Old Jan 30, 2012, 07:59 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by planex View Post
Is there a write up somewhere on how to install flaps?
Just a matter of duplicating how the ailerons are setup on the plane, only embed the servos the same way so they both go in the same direction and not opposite on a Y harness, or if you have a radio that can do it you could put them on seperate channels and mix with ailerons to make true flapperons (flaps act as ailerons when set to do so).
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jan 30, 2012, 08:00 PM
Eagle202 is offline
Find More Posts by Eagle202
Eagle202's Avatar
United States, FL, Clearwater
Joined Aug 2011
Originally Posted by sammyc View Post
My flying on the beach:
http://youtu.be/V0QEFzp469w
Man that looks like a great place to fly. When you get tired you can camp, go surfing, boating or swim. Can't complain about that.
That was also some very impressive low level flying. Looks like at one point you were trying to surf a wave.
Vince
Eagle202 is offline Find More Posts by Eagle202
Old Jan 30, 2012, 08:13 PM
HiFlyer371 is offline
Find More Posts by HiFlyer371
Bill
HiFlyer371's Avatar
United States, NE, La Vista
Joined Jul 2007
Tough Plane!
I ran my Bixler into a goal post today.
Very little damage and a little hot water and some Gorilla Glue fixed it right up.
There is a video of the impact on the Bixler FPV thread.
Will be in the air tomorrow!
HiFlyer371 is offline Find More Posts by HiFlyer371
Old Jan 30, 2012, 08:14 PM
sammyc is offline
Find More Posts by sammyc
I need a bigger shed..
sammyc's Avatar
Australia, TAS, Launceston
Joined Nov 2011
Vince
Cheers, It's not called a sky surfer for nothing hehe
sammyc is offline Find More Posts by sammyc
Old Jan 30, 2012, 08:28 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Sounds fun to say,{reverse thrust},it would not be the same as a variable prop, but then again, you guys know that right.Now correct me if i am wrong but I am pretty sure that no one makes a prop capable of producing thrust in both forward and backwards moving motors{NOW WE ARE TALKING ONE PROP FOR BOTH DIRECTIONS RIGHT{sorry not yelling}
Limited flyer is offline Find More Posts by Limited flyer
Old Jan 30, 2012, 08:33 PM
Joined Oct 2011
Spinning a prop backwards would not produce very good thrust, but thrust it would produce none the less, and considering the efficiency loss of spinning it backwards, backwards flying you will probably not do, but air breaking it will do fine .
Old Jan 30, 2012, 08:56 PM
sammyc is offline
sammyc's Avatar
Joined Nov 2011
Yet spinning it backwards still gives enough thrust to fly... I have carelessly put prop on backwards once, was wondering why it was lacking in performace. But still flew
Spinning backwards would provide heaps to slow down VERY quickly I imagine. I doubt there would be much control, and it would pitch up rapidly. Would be awesome to try, get into a big dive and crank it backwards!
Old Jan 30, 2012, 09:19 PM
Limited flyer
Joined Dec 2011
I agree with both of you,still, just saying.
Old Jan 30, 2012, 09:38 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Here you go, a video of flaps installed on a Skysurfer. I can also operate the flaps without the spoilerons although it is not shown.
Skysurfer with flaps and spoilerons (0 min 53 sec)
Prof100 is online now Find More Posts by Prof100
Old Jan 30, 2012, 09:56 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Well it's easy enough to try. Just replace the ESC with a boat one that has forward and reverse - and make sure the prop is on real tight.
jj604 is offline Find More Posts by jj604
Old Jan 30, 2012, 11:13 PM
Weekend Flyer is offline
Find More Posts by Weekend Flyer
i Like RC
Weekend Flyer's Avatar
Manitoba, Canada
Joined Oct 2010
InRunner 2200 KV or 2700 KV ?
My first plane was a SkySurfer and it flew very well with a HobbyKing InRunner HXT B2835 2200 KV and 6 x 4 Prop with 40A ESC. I'm building my second plane, a Bixler. I'm thinking of using the same motor but the 2700 KV version. Does anyone know if the 2700 KV is a worthwhile improvement? I plan on making the necessary mods to reinforce the wings etc.
Weekend Flyer is offline Find More Posts by Weekend Flyer
Old Jan 30, 2012, 11:14 PM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
Here's a short video of my new sky surfer's maiden. My girlfriend needs a little practice filming moving objects . I've only been flying for 3 months, so be nice lol.
Sky Surfer Maiden Flight in Seattle (2 min 4 sec)
Dkumagai is offline Find More Posts by Dkumagai
Old Jan 30, 2012, 11:47 PM
Hayabusa Heli is offline
Find More Posts by Hayabusa Heli
Heli Mania
Hayabusa Heli's Avatar
PNW
Joined Dec 2010
Originally Posted by Dkumagai View Post
Let's run some numbers. Suppose you have a 6x4 with the standard motor, which probably only spins at around 16k rpm at full throttle. This gives us 16000 rpm x 4 in x 60 min = 3840000 in/HR. 3.84 mil/12/5280 ≈ 60MPH theoretically. Factor in drag and you probably get significantly less than that.
Sorry for the noob question, but when they specify a prop as "6x4" does that mean it's 6 inches in diameter, and theoretically moves forward 4 inches for every revolution (due to the pitch)? Based on you calculation above, that seems to be the case.
Hayabusa Heli is offline Find More Posts by Hayabusa Heli
Old Jan 31, 2012, 12:40 AM
Dkumagai is offline
Joined Oct 2011
That's correct. The first number is diameter and the second is pitch per revolution.
Old Jan 31, 2012, 12:46 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Motor suggestions
I have used all three 2835's (220, 2700, 3900). IMO the best bang for the buck is the 2200Kv. The 2700 makes more noise but is not that big an improvement in speed and performance. If you have (or want to save up the bucks) for a 2505-2835 MicroDan motor, That is a fabulous motor that you will use over and over again in many planes. For about 1/2 that price, you can get the same performance from a Grayson MicroJet V2. But, it is a full ounce more in weight than the MD. Have fun and let us know what you decide.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
