Old Apr 09, 2012, 05:00 PM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
Originally Posted by NorCalMatCat View Post
Well what I did was use a dremel to adapt a standard 6x4e to the stock adapter (I have a v1 Bix), but I think I cannot balance it properly because of my dremeling it... I just can't get the vibes any better even after messing with it on bench trying to balance it out, and my AP freaks out anywhere above 50% throttle.
I did the same with the spare stock motor I had on my girlfriend's scratch plane. I thought I could teach her to fly a 4 channel but she kept nosing it hard and bent the shaft a number of times. Eventually I just cut the shaft to a half inch nub to help prevent it from bending. It's too long stock anyway. You might try shortening it a bit.
Dkumagai is offline Find More Posts by Dkumagai
Old Apr 09, 2012, 05:01 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by Dkumagai View Post
Sorry didn't see that AJ had already beat me to this. I surprised you're running an fpv setup on the stock motor, let alone the standard 5x5. A motor upgrade would probably be your best bet. If you wouldn't mind doing some modification I would go with a slower motor and larger pitchier prop for extra brute thrust for your fpv gear. But if you want to stay in the 6 inch range a 2200 kv with a 6x4 would be just fine. Personally I like my 2700 kv and 6x4 screamer setup .
I am using a 6x4 on stock motor, but I originally dremeled it to fit it to the stock adapter, which now that I am trying to get my AP to work it doesn't like the vibes, I don't think this prop can be balanced because of my dremelling.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 09, 2012, 05:53 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Help is around
My bet is that you are correct. Are you going to order a new prop adapter and prop? Oh, I still do not know if you have a brushless motor or a brushed motor. Hmmm. If you still need any help, there are several folks that will jump in to help out.
Update: I read some of your previous posts. You have a Bixler-Got it. That means you have a BL motor. What 2200kv motor were you looking at/romancing?
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 09, 2012, 05:55 PM
Joined Oct 2011
Brushless 1900kv
Old Apr 09, 2012, 05:57 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Brushless 1900kv
OK. What motor are you looking at? Did you read the motor stuff on Page #1?
AJ
Old Apr 09, 2012, 06:08 PM
dhyayi is offline
Find More Posts by dhyayi
Joined Jul 2011
Originally Posted by epyonxero View Post
I used these control horns. They come with screws.
http://www.amazon.com/gp/product/B00...00_i00_details
are they good enough?
dhyayi is offline Find More Posts by dhyayi
Reply With Quote  (Disabled)
Old Apr 09, 2012, 06:16 PM
Joined Oct 2011
AJ
I have looked, about to look again... probably going to do 2200kv with 6x4.
Old Apr 09, 2012, 06:55 PM
Dkumagai is offline
Joined Oct 2011
Sorry I misunderstood, I thought you dremeled the shaft. You're right IMO, the prop is a lost cause. It would be easiest to buy a new prop and adapter which you'll have to do anyway if you get a new motor. I hate to sound like a broken record, but I LOVE microdans. I have 3 now, and they're by far the best motors I've used.
Old Apr 09, 2012, 07:55 PM
overmyhead is online now
Find More Posts by overmyhead
United States, FL, Bradenton
Joined Jan 2012
Is there another plane just like a Bixler but smaller overall and scaled down?
overmyhead is online now Find More Posts by overmyhead
Old Apr 09, 2012, 08:07 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
There's a few similar ones. There's the AXN floater jet or clouds fly, 1200mm wingspan, hobbyking I know have a plane that looks similar but is 800 or 900mm wingspan.
sammyc is offline Find More Posts by sammyc
Old Apr 09, 2012, 08:13 PM
Joined Oct 2011
What is the shaft mm on stock bix 2620-1900kv motor?
Old Apr 09, 2012, 08:54 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
For me , i found a prop reamer tool to be pretty usefull,{because i am lazy}. If done properly, you should't have to balance it that much.
Limited flyer is offline Find More Posts by Limited flyer
Old Apr 10, 2012, 05:21 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Vector 850
http://www.rcgroups.com/forums/showthread.php?t=1599809
IFlyRCs is offline Find More Posts by IFlyRCs
Old Apr 10, 2012, 09:43 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
You want smaller? This is smaller. I have 4 of these and have RCed them.
http://www.totemhobbies.co.uk/produc...entawhite.aspx
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 10, 2012, 10:44 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Ok so it seems it is a loosing battle to get this 6x4 prop I have perfectly balanced, so what is a link to a 6x4 prop that FITS the stock Bixler prop saver?
Im using this prop here:
http://www.readymaderc.com/store/ind...products_id=85
I tightened it down on the stock shaft with the adapter ring that came with the prop and I havent had any problems.
EDIT: Now that I think of it I may have had to ream it out some.
epyonxero is offline Find More Posts by epyonxero
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
