Old Oct 22, 2011, 07:00 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Originally Posted by fpsazerbaijan View Post
Hi all! Sorry more questions...
I am looking for a replacement prop adapter/spinner for the Bixler (SS V1). I need one that will fit the TGS Sport 6x4E Precision propeller. Any ideas please? Happy flying, Al
This is the one I use
http://www.ebay.com.au/itm/Propeller...item3f0ef7d2d9
ozair is offline Find More Posts by ozair
Old Oct 22, 2011, 08:26 PM
smarm is offline
Find More Posts by smarm
Joined Oct 2011
For those FPV'ing with bixlers, where are you mounting your Vtx and battery? I run a seperate video battery (1000mAh 3s) which I'd lazily put above the 2200 flight battery, quite far forward. I'd mounted the vtx just in front of the vertical stab. The thing flew like an absolute dog and I had a real hard time gaining attitude with sufficient elevator authority unless I was > 2/3rds throttle. Then flew too close to a tree, and the thing dropped with it's heavy nose.
Any advice appreaciated.
smarm is offline Find More Posts by smarm
Old Oct 22, 2011, 08:44 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Originally Posted by Eagle202 View Post
AJ
I purchased my SS from BH last July. The paperwork states it is a V3. I have attached a picture of the transmitter to this replay.
Vince
Wow, that's way different than the RTF SS I got from Tim at RMRC. I have a V1.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Oct 22, 2011, 08:59 PM
Planet Papi is offline
Find More Posts by Planet Papi
Nooby
United States, TX, Austin
Joined Jun 2011
I'm sorry if this has been answered already. The thread was pretty big to find it.
I 'm a newbie to Bixler and I am trying to re purpose my HK TX and RX ( http://www.hobbyking.com/hobbyking/s...042&aff=106965 ) which I have used successfully on Delta wing type scratch built plane.
The problem is now I have few more channels on Bixler and wondering what wire goes where on the Receiver. My receiver have Ch1, Ch2 to Ch6. But doesn't say like Rudder, Throttle etc..Any help would be appreciated.
Thank you all in advance.
Planet Papi is offline Find More Posts by Planet Papi
Old Oct 22, 2011, 09:07 PM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
BH ARF SS Kit (possibly V3)
Per AJ's request.
Description:
Description:
Description:
Description: New stock 2.3mm collet adapter with stock 5" prop. Prop feels fairly rigid.
New stock 2.3mm collet adapter and 5" prop. Propeller feels pretty rigid.
Description: Stock adapter (left) and HeadsUpRC 2.3mm collet adapter (right)
Stock adapter (left), and HeadsUpRC 2.3mm collet adapter (right)
Description:
Description: 6mm wing spar. I thought it may have had thicker walls but a 4mm rod still fits snugly inside. Very rigid in stock form.
6mm wing spar. I originally thought the walls were thicker than in earlier versions, but a 4mm rod still fits inside. It does, however, feel exceptionally rigid.
Description:
Dkumagai is offline Find More Posts by Dkumagai
Old Oct 22, 2011, 09:12 PM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
http://www.hobbyking.com/hobbyking/s...idProduct=6755
Or
can it be a cheap heli head lock gyro?
Hey fps,
I use Detrum GY48v on my PZ P-51 on windy days, but plan on adding one to my Bixler. I turn it on to 30% rate mode using my gear switch on TX:
http://www.hobbypartz.com/60p-dy-1017.html
... just a cheap gyro with headlock and rate mode, you'll need rate mode for an airplane, headlock isn't much use.
I don't know anything about the HK ones, but this thread has all the info needed: http://www.rcgroups.com/forums/showthread.php?t=1035605
protocol is offline Find More Posts by protocol
Old Oct 22, 2011, 09:15 PM
protocol is offline
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
I think this is right:
CH1 - Ailerons
CH2 - Elevator
CH3 - throttle
CH4 - Rudder
Old Oct 22, 2011, 10:02 PM
Papo_60 is offline
Find More Posts by Papo_60
USA, NY, Endicott
Joined Oct 2010
Originally Posted by Wirewolf903 View Post
Very well done build log!
Thanks Wirewolf, appreciate your comments. I put a tremendous amount of time & effort into this build log in hopes that it would help a number of people complete their build/mods many of the problems that I (as a newbie) had to overcome.
In fact, I had hoped () that this build log might even be good enough that it would be considered to have it's link added to pg #1. But alas, I fell short, not even an honorable mention or a job well down by our moderator. So maybe my hope to help many will become help for a few that happened to set my blog post. Looks like a hard club to gain membership too, for some anyway.. My $.02 FWIW.
Ron
Papo_60 is offline Find More Posts by Papo_60
Old Oct 22, 2011, 11:29 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Dkumagai View Post
Per AJ's request.
Attachment 4366611
Attachment 4366612
Attachment 4366613
Attachment 4366614
Attachment 4366615
Attachment 4366616
Attachment 4366624
Attachment 4366625
Yes. Thank You.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 22, 2011, 11:30 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ
Vince
GREAT!. Man, oh man. I have been searching for that pic for a long time. Now...Does anyone have a pic of the xmitter from a V2 RTF?? BIG TIA for whoever might have that picture for comparison.
AJ
Old Oct 22, 2011, 11:35 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by ozair View Post
Yes AJ, the pictures provided by Bill are very informative (thanks for posting Prof), for me anyway.
I just purchased this one http://www.ebay.com.au/itm/ESky-0008...item1e644703c0
to play around with and get a feel of what they can do.
Oops. That is a headlock gyro. I do not know if it will run as a rate gyro. The only gryo I have used is the EK2-0704 (note: NO "B") which is a rate gyro. It looks like THIS. They are getting hard to find. There are a couple of rate gyros from HK. But, I have never used them and I know nothing about them. Anybody have any feedback to help ozair??
AJ
UPDATE: This might help. I have never tried it.
http://www.rcgroups.com/forums/showthread.php?t=1051219
Old Oct 23, 2011, 12:33 AM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Here is a great thread on using gyros on airplanes. Melnic started the thread.
Prof100 is online now Find More Posts by Prof100
Old Oct 23, 2011, 12:46 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
AJ
Update: Ignore this, didn't see your update.
From the description of the item on eBay:
dual sensibility adjusting model---nose locked model and standard model
Gordks is offline Find More Posts by Gordks
Old Oct 23, 2011, 12:55 AM
Orcoz is offline
Find More Posts by Orcoz
Clueless, but trying
Orcoz's Avatar
United States, CA, Walnut Creek
Joined Nov 2001
I built a little copycat pod, and thy Vtx sits in the back of the pod. I use a 450mah 3s and it just sits on top of the flight battery (1300mah 3s). Flies like a dream.
Orcoz is offline Find More Posts by Orcoz
Old Oct 23, 2011, 05:13 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
The top picture can't be in Florida. They don't allow pushcarts in the roadway.
No, it's in Georgia -- that's the Florida state line in the background.
You should've known that from the mass exodus in progress. (Word spread quickly.)
The pushcart is a peanut vendor. Furthermore, it's actually a state vehicle.
StarHopper44 is offline Find More Posts by StarHopper44
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
