Old Oct 15, 2011, 08:47 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by StarHopper44 View Post
I've not been able to wrap my head around what real good a servo tester is. Connect it, and it works or it don't.....and ain't that about it?
It makes you a immediate babe magnet.
Along with what aeronca said it's good for centering servos during a build before all the electronics are hooked up.
2500GENE is offline Find More Posts by 2500GENE
Old Oct 15, 2011, 09:03 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Gene,
I didn't know I became a babe magnet. I told my wife and she said no.
The servo centering feature is very helpful when building a plane. Cycling a servo to "break it in" is something I wouldn't think you'd do with a servo unless, of course, the servos passed QC only in name, not in reality.
Bill
Prof100 is offline Find More Posts by Prof100
Old Oct 15, 2011, 09:13 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by aeronca View Post
Someone mentioned a "servo cycler" they bought on eBay. I am not sure it was someone from this thread, but if it was, could you post a link?
Much appreciated!
Aeronca
HERE is another one. It works great for me. The one that jj604 mentioned is probably a good one, too. Heck, for the price - Get both.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 15, 2011, 09:23 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Servo choice
Much appreciated!
Aeronca
Originally Posted by jj604 View Post
There are lots of them. This one from Hobby King is good value ,works well, and has good functionality for 8 bucks. And it's in stock (unbelievable but true).
http://www.hobbyking.com/hobbyking/s...dProduct=11780
Originally Posted by Prof100 View Post
Gene,
Bill
Another thing you guys might want to consider is a metal gear servo. As the years go by, they get less and less expensive. Currently, HERE is what I am using. Over on the Fun Cub thread, the HXT900 is considered crap and not worthy of putting in a plane at all. Slowly, I am getting all my planes (31-see blog) converted over to them. So far, they are working great for me. I have about 25 of them installed in some planes and I have not had a failure yet. I cannot testify to the quality of them compared to other MG servos because this is the only one I have used. So, on your next HK order, you might want to round out the weight of your basket with a couple of them and try them for yourself. BTW-I still consider the HXT900 a good (not great) workhorse for park flyers. Just my .02 worth.
AJ
Old Oct 15, 2011, 09:26 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by ozair View Post
Thanks to Gene and AJ for gyro info.
After what FP said I am still trying to decide whether to use them or not
There is a win-win situation waiting for you. You can buy long hair wigs from GENE and go undercover. No one will know and we won't tell.
AJ
Old Oct 15, 2011, 10:54 AM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
From what I've been able to gather, cycling what appears to be a marginal servo for 5-15 minutes or so can "break it in" and work out a really good gear mesh, and that results in a smooth operating ditty from what originally appeared to be a marginal piece of equipment. Running an automatic cycler for this amount of time sure beats sittin' there moving the sticks.
Aeronca
First 'cycler' was said, & first response cited 'tester'....so count me ignunt but at that point I assumed they are one & the same....whereas beforehand I'd thought a tester did the kind've things Prof & Gino suggested, and/or maybe could "test" a suspect servo somehow & warn you of imminent failure from like, electro or mechs or whutever. If not for the latter, I still can't see the advantage of buying something a simple Go/No Go test will tell ya. Enlighten me.
AFA cardboard vs plastic vs metal.....I got eyes.
For stage II advanced diagnosis where doubt remains, magnets & matches.
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 15, 2011, 10:57 AM
Joined Jun 2011
AJ
Wig or not, Gene never looked that good, even in his Mom's favorite picture.
(But the really telling factor was, her favorite picture didn't even have Gene in it!)
Old Oct 15, 2011, 11:09 AM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
i have just finished my bixler fpv build, all gear installed before glueing together, i have still to do the cog, and some tweeking, but its 90% ready, i dont plan on using the rudder, so have fixed it and also had to replace it due to me flexing too hard when the plane first arrived, also using a board cam and scratch built pod with camera case, big thanks to Orcoz for letting me have his idea http://www.rcgroups.com/forums/showt...0#post18799833, i have just one question, what cog are people using i have read 60mm and even 70 + mm so wondering what you guys are using, hope you approve of my build
carl
doggit is offline Find More Posts by doggit
Old Oct 15, 2011, 11:47 AM
Joined Jun 2011
Old Oct 15, 2011, 12:08 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
The 3900 would be a rocket
No, it wouldn't.
I've been flying with a 2835-3900KV motor for months now. Nice smooth launch, gentle climb out, and pretty slow flying, both for me (way out of practice) and for m 13-year-old son (beginner). That motor and a 40A ESC in a Skysurfer is one of the easiest-to-fly, mellow combinations I've had.
And why?
I have a fancy radio, apparently much fancier than the radios used by those who think a 3900KV is a "rocket". My radio has TWO (count them, two) sticks! And the one on the left does something revolutionary: it controls the motor speed.
I keep that extra stick at about its halfway point, even during launch. You'd be amazed how much that mellows out the plane. It climbs well but gently, cruises nicely, and the plane's batteries last a really long time!
And then, if you ever want to have a little fun, you can point the plane straight up and move that second stick (the one on the left for most such radios) to the top position. But most of the time, leave it near the middle of its travel. With this second stick, you can have the best of both worlds!
You all might want to get one of these new-type radios... especially those of you to whom a 3900KV motor is automatically a "rocket". It looks to me like you haven't had a way of regulating the motor speed until now. But help is finally available!
Get a radio with that second stick. It makes all the difference. Trust me.
Little-Acorn is offline Find More Posts by Little-Acorn
Old Oct 15, 2011, 12:20 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by Little-Acorn View Post
No, it wouldn't.
And why?
A motor in the range of 4000KV on a 3S is what you'd see with 64 mm (2.52 inches) EDFs. So, your choice is a bit unusual for a prop plane but whatever works for you is always the goal.
Old Oct 15, 2011, 12:43 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
No, it wouldn't.
And why?
Someday I'll add that 2nd stick for throttle. Then I can use a 5000kv motor at 1/10 throttle.
Old Oct 15, 2011, 12:45 PM
Joined Jun 2011
"...and the plane's batteries last a really long time!...
Please define (quantification preferred) "really long time".
Old Oct 15, 2011, 12:47 PM
Joined Jun 2011
I'm shootin' for 50000Kv, & just leave the Tx at home!
('Course, might hafta git some kinda clearance from NASA afore launchin'.)
Old Oct 15, 2011, 04:14 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
carl
The correct CG is 60mm. Your build looks great to me. Of course, the proof is in the flying of it. Make sure to take some videos to share with all of us.
AJ
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
