Old Oct 31, 2011, 11:27 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by idletime View Post
How much of a 'big deal' is this...I have a similar issue with my AXN that's been through one to many crashes...but otherwise has been fixed.
I think it's a matter of degree.....the all important question is, how does it fly? When it comes to how much of an issue, I think of how I was surprised after watching videos from on-plane cameras which showed the control surfaces in flight, how much reaction you get from t-i-n-y control surface movements. It'll take a bit of doing, but I can upload an example to show if there's interest.
I remember being concerned I didn't have much 'range' of adjustment from my radio's trim controls, from watching (measuring, even) the little they did move from one end of adjustment range to the other. Turns out, they have PLENTY of effect on the plane.
So....again how does it fly? It might look misaligned as all heck, but if it's flying straight & true, with controls & trims centered.....no'm sayin'?
Keep in mind, a lot of mechanical trim can be applied just by adjusting pushrod length with clevis position.
StarHopper44 is offline Find More Posts by StarHopper44
Old Nov 01, 2011, 12:28 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by jrjr View Post
Here's one of my winter projects... a big box of balsa....
I plan to make it electric though
And here's the second project.
I like the biplane! May just do one of those myself. A bit bigger than most. Like that. I even have a motor just about the right size for it! Will look for a thread on it.
Gord
Gordks is offline Find More Posts by Gordks
Old Nov 01, 2011, 04:52 AM
Jam1e is offline
Find More Posts by Jam1e
Worcestershire, England
Joined Nov 2007
Originally Posted by Prof100
The horizontal stab and wing are wonky (not square) to the fuselage. Below is your picture with some lines picking up the axis.
Thanks for all the ideas and comments folks.
As embarassing as it is i think it may be a case of the horizontal and vertical stab being out of square. Along with the main wing being twisted. Which, when added all together results in a plane that is not pleasant to fly at all!
I've decided to go with one change at a time and "test-fly" it to see if there is any improvement. First thing being the vertical stab, which i've removed and about to hopefully glue back on properly this time. And if the crappy UK weather ever improves i'll i then fly it!...
Just a thought. I'm using a heavy esc and ubec. 100 grams to be procise!!
I've attached it via velcro to the inside of the battery compartment, stuck to the right-hand side/wall of the fusalage. As the nose of the plane is quite wide in comparison to the rest of its fus, is it possible it may be dragging this side of the fus down causing it to bank right like it's out of trim??
Well i flew it!.......
It flew fine but still needed a large amount of aileron trim to keep her level.
Saved me alot of work! Considering i was about to strip extra cf rods out the wing!
Didn't push her at all as it was it's first "real" flight. I had an 8 minute flight and used 1380 mah out of my Rhyno 2250mah 3s. So i'll increase flight time by a minute and have another look at comsumption.
It's a very strange feeling flying the Bixler. Never flown a glider before but getting used to it is good fun!!
Jam1e is offline Find More Posts by Jam1e
Old Nov 01, 2011, 05:29 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Gord
Here's a good one
http://www.rcuniverse.com/forum/m_25..._1/key_/tm.htm
jrjr is offline Find More Posts by jrjr
Old Nov 01, 2011, 06:17 AM
khaled_abobakr is online now
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Hi Prof1000
Could you please tell me what happens if I fly with this amount of misalignment ??
Thanks a lot
Khaled
khaled_abobakr is online now Find More Posts by khaled_abobakr
Old Nov 01, 2011, 07:23 AM
eccvets is offline
Find More Posts by eccvets
Joined Aug 2009
I think I may have a solution to my little weight problem... The way I see it, at this point the foam is just dead weight so I think I'm gonna go ahead and make a full carbonfiber/kevlar plane. Just cut out the middle man AKA==>foam and go for full carbon... What do you think? I mean it was ~24-26 oz with the foam before all my modifications, I figure I'll end up with a stiffer/stronger airframe at about half the weight of the original (perhaps lighter) as my AUW after my mods which will be ~48oz. Might weight a bit more if the metal servos I ordered weight a lot more then the stock ones... I could tear out all the stock plastic servos and put that into the carbon plane and then put the metal ones into the foamie.
eccvets is offline Find More Posts by eccvets
Old Nov 01, 2011, 07:24 AM
Joined Nov 2006
Originally Posted by Eagle202 View Post
Nice motor. What is the difference between the 2836-22 & the 2835 kv3900?
Sorry .. but I can't provide such information as I'm still learning and I lack that kind of knowledge ... I'm glad Prof100 has given you the proper answer
Thanks a lot
Khaled
Old Nov 01, 2011, 08:52 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by StarHopper44 View Post
How do you route the 30" -- is there a portion just left dangling free, I'd guess, behind the plane? (As opposed to doubling it back somewhere along the line.)
And, from a couple of PM's I've gotten, it sounds like Tx signals aren't affected by foam, but are by CF and metal plating type surfaces. Which seems to suggest you could just run the long antenna back thru the fuse to the tail, & either double it back (if that's 'allowed') or, let it emerge from that tiny hole at the extreme back end.
There's more to the story - basically, a part of why I'm asking - but let's cover that first & I'll get more into it later.
It runs out a hole under the canopy along the lower fuse seam through a small tube ca'ed to the seam. I don't remember if the tube came with the SkyS or if I used one from a EZ I had laying around. Rest hangs out the back.
Coiling the antenna or running it back onto itself is not a good idea. It shortens the range quite a bit. I found this out the hard way with a heli (may it rest in pieces).
Nuttin to show pic wise. All my pics are on the home pc back in NJ as is the SkyS......so I leave you with this..
2500GENE is offline Find More Posts by 2500GENE
Old Nov 01, 2011, 08:54 AM
Jam1e is offline
Joined Nov 2007
Go for it i say. It's all about experimenting....
Old Nov 01, 2011, 10:17 AM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Must be a NJ troll. The FL troll would have a tan!
Ted
G550Ted is offline Find More Posts by G550Ted
Old Nov 01, 2011, 02:13 PM
Earthbound Skyhound
Joined Jun 2011
Ted
Where the Sun don't shine???
Somebody got some 'splainin' to do, Loosey!
Old Nov 01, 2011, 04:38 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by khaled_abobakr View Post
Hi Prof1000
Thanks a lot
Khaled
Khaled,
If I flew the plane I would be trimming the ailerons to get it to fly level. I would land the plane and put in the aileron trim mechanically and readjust the radio trims to zero.
My LED lit Skysurfer suffered numerous tip stalls and mangled the nose pretty bad. Even after repair the odd shaped refinished fuselage affected how it flew. It wanted to roll left. I adjusted trims and flight perfromance is reasonable.
Loops can be done but may not track perfectly.
Bill
Prof100 is online now Find More Posts by Prof100
Old Nov 01, 2011, 08:48 PM
Weekend Flyer is offline
Find More Posts by Weekend Flyer
i Like RC
Weekend Flyer's Avatar
Manitoba, Canada
Joined Oct 2010
I'm sure someone has posted this somewhere already but I'll never stumble upon it so I'll ask.
I have a sky surfer v1 and want to get another as a kit. Is the BH sky surfer worth the extra $10 (plus another extra $10 shipping) than the Bixler v1 kit?
Weekend Flyer is offline Find More Posts by Weekend Flyer
Old Nov 01, 2011, 09:25 PM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
GoPro Mount for Bixler
I finally broke down and upgraded my onboard camera to a GoPro HD. After I got it I realized I wasn't sure how to mount the thing on the plane. Here is what I came up with for the mount.
GoPro Mount for Bixler Glider (20 min 13 sec)
I'm putting together a flight test video also.
-Mike
mike_m2 is offline Find More Posts by mike_m2
Old Nov 01, 2011, 09:34 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Ted
hey, back off bud, we get some sun here too :-))
LOLOL
nakelp86 is offline Find More Posts by nakelp86
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
