow an external combustion steam engine for an RC plane. Brilliant!!
I guess you can put it inside the belly of an X8 Beast with a long drive shaft between the fly wheel and the prop in the rear.
Of course the foam may start to soften a bit.
Nice video AJ
Eagle202 is offline Find More Posts by Eagle202
Old Apr 11, 2012, 07:32 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
AJ
Nope, but what about this engine?
(This motor is on the opposite side of my block :P)
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 11, 2012, 08:03 PM
Limited flyer
Joined Dec 2011
AJ
Gonna have trouble keeping that lit in the air.{That is of course if you can get it mounted and can find CG}
Old Apr 11, 2012, 10:05 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ
Why am I not surprised?
Prof100 is online now Find More Posts by Prof100
Old Apr 11, 2012, 10:26 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
What's the KV?
Prop size?
IFlyRCs is offline Find More Posts by IFlyRCs
Old Apr 11, 2012, 10:45 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
What ESC would be a good match?
sammyc is offline Find More Posts by sammyc
Old Apr 11, 2012, 10:54 PM
Joined Oct 2011
ESC for that large electric motor? or a steam engine? (which wouldn't use an ESC, and a steam engine wouldn't be rated in KV... :P)
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
