Old Oct 23, 2011, 08:33 PM
im2lar is offline
Find More Posts by im2lar
United States, SC, Mt Pleasant
Joined Oct 2011
Heading Hold Gyros in an Airplane
As a novice, I was researching Gyros and wondering why any "gyro" would not work in any axis.
In Short;
I found that Heading Hold is actually how it acts rather than how it works.
And that most HH gyros can, in fact, be used for airplane stabilization.
After searching I finally found some links that had the info I was looking for, and at a level I could grasp.
To Start Go Here;
http://www.mycoolrc.com/gyro/index.html
http://www.mycoolrc.com/gyro/indexnew.html
I found a lot of usefull info there, and in simple terms.
Follow the links and you will find info on a lot of different gyros.
What, Why, and How to use.
Ebay is flooded with cheap Esky EK2-704B HH Gyros @ $15.55 delivered US.
Or the Detrum GY48V for in the $18 to $20 delivered US.
im2lar is offline Find More Posts by im2lar
Old Oct 23, 2011, 08:38 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
In Short;
To Start Go Here;
It's just the difference between heading hold and rate hold I think that is the distinction. Some (or most) can do both, depending on the sensitivity settings. At least the one on my heli can do both.
erkq is offline Find More Posts by erkq
Old Oct 23, 2011, 10:27 PM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
Originally Posted by ozair View Post
From the link you provided I see that the GY48v is also described as a headlock gyro and you are using it successfully on your PZ P51 yet AJ seems to have concerns about using headlock gyros. Do you think that the one I just purchased (hasn't arrived yet) from Ebay, the Esky EK2-0704B will work or is it different to your one?
Yeah, they describe it as a headlock gyro, but its both, headlock & rate mode.
The Esky 704b looks to be both as well, and is one of the main 3 that gets discussed in the thread. I plugged my GV48v into the gear channel, then set the gear options to 0/-30 on my TX (negative = rate mode%, positive = headlock%). You can probably do the same with the Esky.
If you have a knob on your TX, you could probably dial up and down the sensitivity and mode in real time.
protocol is offline Find More Posts by protocol
Old Oct 23, 2011, 10:32 PM
protocol is offline
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
Originally Posted by aeronca View Post
...I used to fly U/C combat with 7x8 and 8x8 props (2 different classes) and I can tell you, there is a load of difference in speed compared to the same diameters with 6" pitch!
I noticed this myself today, flew my P-51 with a 10x8, and I could feel the extra speed over my previous 10x7, and slightly shorter battery life.
Old Oct 24, 2011, 12:05 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by Flypoppa View Post
No problems my mate. I have a couple of them that have not been used. 1920 style Full body.
Now you drive safely you hear.
Thanks but me and the wife flew. The brother inlaw and my son drove the truck and just got here. Floating in the pool with a few beverages then snoozing. Unload the truck in the am then go gator hunting in the back yard. Saw a snake the size of a boat oar I need to kill. . It's 1am and there are stores open 24hrs a day who sell beer.
Like the ball player said to Kevin Kostner in Field of Dreams....."is this heaven?"
2500GENE is offline Find More Posts by 2500GENE
Old Oct 24, 2011, 12:18 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Here is a 3 minute video of the Microdan Skysurfer with two rate gyros installed (Esky EK2 0704) on the ailerons and elevator. This is the second flight after my first which had the gyros reversed. What a handful that was with the gyros fighting the flying of the plane. After landing and switching the gyros to operate correctly you can see it really handles the wind well. Amazing. Wind was 15 mph and the Skysurfer was extremely tolerant of the wind. The Skysurfer is a good flyer in the wind without gyros but easier to fly with them.
Note that at about 45 seconds I video another glider and you can see the wings rocking in comparison to the gyro equipped Skysurfer.
Skysurfer with aileron and elevator gyros_10-22-11 (2 min 55 sec)
Prof100 is offline Find More Posts by Prof100
Old Oct 24, 2011, 01:59 AM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
I found this video today, it's of a guy flying a sky surfer beautifully in what he claims to be 15 mph winds.
Sky Surfer Battery Placement and Flight (8 min 18 sec)
Dkumagai is offline Find More Posts by Dkumagai
Old Oct 24, 2011, 03:53 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Hey all, im about too pull the trigger and oder the Kit Bixler.. I have the 2 RCtimer Bls on hand the 2212 and the 2826. I did a bit of searching but cam up short on the mount that comes with this...seeing il be getting the Kit is it a direct fit...
I think i seen someone take it out and do some trimming of the mount and bolt it on form the back, im guessing the X mount well not fit?
I know the search function ,but all i got come up were the Number/data on the 2212/6.
Plan is FPV with GoPro and LEDs
I have it all in the cart ready to order lol...
Thanks for info
Cheers
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Oct 24, 2011, 06:03 AM
khaled_abobakr is online now
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
http://youtu.be/xIn4dY5gdB0
That was totally awesome
Khaled
khaled_abobakr is online now Find More Posts by khaled_abobakr
Old Oct 24, 2011, 06:11 AM
Joined Nov 2006
http://www.youtube.com/watch?v=ppCdLkGR4FM
Amazing ... amazing .... This plane has a lot of potential ..
Khaled
Old Oct 24, 2011, 06:15 AM
Joined Nov 2006
Hi again
Today I flew my heavy FPV Bixler "LOS" with a CG 7.2 cm from LE... and for the 1st time I could really have a better feel of the plane ...
1-It glides hands free.. no diving this time
2- control is greatly enhanced
So I'll try 7.4 cm CG next time .. finally I'm getting there ...
Thanks a lot to all of you guys for the help you've provided
Here are some photos of my ugly fat FPV Bixler
http://www.rcgroups.com/forums/showt...6#post19679932
Khaled
Old Oct 24, 2011, 06:23 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by khaled_abobakr View Post
Hi again
Today I flew my heavy FPV Bixler "LOS" with a CG 7.2mm from LE... and for the 1st time I could really have a better feel of the plane ...
So I'll try 7.4 mm CG next time .. finally I'm getting there ...
Khaled
Not being picky... But don't you mean 72 and 74mm or 7.2 and 7.4 cm?
Flypoppa is offline Find More Posts by Flypoppa
Old Oct 24, 2011, 07:15 AM
Joined Nov 2006
Sorry .. corrected ... of course I meant 7.2 cm and 7.4 cm
Thanks for the correction
Khaled
Old Oct 24, 2011, 08:10 AM
rizky_p is offline
Find More Posts by rizky_p
rizky_p's Avatar
Indonesia, Jakarta Capital Region, Djakarta
Joined Apr 2007
Does anyone knows what is the inside diameter of the motor opening on bixler? I am planning to put 2826 outrunner motor inside.
Thanks.
rizky_p is offline Find More Posts by rizky_p
Old Oct 24, 2011, 08:45 AM
eccvets is offline
Find More Posts by eccvets
Joined Aug 2009
Hey guys, I have the stock motor with a 2200mah lipo and my AUW is 38.5 oz. I do have a 6X4E prop. Do you guys think I'll be able to get her in to the sky?
I played with laying 3-4 layers of carbonfiber in the fuse and put a kevlar/carbon fiber nose on the plane and did the normal mods like putting CF in to the rear stabilizer and rudder and on all the control surfaces, solid Carbonfiber spar, made new control horns as the old ones snapped on me and taped up the wings with extreme tape. The plane is pretty much crashproof but IDK if I'll beable to actually get her in to the air. I have a spare 2600kv motor and wanted to hold off on putting that one in this plane just to see if the stock motor could work. What do you guys think?
eccvets is offline Find More Posts by eccvets
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
