Old Mar 15, 2012, 12:32 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Originally Posted by ajbaker View Post
While interesting, this has nothing to do with the SkyS/Bix. In a fast moving thread like this one, using almost a whole page of OT is not good for the health of the thread. Please start another thread addressing this subject. I, for one, would like to know more about this topic, too.
AJ
I was only asking if anyone has ever done it before was all, and i totally disagree with you,everybody uses a prop on a skys/ bixler,right
Limited flyer is offline Find More Posts by Limited flyer
Old Mar 15, 2012, 01:44 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Re: Hinge Gluing
I've seen mention of oiling the pin to prevent CA from sticking.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Mar 15, 2012, 02:19 PM
Limited flyer
Joined Dec 2011
I use fibre tape,BUT,if you live in a cold area,try using medical tape that is made from a thin cloth like substance,that way it is less prone to getting stiff in colder temps,so there would be no need for oil if you go that rout.
Last edited by Limited flyer; Mar 15, 2012 at 04:01 PM. Reason: wrong advice first time
Old Mar 15, 2012, 04:08 PM
Limited flyer
Joined Dec 2011
Hey AJ,Imay have started the the ot, you can't blame me for getting answers i never asked the questions for, I only asked about the prop.
Old Mar 15, 2012, 06:30 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Give just those choices, CA should be avoided totally because it has a very nasty habit of "wicking" directly into the hinge pivot point and making the hinge inoperable. So, #2 and #3 are not worth considering. #1 can also expand and wick into the hinge also. Therefore, by process of elimination, #4 would be the only choice left. However, I suggest that you drill a 1/16" hole through the front and back of the hinge and push a round toothpick through the hole and use a speck of hot glue to hold the toothpick in place (after cutting off the toothpick, of course). Another option is to not use the hinges you mentioned at all and use 3M Extreme tape to fashion your own hinge. The tape method is what most of use for a number of reasons.
AJ
One thing nice about using MEDIUM ca is it doesn't "run" into an area you don't want it to, if used sparingly. Ca hinges work very well also.
Now, no more toothpick talk,... that's as off topic as prop talk.
2500GENE is offline Find More Posts by 2500GENE
Old Mar 15, 2012, 06:37 PM
AshtonFlyer is offline
Find More Posts by AshtonFlyer
AshtonFlyer's Avatar
United Kingdom, England, Bristol
Joined Dec 2011
Been watching this debate for a bit - nobody's mentioned UHU-POR yet..
Cut the hinge opening, insert tweezers (or a toothpick!), drip a drop of UHU, slip your hinge in (ooerr missus) and voila.
I regard UHU as non-gun hot glue - much simpler to apply, but a bit more fluid.
AshtonFlyer is offline Find More Posts by AshtonFlyer
Old Mar 15, 2012, 06:41 PM
Limited flyer
Joined Dec 2011
Since when s prop talk off topic??
Old Mar 15, 2012, 08:07 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
servos,horns mounting method
Hiya folks,
Sorry for asking this maybe-already-has-been-asked-before question:
Im going to start my build (HK Bixler)...so..what good/best method to mount the servos & horns so that its serviceable. Thx.
CPMBOY is offline Find More Posts by CPMBOY
Old Mar 15, 2012, 08:30 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by CPMBOY View Post
Hiya folks,
Low to medium temp hot glue.
Prof100 is offline Find More Posts by Prof100
Old Mar 15, 2012, 11:22 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
More thoughts on Sky Surfer Hinges
Originally Posted by geotete View Post
Thanks for your answer!
My selection is what I have on hand, and I also have the epoxy but didn't mention, because I think that will not bond great with the 2 materials.
I was following tip:
"29. Replace the foam hinges with larger hinges if you want to really make them work well. HERE are the hinges I recommend (3 on each aileron)."
from the 1st page! So should I ignore this tip?
All the Best,
Geotete
No. Ultimately, there are many "right" answers to the hinge question.. It is a question of what works best for you. Again, the most popular method that is used is the "tape" hinge. Even that has many different methods and types of tape to use. The #29 that you refer to is the method that I use simply because it gives the least amount of resistance to the aileron movement (rudder and elevator, too). Each method has pros and cons. Whichever one you decide, please post the pics of your build. It is always neat to see each persons methodology.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 15, 2012, 11:23 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Prop variables.
Prop talk isn't OT. The method you suggested is way off topic as it doesn't even exist yet for our applications. I consider only those things that are within reach of the average hobbyist to be relavent and worthy of discussion. Besides, considering how fast thread moves, anything that is NOT directly applicable to the SkyS/Bixler is generally OT IMO.
AJ
Old Mar 15, 2012, 11:25 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
Stereolithography is way off topic.
Old Mar 15, 2012, 11:30 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Another suggestion
Hiya folks,
CA for the horns and hot glue for the servos. However, there is nothing wrong with hot glue for both (since you already have it heated up.)
AJ
Old Mar 16, 2012, 12:55 AM
Limited flyer
Joined Dec 2011
AJ
What ever.Did you see the link olthump left,they made a whole plain like that,Idon;t think a prop is out of the realm of impossibility.
Old Mar 16, 2012, 07:21 AM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
AJ
ok..we glue them...how to take them out in case of replacing them?...
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
