Old Apr 10, 2012, 07:05 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Flight on really nice day.
I took it out because is was such a great day for flying.
AJ
http://www.youtube.com/watch?v=hRkM8DyQSfM
ajbaker is offline Find More Posts by ajbaker
Old Apr 10, 2012, 07:14 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by wilem View Post
i have one using it with a e-flite pro 25 amp sc... the E-flite ESC only has two settings for timing... this one cuts out on mid throttle so its either low or high. the hobby king motor did the exact same thing....i am gonna change the esc. it is a powerful motor..
I am using a HK 40A-50A ESC so I know it can handle it, but is the rctimer motor any good?
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 10, 2012, 07:23 PM
Skribbles is offline
Find More Posts by Skribbles
Australia, TAS, Old Beach
Joined Oct 2010
Hey fellas, just got a Bixler (first plane ).
I got an ARF but the 2 fuse halves are not glued together and no glue was supplied, just wondering what glue I should use?
Skribbles is offline Find More Posts by Skribbles
Old Apr 10, 2012, 07:26 PM
Joined Oct 2011
Ok I took the plunge and bought the rctimer 2200kv motor. For $12 if it doesn't work well then it's not much of a loss :P. I also bought a prop balancer, and a new 6x4 prop :P.
Now to wait for it all to arrive, but in the mean time still gonna fly her with this motor :P
Old Apr 10, 2012, 07:59 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
[QUOTE=Eagle202;21293267]Thanks. I was looking for one that had steps of 4, 5, 6 & 7mm or a tapered one from 3mm to 10mm.
Still looking.
Scratch that. I found an Empire 27770 T-handled taper for $12.83 on Amazon. Add a 6 inch pit bull LCD digital caliper for $12.39 and got them both shipped for free.
Thanks for giving me the idea to check places other that hobby shops.[
I hate to nit pic{I really do i just can't help it}, BUT i dont' think i gave you other ideas to check other places than hobby shops, since the place where i got the reamer from was called HOBBY WHOLESALE,just saying.
Limited flyer is offline Find More Posts by Limited flyer
Old Apr 10, 2012, 09:22 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
[QUOTE=Limited flyer;21294072]
Still looking.
Actually between the tip about Menards from road_rascal and yours about a wholesale place for some reason triggered my search in Amazon. Can't explain it but that is how my mind works sometimes. My thanks to both of you stands.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 10, 2012, 09:39 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Regular Medium CA or Beacon's FoamTac work well. The CA is usable within minutes. FoamTac should sit overnight.
Prof100 is offline Find More Posts by Prof100
Old Apr 10, 2012, 11:11 PM
Joined Oct 2010
Cheers mate.
Old Apr 11, 2012, 01:04 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Another option
Prof100 gave you some excellent suggestions, IMO. I would just add that you could use double-sided scotch (cello?) tape to make it a bit easier to separate the fuselage if you ever need to do that.
AJ
Old Apr 11, 2012, 01:22 AM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
I agree. Double-sided tape is stronger than it looks (several crashes and it holds perfectly), and is easy to seperate with a craft knife.
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Apr 11, 2012, 02:15 AM
Javatango is offline
Find More Posts by Javatango
United States, WA, Auburn
Joined Dec 2011
Any problem with using double sided tape to attach the tail to the fuselage?
Javatango is offline Find More Posts by Javatango
Old Apr 11, 2012, 02:58 AM
Roblister is offline
Find More Posts by Roblister
North West UK
Joined Nov 2010
After what appears to be an eternity waiting for UK stocks of the Multiplex Easystar II RR to appear again, I have given up hope and opted to take the Sky Surfer route. In posting #2 of this thread item 4 links to BRC Hobbies as one of the UK vendors. A search of this thread suggests that they don't carry stocks of the Sky Surfer anymore. However, checking their website they seem to carry the latest ARTF and RR versions here http://brchobbies.com/?page=search&s...rch=sky+surfer Apologies if this is already known. I can't read all 958 pages today but did do a search.
Has anyone bought from them recently and know if it is the latest version.
Roblister is offline Find More Posts by Roblister
Old Apr 11, 2012, 03:34 AM
Joined Dec 2011
Blobs of UHU-POR for that!
(you can also try the removable stab mod - although I found the Factory version on my EZ a bit weak)
Old Apr 11, 2012, 03:37 AM
Joined Dec 2011
For the Sky Surfer, try the importer here: http://www.jperkinsdistribution.co.u...4&activepage=1
I have no idea what version it is, but the latest shipment arrived in Jan 2012 and is being sold by a lot of vendors. I'd email JPerkins direct though to check.
Old Apr 11, 2012, 04:08 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
AJ
Hey AJ I wish you had edited that vid. My iPad screen went black and I thought that the iPad had gone legs up. Blo*dy frightened me.
Nice landings.
Flypoppa is offline Find More Posts by Flypoppa
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
