Old Oct 21, 2011, 09:10 PM
DMala is offline
Find More Posts by DMala
DMala's Avatar
New Jersey
Joined Sep 2009
Great, thanks guys!
DMala is offline Find More Posts by DMala
Old Oct 21, 2011, 09:12 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by DMala View Post
It's fair to say that I should read the first pages before of asking questions (which I did by the way), but also my post should have been read equally carefully...... and not everyone did.... so please chill out a tad before you shoot from the hip, thanks.
I did read on the very first page that the better prop is a TGS 6x4E prop, in fact I specifically mentioned it in my question. What I did not understand on the first page is the following:
"7. Prop Adapter - Use a 2.3mm for V1 & V2 BL."
With a Google a search I find very different adapters and I doubt that they would all be good:
example: http://www.bphobbies.com/view.asp?id...03&pid=V748000
Vs http://www.amazon.com/Maxx-Adapter-2.../dp/B001AEUZHS
Vs the collet adaptors that come with the HK prop (aeronca, thanks for the link)
So that's why I wrote "From what I understand to get started I should get (...) a TGS 6x4E prop (and adapter? I am unfamiliar with how to connect airplane props)" (...)If necessary I can find the tubes and probably the horns on my own, but I have no idea what parts to order for the prop. "
You see? I asked which parts "for " the prop, not "which prop..."
So I am still hoping that someone kindly answers this original question, which does not require hundreds of lines/pages (whatever that means...) to answer.... thanks
http://www.rcdude.com/servlet/the-15...Adapter/Detail
http://www.e-fliterc.com/Products/De...rodID=EFLM1921
http://www.hobby-lobby.com/collet_pr..._1196_prd1.htm
http://www.toysonics.com/toysonics-a...-to-4.7mm.html
http://www.maxxprod.com/mpi/mpi-291.html
http://www.shop.dennishobbies.com/Bu...400-ACC325.htm
http://www.amainhobbies.com/product_...peller-Adapter
http://www.amazon.com/gp/product/B00...WGSZGRECR01YV5
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 21, 2011, 09:21 PM
Earthbound Skyhound
Joined Jun 2011
Originally Posted by 2500GENE View Post
Look at it this way. The only way it takes more power is if you throttle up to get back faster. The plane will be flying 20-30mph airspeed. The wind will be 15mph or less. You will not want to fly in 20mph wind or better. (no mater what some claim to have done.) The plane will come back at the same throttle setting you used heading down wind.
The point is flying into the wind doesn't use more power unless you throttle up causing it to use more. You caused the power consumption to increase, not the wind.
If we do go to war on this I want to wear the blue helmet, you can wear the grey. I'll meet you at Gettysburg, PA.
and further more..... What is your first name?
Gene, if you're flying a plane straight away from you at 10mph GROUND speed with a 15mph direct tailwind, and don't touch the throttle, what happens when you turn the plane directly back towards you?
Old Oct 21, 2011, 09:26 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
It can't happen since you can't fly with -5 airspeed.
In such a scenario the plane would be way under it's stall speed and would drop like a rock long before turning was a issue.
http://en.wikipedia.org/wiki/Stall_%28flight%29
2500GENE is offline Find More Posts by 2500GENE
Old Oct 21, 2011, 10:21 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AGL vs air speeds
If you are considering only ground speed, the airplane is going away from you at -5mph. If you had an ASI on the plane, it would read 10mph and an observer in the plane would be watching you go away from him at -5mph. All of this, of course, assumes that you have a plane that will fly at 10mph (like a slow stick).
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 21, 2011, 10:50 PM
Earthbound Skyhound
Joined Jun 2011
Gene, if you're flying a plane in a 90 15mph crosswind at 10mph GROUND speed, don't touch the throttle, and turn it directly into that 15mph wind, what happens to the airplane?
Old Oct 21, 2011, 10:55 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
The question is not specific enough. It depend if part of that 10mph ground speed has a sideways component, meaning you are being swept along with the wind. Or, are you crabbing against the wind and keeping a ground trajectory that is 90 degrees to the wind. Different scenarios and different answers.
The first scenario really isn't possible, as you are doing at least 15 mph ground speed, even if you are in a hover.
If you mean the latter scenario, the plane is ALREADY turned 56 degrees into the wind to crab against the 15mph wind speed. In this scenario your TAS would be 18 mph. As you turned into the wind your 10mph ground speed vector would shift 90 degrees and your ground speed would reduce to 3 mph and the plane would be none the wiser, having made a constant speed 34 degree turn. I can detail the math if desired.
EDIT: BTW, I know I'm not Gene. But it is an interesting scenario to think about.
EDIT EDIT: There, I think THAT's it. As I say... interesting scenario.
erkq is online now Find More Posts by erkq
Old Oct 22, 2011, 12:19 AM
Dkumagai is offline
Find More Posts by Dkumagai
United States, WA, Seattle
Joined Oct 2011
If anyone is interested, my ARF SS from BH came with a 2.3mm collet-style prop adapter. I had already purchased an adapter from headsuprc, and I think either will work on my TGS 6x4. The stock adapter is significantly larger and heavier than the one from headsuprc.
The stock prop also seems to be of better quality than what was included with previous iterations of the SS. The stock spar also appears thicker than what I've seen in pictures here. I can post some shots of my kit while it's still in pieces if anyone is interested.
Dkumagai is offline Find More Posts by Dkumagai
Old Oct 22, 2011, 12:23 AM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
SH so much for your buddy codes You get me all excited and then nothing. As a result of your actions and Gene's wanting to finish off his pool I just cannot afford this unit any more
Gene, I dont know about the others but I will give you 1 month to finish off your pool after which time its back to normal use of your card, this hobby is identical to a woman, they both suck you in
ozair is offline Find More Posts by ozair
Old Oct 22, 2011, 12:25 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
If this was a V3 SkyS from BH then please post pictures.
Old Oct 22, 2011, 12:32 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Originally Posted by healthyfatboy View Post
Do you have the link to this? I would search through the last pages but I'm feeling lazy right now.
Try this one http://www.hobbyking.com/hobbyking/s...dProduct=11780
Old Oct 22, 2011, 12:51 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Originally Posted by Flypoppa View Post
Can we get off this 666 page as it is scary.
FP what utter rubbish. I can't believe that an intelligent man like you believes in this supersticious hoo-ha. Just as well it wasn't Friday the 13th.
Old Oct 22, 2011, 01:00 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
10,000th post! Wahoo! I was waiting for that if you couldn't tell...
Well done HFB, your medal is in the mail
On a serious note, I think Congratulations are in order for AJ the man that set up this thread and through his diligent efforts created one of the best threads on RCG. Well done AJ, over 10000 posts and going strong.
Old Oct 22, 2011, 01:21 AM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Gyro installation
I have several of the Esky rate gyros but this pair came out of a Harbor Freight Easy Star clone which was a real piece of junk. So, the Skysurfer with the MicroDan is now sporting gyros on the elevator and ailerons. With the HXT900 analog servos 30% gain is the max. Low medium temp hot glue mounts them to the fuselage. Test flight with gyros is tomorrow, time permitting.
Prof100 is online now Find More Posts by Prof100
Old Oct 22, 2011, 02:04 AM
Dkumagai is offline
Joined Oct 2011
I think it is in fact a v3. I requested a clear canopy with my ARF and it seems like they just sent me an unassembled v3. I'll post pics tomorrow when I'm not dead tired.
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
