jrjr
While i had full intention of installing the 4 mm rod i got delayed. One of my flying buddies mentioned using a metal tube or stranded wire instead since he had performed the 4 mm rod modification and they both broke after a drastic pull out from a loop. I just read about a similar mishap on the Blixer FPV thread were both rods broke when guy1a's plane his a water sprinkler. I let him know I had installed a 5 stranded #20 awg wire rod into my 6 mm rod. Made it myself by folding a longer piece of wire 4 times and then twisting the the bundle a couple times. Then wrapped the spare length of wire at both ends to keep the stranded bundle together. While i haven't put it to the true test the idea is that if the 6 mm rod breaks the stranded wire inside will not allow the wings to fold (flap maybe ) but maintain some rigidity so the plane could be safely landed instead of nose dive.![]() I will get back to everyone to let them know if this "mod" really works or not. Vince |
Singapore, Singapore
Joined Nov 2011
Just realised that my charger doesn't come with leads... Time to shop for some deans plugs and heat shrink tubing as well... |
Joined Nov 2011
I saw the flipping wings video, I never would have thought that the spar can split like that. Maybe someone should tell the flitetest crew about it since it's a product that they stand behind and they never mentioned it as a problem. To be honest, I'm starting to feel that the Skysurfer might not be the best first plane a total beginner can get. Without checking out this thread, I might be in for a tough maiden or end up with broken wings. Maybe this hobby needs more foolproof begnner rtfs other than the parkzone offerings. I'm just thankful that I like to learn about the technical stuff that goes into electrical rc planes. |
It's a fine beginners design if properly manufactured. Then it's called the Multiplex EasyStar.
Seriously, it's a shame that in the race to bring the price down, they cut just a couple too many corners. The shoddy spar and the flimsy control horns being the two obvious ones. The rest are probably not a real problem, provided all the servos do work when you try them. Quote:
Paul |
Joined May 2011
My son learned to fly RC with this plane without any of these mobs, it is a great 1st plane. Granted once he got to where he could fly eights in a tight pattern I had to put some rubber bands on the wings. By that time they where moving around quite a bit.
If you plan on doing acrobats and speed flying, yes you will need to do these mods; spar and wing attachment mods at the very least. |
They clamed that they had a problem assembling it after a month time. So the Russian expert goes there to check things out. - We tried to assemble the tractor a number of times but it always came out to be a tank. - OK! Did you read the instruction? - Yes every time we strictly follow the instruction. - Well, you always do not read to the very end. See what it sais here in the very last line: ‘Finish it up with a rough file after assembly’ |
It's disgusting, really. If they're gonna cut corners to keep the price down, why on something that costs mere pennies, anyway? It just doesn't make sense to so cheapen products that they crow about being so proud they designed and built. No sense at all!
Well said. My thoughts EXACTLY. It's beyond why they do it.
Wish there was a way of finding someone along the production line to explain why they do it. Almost all of my Phoenix's clevises were already broken or broke when I tried to adjust them. Needless to say I have 100 of various sizes to replace the crap ones that too many planes come with. -B!LL! |
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
