Old Oct 16, 2011, 11:14 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
[QUOTE=aclinml;19608090]OK, so I wanted to remove the stock Bixler prop adapter, so I could put a normal prop adapter on it. I heated up the adapter with a lighter for about 60 secs, then put a pair of vice grips on the shaft just below the adapter, and then pried like hell with a screwdriver and could not get it to budge, even strained my back trying to do it! That adapter is not going anywhere! So now I notice that the stock adapter is not in a straight line compared to the shaft. After a few minutes I have got it back on pretty straight. I tested the engine and it does have a VERY slight vibration, but I think it will be OK for now.
So, it looks like to get it to be completely true, I will have to swap out the motor with a new one. So, I have two questions....
1. Which is a good replacement motor (under $20)? I DO NOT want unlimited vertical. The stock power in my Bixler was just fine. A LITTLE more power
would be OK, but don't really need a whole lot more.
2. Since the Bixler fuse is glued together, what and how should I cut into it to gain access to the motor and the mount?
Thanks, guys....[/QUOTE
This is the replacement that I use with a 6X4 and 25amp ESC.
http://www.dealextreme.com/p/a2208-1...irplanes-13561
Flypoppa is offline Find More Posts by Flypoppa
Old Oct 16, 2011, 11:17 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
1. Which is a good replacement motor (under $20)? I DO NOT want unlimited vertical. The stock power in my Bixler was just fine. A LITTLE more power would be OK, but don't really need a whole lot more.
Thanks, guys....
Dear Sir:
Didja happen to catch our motto:
"Bixler See Post #2 & #3 for parts & mods B4 asking " ?
Lotta wisdom in that!
http://www.rcgroups.com/forums/showt...=1231310&pp=25
Otherwise, we can't be responsible for what Gene might tell you. About anything.
(*psssst* You wanta stay on his good side!)
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 16, 2011, 11:20 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by StarHopper44 View Post
Don't be silly, man - you can't count the Bixler as a SkySurfer!
The decals are completely different!
(Tho sometimes their boxes will get ya confused.)
Just to confuse everyone, I have decals from a Rookie, and Turngy on my Skybixrookturn.
Old Oct 16, 2011, 11:23 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
AND the SkySurfer is FAR superior!
jrjr is offline Find More Posts by jrjr
Old Oct 16, 2011, 11:25 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
No, no, no... The Bix is the Best!
erkq is offline Find More Posts by erkq
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
What! Is that just the box?
Old Oct 16, 2011, 11:35 AM
Earthbound Skyhound
Joined Jun 2011
My Beexlaire farts in your Skesurfeur's generale directione!
Old Oct 16, 2011, 11:38 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Thanks, guys....
There are several options for mounting and are discussed in this thread. Here's one that I don't think made it here before.....
If you want a little more power go with a 2200 like
This
or
This
Old Oct 16, 2011, 11:43 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Glad I wasn't holding my coffee when I saw that! Would have had to take a shower.
Gord
Gordks is offline Find More Posts by Gordks
Old Oct 16, 2011, 11:51 AM
erkq is offline
Joined Dec 2010
Right on, right on... I can get behind that!
Old Oct 16, 2011, 12:06 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
When, not IF you purchase a new SF, Purchase a couple sticks of Carbon Bibbon
.032 X .310 X 60" from WWW.CANUCKENGINGEERING.COM cut and place two lengths from where the nose starts to curve in, to under the wing. One on the side and one underside. Then Nex. Go the tail fathers. One on top from in front of the Rudder to
about the trailing edge of the wing. One on the side, from under the Hz. fin running forward to about the trailing edge of the wing.
Now on to the wings. From about the edge of the fuz. run full length of wing to where the tip starts to turn up.
Now for the hz. stab. each side, from the fuz. to about the tip.
Cut a slot just a little deeper then the .310, push it in, and succure with CA glue.
YOUR PROBLEMS WILL BE OVER.
Wings will not flap, tail will not flap, nose will not break off.
SARG5
SARG5 is offline Find More Posts by SARG5
Old Oct 16, 2011, 12:25 PM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
**~~Lighting a scented candle with nose plugged~~**
HEY open a window will ya StarPopper?
That Bix of yours is smellin up the place
Old Oct 16, 2011, 01:09 PM
Ole Joe is offline
Find More Posts by Ole Joe
Joined Oct 2007
Thanks, guys....
Just cut off the shaft aft of the standard adapter with a Dremel type tool and cutoff disk. Purchase the appropriate adapter size for your shaft and your good to go. I've found different size shafts among SkyS and Bixlers, so measure yours to be sure. The standard shaft is much longer then needed and will still accept a collet style adapter after it is cut.
Ole Joe is offline Find More Posts by Ole Joe
Old Oct 16, 2011, 03:23 PM
Tim. is offline
Find More Posts by Tim.
Joined Aug 2011
I use the A2208/8 (2600kv) that's the rewound version of that DX motor, it rocks to the tune of around 18 amps with a 6X4 and gets the plane moving along nicely.
All my videos of my bixler flights to date have failed, but here's one with my new flight cam.
A2200 test (2 min 17 sec)
Tim
Tim. is offline Find More Posts by Tim.
Old Oct 16, 2011, 04:18 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Video
Tim
Nicely done. I loved the second half especially. Perfect landing.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
