Old Dec 09, 2011, 09:20 PM
Limited flyer is offline
Find More Posts by Limited flyer
Limited flyer
Limited flyer's Avatar
Joined Dec 2011
Originally Posted by 2500GENE View Post
Just copy and paste the link from here and it will show up.
CA works fine on this type foam. I have had several EZ Stars and SkyS planes over the years and never had to cut one open. If I HAD to I still could and just use ca to glue it back. CA is brittle in some applications like mounting motors but works well in joining the fuse. Glue that expands like Gorilla glue has a tendency to "push" the joint open as it cures. You could actually just tape the fuse together and it'll would just fine. Don't over think this. Get it together and get it in the air. If you are new at this then chances are you will smash the crap out of the plane learning to fly and get a new fuse anyway before wanting to open it up for something. Do what you feel is best with any advise given. There are many fine ways to do it.
Oh, also...ca is what Multiplex recommends to glue the EZ together. Been working fine for years.
This is my second bix that i am know flying, crashed the first one beyond repair, have another in the box{the third one} going to practice my inverted, rolls and loops on this one, and damage will happen learning this stuff,{will not be satisfied untill i can do inverted 5 feet off the deck},but any who, So you think ca is the answer, gonna fly the third one stock for a while, but planto get a beefier motor for it,hence the glue question.
Limited flyer is offline Find More Posts by Limited flyer
Old Dec 09, 2011, 09:34 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Best of luck to you. CA will hold the fuse and tail with whatever motor you throw at it. For the motor use something more flexible like a poly based glue or fake silicone. (real silicone will melt the foam some then harden up).
Get to handle the plane real good in normal flight until you are bored to tears before going inverted 5ft off the deck. Do your inverts high at first and start to bring them down. Your plane may last longer this way.
Best off luck.
2500GENE is offline Find More Posts by 2500GENE
Old Dec 09, 2011, 10:33 PM
Limited flyer
Joined Dec 2011
Get to handle the plane real good in normal until you are bored to tears before going inverted 5ft off the deck. Do your inverts high at first and start to bring them down. Your plane may last longer this way.
Best off luck.
I suppose i should have mentioned that i have been practicing this at altitude already.Sorry
Old Dec 09, 2011, 11:39 PM
AVIATION_RULZ is offline
Find More Posts by AVIATION_RULZ
Canada, BC, Surrey
Joined Feb 2011
Originally Posted by Little-Acorn View Post
I haven't measured power on mine. But that Turnigy 2835-3900KV that I mentioned earlier, turns 21,100 RPM on the bench with a 11.1V, 2200mAh GensAce LiPo battery, a 40A ESC, and a three-blade Master Airscrew 6x4 prop.
And with that combination, it will climb straight up out of sight.
I'm pretty sure it's drawing more than 183W while it's doing it.
OTOH when I treat it more gently, I've gotten a 26-minute flight on it without running out of battery, and doing some slow climbs and a few stunts.
If you could do me a favour and please do a bench test.... maybe find out how many watts its pulling? Thanks mate!
AVIATION_RULZ is offline Find More Posts by AVIATION_RULZ
Old Dec 10, 2011, 02:03 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
I'll bet it isn't 705W!
Gord
Gordks is offline Find More Posts by Gordks
Old Dec 10, 2011, 10:24 AM
NickBee is offline
Find More Posts by NickBee
Flanders, NJ USA
Joined Jan 2001
Hey guys.
I am planning to maiden tomorrow but I am having cg issues. I guess the micro Dan outruner with mount puts the motor a bit rearward and my plane is tail heavy at the recommended cg of 60 mm. I am using a 2100 mah pack as far up as it will go. Since swapping out batteries is not an option for tomorrows flight I am going to add some lead to the nose ( original weight was removed).
So my question is should I stick to a cg of 60mm? Or can I push that back a bit so I have to add less lead for now.
Thanks!
NickBee is offline Find More Posts by NickBee
Old Dec 10, 2011, 10:33 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by doomracing View Post
well it really comes down to this IMHO.
1) strengthen the carbon rod. that's a no brainier.
2) do one of the mods to keep the wings plugged onto each other. really doesn't matter witch, or who thought of it. JUST DO IT!
3) put a carbon rod down the fuse to make it rigid. my bixler has the groove for it, but didn't come with the rod. WHY???!!!
4) replace the hardware. cheesy clevises. i prefer connecting rod anchors. that's not the proper name for them, but they are the connector that lets the rod go threw them, and locks them in place with a screw.
there are probably other mods that should be done, but these 4 are IMHO the 4 biggest gotta do mods. if there are other gotta do's please let me know.
The groove down the middle in the Bixler (aka Skysurfer V1) was for the 72 mhz antenna. Now all the radios are 2.4 ghz. It was never intended for a carbon fiber tube. Although, it is mighty nice of them to mold in the slot.
Prof100 is offline Find More Posts by Prof100
Old Dec 10, 2011, 10:48 AM
Fugitive_Bill is offline
Find More Posts by Fugitive_Bill
CURIOSITY Has Landed!
Fugitive_Bill's Avatar
Sydney, Australia
Joined Jul 2005
Nick,
On a maiden I'd be trying to have the CoG as close to where it should be, you want it to be as stable as possible even if it means being heavier.
But of course it all depends on your skill level.
I'd much prefer the extra overall weight than to being tail heavy.
I've not flown my Bixler yet, heck I've hardly even began the build, as I'm one of those who have 10 projects going at once!
BTW: Before StarHopper jumps down my throat, that's just 'In My Humble Opinion'.
-B!LL!
Fugitive_Bill is offline Find More Posts by Fugitive_Bill
Old Dec 10, 2011, 11:01 AM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Ted said it's for a xx antenna.
Old Dec 10, 2011, 11:49 AM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Correction
That actually should be an XXX transmitter antenna. Supposedly for remote operation of my alleged 'shine still of which I know absolutely nothing about.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Dec 10, 2011, 12:00 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
At what throttle setting for the 21000 rpm?
Full.
I'm starting to wonder if that is really a 3900kv motor or the manufacture is rating it overly optimistic.
Well, I don't have enough info to predict, since I've never full-throttled it with no prop or prop adapter mounted. Not sure how I'd measure the RPM if I did, since my tach is an optical one that works from the light flashing on the prop blades (or a flat spot on a flywheel I'd suppose).
Why do you feel the rating is overly optimistic?
Little-Acorn is offline Find More Posts by Little-Acorn
Old Dec 10, 2011, 01:12 PM
San Diego, CA
Joined Dec 2006
Gord
70 amps thru a 40A ESC with a 2200 3s 25C LiPo, I wish!
I'll try to test it. Time to get out that WattsUpMeter I've been using on E-bikes.
Old Dec 10, 2011, 03:03 PM
Limited flyer
Joined Dec 2011
Bought some foam tac yesterday, it seems i have tempted the rc gods one again.Went out for a fly this morn, botched a chuck and my bird splashed on the snowy hard ground,never did have to glue the spar covers in untill today,got home and got that repair done, went out again tried a powered take off from the snow, all was going well{did i mention that the wind picked up 24kph} untill i banked left, and mother nature said not today ron, a gust batted my plane back down to earth, as a result, got a nice big tare right underneath aft of the canopy. gonna find out how good this foam tac really is.Was in a rush to fix it{i'm a freak like that},so did not think of taking before and after pics,if any one wants pics of it fixed, be more than happy to oblige.BTW used dabs of hot glue for spar covers, foam tac for crack
Old Dec 10, 2011, 03:06 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Originally Posted by NickBee View Post
Hey guys.
Thanks!
Set your CG to 65mm (which will be fine) and you will need a lot less nose weight.
ozair is offline Find More Posts by ozair
Old Dec 10, 2011, 03:22 PM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Ted
Come on Ted, your not letting Gene get to ya.
As for the so called "alleged 'shine still of which you know absolutely nothing about" sure, pull the other one it plays tunes
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
