Old Apr 04, 2012, 02:18 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by bgarber View Post
Hey Cat, question for ya... did you slice the through the top of the fuselage to get the ESC to that flat spot on top? (Is your ESC the thing in black with the red square on top?) What's the blue thingy; tape?
thanks,
Brian
Yes that is the ESC, and I did cut it down to fit. I am not sure which blue thing you refer to, the velcro piece for the canopy?
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 04, 2012, 02:20 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by Eagle202 View Post
Getting insurance makes sense and I will be looking into it here in the US.
How did you find an insurance agency that would provide you with that type of coverage?
I didn't. It comes with the membership of the FPVUK.ORG group. The groups heads organised it.
Flypoppa is offline Find More Posts by Flypoppa
Old Apr 04, 2012, 03:23 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Someone was thinking ahead. Thanks for the info.
Eagle202 is offline Find More Posts by Eagle202
Old Apr 04, 2012, 03:37 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by NorCalMatCat View Post
Ok major airframe repairs are complete, <snip>
Where did you get the LG? I like it. Do you have a link, maybe? TIA
AJ
ajbaker is offline Find More Posts by ajbaker
Old Apr 04, 2012, 04:17 PM
Joined Oct 2011
AJ
And of course some sort of axle and collars to attach the wheels would be required.
It's a good LG setup, though a bit heavy but only because I wanted good ruggedness, and they are! Tail wheel requires a little bit of work to attach it well.
Old Apr 04, 2012, 04:46 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Thank You. I do a lot of business with HK and I would have never thought of searching for "strut". Both of my Sky Surfer's will be very happy.
AJ
Old Apr 04, 2012, 05:18 PM
Joined Oct 2011
AJ
Rememberit is a 2 piece LG, so you will need to make a good mounting method, personally I just used pop sicle sticks, as a matter of fact...
Original LG build log Part 1
Original LG build log Part 2
Just consider in my original build I had them a little too far back for good balance, they need to be a little forward of the leading edge, otherwise nosing it on take-offs becomes an issue.
Old Apr 04, 2012, 10:51 PM
wilem is offline
Find More Posts by wilem
airplanes r made from aluminum
wilem's Avatar
United States, SC, Darlington
Joined Jul 2009
Originally Posted by road_rascal View Post
I just put together my 3rd Sky Surfer, this time with flaps (going to be my GoPro camera ship) and I put in a HeadsUpRC 2200kv inrunner. Now HeadsUp must have discontinued that motor because I don't see it on their site, only an Emax 2450kv inrunner. For those who have used the previous 2200kv inrunner from HeadsUp what prop are you using? Right now with a 3s2200mAh 30c lipo and an EMP 6x4 prop I' m showing around 210w at 17A with my watt meter. Maiden on this bird should be tomorrow or the next day.
i am using a 6x5 on a rctimer motor http://www.rctimer.com/index.php?gOo...6&productname= and it puls 30 amps at wide open climb out on take off. BUT is really goes well. the park 450 with a cut down 8x8 was only pulling 11 amps and was anemic. i was thinking of trying a 6x4 tomorrow see if i can get the current down some. or maybe drop back to a 2 cell.
wilem is offline Find More Posts by wilem
Old Apr 05, 2012, 12:16 AM
limafilho is offline
Find More Posts by limafilho
Brazil, PR, Curitiba
Joined Jul 2011
this landing gear
http://www.hobbyking.com/hobbyking/s...5cc_size_.html
can fit on bixler aircraft?!
limafilho is offline Find More Posts by limafilho
Old Apr 05, 2012, 02:18 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Options
Originally Posted by limafilho View Post
this landing gear
If you mean can it be "custom" fit to the Bixler, then, most likely, Yes. However, you might want to consider a few posts up by NorCalMatCat. I really like the pictures of how he adapted the LG to his plane. The LG (struts) are a lot cheaper, too. I am going to order them for my planes. Take a look.
AJ
Old Apr 05, 2012, 06:49 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
It's going to be sitting very high off the ground. Takeoffs will be interesting at an angle of attack of 20+ degrees.
The landing gear made by airscapeRC (who seem to have stopped selling it) shows you the sort of geometry that works. Would be what I would aim for on a home made as well.
Takes off like a dream on my Bixler. It is adjustable fore and aft to optimize for bounce on landing.
this landing gear
jj604 is online now Find More Posts by jj604
Old Apr 05, 2012, 11:25 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Cost is a factor
It looks nice. But, IIRC, at $35, it costs almost as much as the whole plane. IMO, he is way overpriced. There are many other options that are just as effective and much cheaper.
AJ
Old Apr 05, 2012, 11:52 AM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
It's thier money aj, i think they can spend it how the like.
Limited flyer is offline Find More Posts by Limited flyer
Old Apr 05, 2012, 12:15 PM
bgarber is offline
Find More Posts by bgarber
United States, OH, Dayton
Joined Feb 2012
Yeah, I think I saw in the other picture that it is velcro.
Thanks!
bgarber is offline Find More Posts by bgarber
Old Apr 05, 2012, 02:34 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ said it was his opinion. Do you have an alternative that's more practical?
At $18, the Mini Ultrastick gear set could be an option.
Prof100 is offline Find More Posts by Prof100
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
