Old Nov 10, 2011, 03:41 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by StarHopper44;
I'm figgerin', if enough of us band together & get gyros, at sale prices, we can save up enough money to send FlyPoppa a really tricked-out hella heli for Christmas....and let's see how he feels about flyin' without gyros then!
Hey sissy, if you were to kindly send me a Hella hele, I would not open the box and put it on EBay.
I don't like helis. Maybe it's because I can't fly them.
Flypoppa is offline Find More Posts by Flypoppa
Old Nov 10, 2011, 03:44 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by Eagle202 View Post
I need some help finding the correct 4 mm wing spar to fit into the 6 mm that came with my SS from BH.
BH only has the 6mm replacement. HK's are backordered, Headsup does not carry them in any size (at least i could not find any on their website), Towers has (if i do the conversion from Eng to Met correctly) a 3mm & 5mm but no 4mm. Hobby lobby has 3 types which I presume are 4mm OD with a 2.0, 2.5 or 3.0mm ID x 1000mm length.
Do I wait for HK or should I get a couple from H lobby and which one if I do?
Vince
I'll go ya one better. AFA replacing the 6mm original, I wouldn't want theirs. In my crash (which wasn't very hard), that one splintered in about 6 places right dead in the middle, & the glue holding my 4mm insert broke it completely free, while it emerged unscathed. Saying that, I'd look for a 6mm with thicker wall, which would mean our 'normal' 4mm insert might not fit inside. Shop around, note the ID of the 6mm outer, & select an inner rod with an OD that'll fit. Makes finding a bit more iffy, but do whatcha can. Keep in mind you might have to go with inch sizes instead of metric. (Not that there's anything wrong with that!)
Meanwhile, here's a couple places you might check out:
http://www.goodwinds.com/merch/list.shtml?cat=carbon <> Browse around in their Closeouts section for possible bargains: http://www.goodwinds.com/goodwinds/m...l?cat=specials
http://www.troybuiltmodels.com/categ...par-Tubes.html
http://www.rcfoam.com/index.php?cPat...44647c4d4f7537
http://www3.towerhobbies.com/cgi-bin...tube&search=Go
& here's a GoogList of sources:
http://www.google.com/products/catal...=0CKwBEPMCMA0#
Good luck!
StarHopper44 is offline Find More Posts by StarHopper44
Old Nov 10, 2011, 03:58 AM
Earthbound Skyhound
Joined Jun 2011
My guess is, more'n likely ya prolly couldn't figger out how to open the box, either.
Old Nov 10, 2011, 04:18 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Vince
This is the tube I used inside the 6mm wing spar to reinforce it:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKAE9
Good luck!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Nov 10, 2011, 08:53 AM
Earthbound Skyhound
Joined Jun 2011
Hey guys;
I'm attempting to run some efficiency graphs on the stock 2620-1900 motor. Some of the input data I used are questionable, so let me ask: Here's the info requested:
Enter Kv <> got that, at 1900
Enter Io* [?]
Enter Rm** [?]
Enter Voltage 11.1 -?-Presuming this refers to the battery rating??
Enter Weight*** (g)
*Io = Noload Current of the Motor, derived from running a motor WOT without a prop at varying voltages. Io can be expressed with an associated Voltage and should be. [Presuming this represented by next input line, 'Enter Voltage']
**Rm = Resistance value of the motor, derived from the guage of wire used
*** 'Weight' would logically seem to be the AUW of the plane - I've used 700g as an average with 2200mAh LiPo. The reason I question here is, I've seen some notes (thread related to this tool's use) indicating this is the weight of the motor. I don't see how that could be applicable in calculating 'efficiency', unless it's figuring in a load compensator for spinning the outrunner casing, which this tool isn't dedicated to figuring, so....????? Thoughts?
Here's the tool URL if you want to give it a run:
http://www.peakeff.com/GraphKIR.aspx...=test2620-1900
And here's the initial input figures I used just to try it out:
Enter Kv 1900
Enter Io 0.5 [?]
Enter Rm 0.5 [?]
Enter Voltage 11.1
Enter Weight (g) 700
---And, selected 'Show APC Props'
Results indicate some interesting propositions for other-than 5x3 & 6x4 props!
I want to get more accurate input for the Io & Rm - but the above numbers produced theoretical (graphed) speed pretty close to what I clocked the Bix at on radar.
Anybody know 'righteous' numbers for this? Thoughts?
TIA!
Old Nov 10, 2011, 09:11 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Nah. No problem there as SHE normaly gets there first to see 'What have you bought now'.
As for helos... When my foam models get damaged (which is not very often) it normaly is a quick fix, even on the field.
I have seen some very expensive Helos bite the dust, and the bits go into a plastic bag as a bin job.
Old Nov 10, 2011, 12:26 PM
Arck is offline
Find More Posts by Arck
I land with enthusiasm
Arck's Avatar
Lima-Peru
Joined Aug 2004
Originally Posted by Jam1e View Post
+1
I agree with Acorn. I've got the Turnigy 2835-3900KV in my Bixler and it's a great motor and is a perfect match for a 2200 3s 25c lipo and in my case a 45amp ESC. Easy hand launchs great verticals!
HI Jam1e, could you please tell me how you install the Turnigy 2835-3900KV, the stock motor is an outrunner I think, and the other is an inrunner,,,,,,
Im flying my Bixler with the stock motor and 6x4 APC, but due Im entering into FPV, more power is a must? should I need to separate the frames of the plane?
Please Help me,,,,
thanks
werner
Arck is offline Find More Posts by Arck
Old Nov 10, 2011, 12:33 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
3900kv... Power mad. For goodness sake the model is a glider. I replaced the stock with a 1800kv 20amp ESC, 6x4 prop, and stick a 2200 3s in the nose.
It will do a SOGATO. It will also go vertical for a while and gets me to a gliding height of about 400 ft in about 20 seconds.
I then glide around thermal hunting or glide back down and then power up for height yet again.
As for the duration of my flying times... I have yet to run the 2200 3s down in my flights.
Also no gyros are harmed in my flying as I don't use them.
+1 on the motor. But I might be trying gyros just for fun.
Gord
Gordks is offline Find More Posts by Gordks
Old Nov 10, 2011, 01:01 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Hey guys;
Enter Io* [?]
Enter Rm** [?]
Enter Weight*** (g)
Enter Kv 1900
Enter Io 0.5 [?]
Enter Rm 0.5 [?]
Enter Voltage 11.1
TIA!
SH read page 1 (motor specs) you will see that
No load current is quoted as 1.5A at 11.1V and
Internal resistance is 0.04 Ohms
Come on man, Flypoppa will be laughing his head off
ozair is offline Find More Posts by ozair
Old Nov 10, 2011, 01:02 PM
Gordks is offline
Joined Mar 2010
Don't ever try a heli! Not even one of those cheap ifra-red controlled counter rotating things. They are addictive. I made that mistake and now I have a Blade MSR (fixed pitch), and and an MCPx (collective pitch) and am just waiting until the MSRx (flybarless MSR) is available so I can get one of those. The MSRs are great for the winter in the living room. Flybarless is more controllable. Collective pitch allows inverted flight but is more suited to outdoor use due to much higher rotor speed.
Fair warning. Don't do it!
Gord
Old Nov 10, 2011, 01:06 PM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Please Help me,,,,
thanks
werner
Werner also have a read of post # 4722
Old Nov 10, 2011, 02:25 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Gord
Too late Gord. I already have a couple of those IR little ones that were bought for me. I also have a 'UFO' thing that just goes up and down and I can get it to hover.
Not addictive for me luckily.
Old Nov 10, 2011, 02:30 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Laughing.... That is doing my head in so all I can do is laugh.
Some how I don't think that I need to know all that stuff.
I just stick a recommended and tried prop on, and if it flys, then that's it.
Good on here ain't it?
Old Nov 10, 2011, 02:36 PM
Jam1e is offline
Find More Posts by Jam1e
Worcestershire, England
Joined Nov 2007
Like it!!
Jam1e is offline Find More Posts by Jam1e
Old Nov 10, 2011, 02:53 PM
Arck is offline
Arck's Avatar
Lima-Peru
Joined Aug 2004
I am currently building my V2 SS (nearly done!!) and wanted a motor mount option that would allow me to change motors without cracking the fuse. I wanted to use the 2200 KV inrunner and thought the following would be the simplest option.............
Great ozair, what about the incidence of the motor, some advise on that?
Thanks for your patience,,,
werner
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
