Old Mar 19, 2012, 06:10 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
I have been trying very hard to get my bixler to tip stall, but won't do it. My other planes have terrible tip stall tendancies, my dynam catalina and starmax MX2.
I think maybe people having tip stall tendancies may have one/both warped wing with incorrect washout, this is not uncommon with these foamies, which will bend and warp in heat and with pressure eg laying one wing against something for a long period of time. And quality control in the factories aren't high either, so may be like it from new.
sammyc is offline Find More Posts by sammyc
Old Mar 19, 2012, 06:11 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Don't forget weight, I was flying FPV, she was nearly twice as heavy as stock, with vTX, camera, antenna etc all on the fuse, this alone will add to the willingness of it to tip stall too.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 19, 2012, 06:14 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
I would expect weight to only effect the speed of stall, not change tip stall tendencies. Unless the weight isn't balanced, one heavy wing will be bad
Old Mar 19, 2012, 06:16 PM
Joined Oct 2011
Well it's weight above and below CG, I also had 109 grams of landing gear sticking a good 6 inches below the airframe as well. I don't think any of these things by themselves are going to guarantee a tip stall, but I would say the combination makes it more possible.
Old Mar 19, 2012, 06:22 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Ah yes, true true
Old Mar 19, 2012, 06:31 PM
Joined Oct 2011
Ah yes, true true
And it took a flair from a stall recovery even then for mine to do it rofl, I have never noticed a tip stall tendency in normal flight.
Old Mar 19, 2012, 06:49 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
To keep the discussion going that would mean a slight waste in lift?
I would say any lift is good lift
jrjr is offline Find More Posts by jrjr
Old Mar 19, 2012, 07:10 PM
Simon2504 is offline
Find More Posts by Simon2504
United Kingdom, England, Ripon
Joined Dec 2011
Playing around with some props over the weekend I think ive found my preferred prop for the Bix, after watching the video's the difference in props really shows, I was using the APC 6x4 but the MasterAirscrew 5.5x4.5 was so much better, a lot smoother and less noise (before anyone says it.....they are both balanced exactly the same) first half MasterAirscrew second, half APC
prop test (2 min 2 sec)
Simon2504 is offline Find More Posts by Simon2504
Old Mar 19, 2012, 09:42 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
For those using the turnigy D2826 2200kV motor, what timing did you find works best? I have a 30A plush ESC and 6x4 or 6x3 prop.
Old Mar 20, 2012, 01:58 AM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by Simon2504 View Post
Playing around with some props over the weekend I think ive found my preferred prop for the Bix, after watching the video's the difference in props really shows, I was using the APC 6x4 but the MasterAirscrew 5.5x4.5 was so much better, a lot smoother and less noise (before anyone says it.....they are both balanced exactly the same) first half APC second, half MasterAirscrew
http://youtu.be/kiXa5HT_TwQ
You running the stock motor with that 5.5x4.5 prop? Where did you buy it?
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Mar 20, 2012, 03:45 AM
mandevil is offline
Find More Posts by mandevil
mandevil's Avatar
Joined Jun 2011
Playing around with some props over the weekend I think ive found my preferred prop for the Bix, after watching the video's the difference in props really shows, I was using the APC 6x4 but the MasterAirscrew 5.5x4.5 was so much better.
Hm, that looks interesting. Looks like it goes into my next Hobby King order :-)
mandevil is offline Find More Posts by mandevil
Old Mar 20, 2012, 03:46 AM
mandevil is offline
mandevil's Avatar
Joined Jun 2011
It's available, for example, here.
Old Mar 20, 2012, 04:27 AM
Joined Dec 2011
Yes that was with stock motor and mine came from hobbyking
Old Mar 20, 2012, 07:39 AM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Rebuilt my bixler tonight, new Turnigy D2826 2200kV motor, 6x3E prop (for now), 30A Turnigy Plush ESC, Turnigy UBEC, frsky rx and tx module in my 9X transmitter.
Ill be test flying with new setup and trimming, then re-adding my FPV stuff
Old Mar 20, 2012, 08:30 AM
taz101 is offline
Find More Posts by taz101
taz101's Avatar
Australia, QLD, Gold Coast
Joined Oct 2010
AJ,
Might be time to update the thread name. Have you seen the new LRP Upstream F-1400.
Looks familiar!!
LURCH.
taz101 is offline Find More Posts by taz101
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
