Old Oct 14, 2011, 09:42 PM
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Originally Posted by 2500GENE View Post
The reason no one wants to fly with Flypops is he's old and smells like sardines.
The last plane I got down from a tree I use my son's paint ball gun. Worked. Then I shot some guy in a golf cart that was bothering me. It's may have been Ted. Not sure.
Nah. I was the gun in the other cart that ran over your models while you were messing around in the woods.
Ted
G550Ted is online now Find More Posts by G550Ted
Old Oct 14, 2011, 10:22 PM
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Gyro
Originally Posted by ozair View Post
AJ, please answer this quickly (and lets hope that FP does not see it). Do you use any rate gyros on any of your SkyS's, can you recommend any for tail and ailerons.
See GENE's reply below.
Start out slow. I use a Esky ek-704 for elevator only. Works very well.
Don't fly in gusty wind. The plane with the extra fpv gear weight likes to stay flat and smooth (I use a EZ*) for roll, only pitching up and down was a issue.
+1. Just use one on the pitch axis for now. I don't see any advantage to using one on the roll axis. But, give it a try and see what you think. The best source of the EK2-0704 is from Ebay. You choose the vendor. For a guideline, they should be under ~$14 delivered to your doorstep.
AJ
P.S. I am sorry I could not give you a better link. Ebay is down right now for who knows why.
UPDATE: HERE is an example. But, you can find them cheaper.
ajbaker is online now Find More Posts by ajbaker
Old Oct 14, 2011, 11:25 PM
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
eBay? Down?? OMIGAWD....is it 2012 already?????
StarHopper44 is offline Find More Posts by StarHopper44
Old Oct 15, 2011, 12:19 AM
Just Me
Joined Apr 2006
http://www.rcgroups.com/forums/showthread.php?t=1035605
Visit that thread and read up before you buy one....great info on there...
Brner is offline Find More Posts by Brner
Old Oct 15, 2011, 12:48 AM
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Originally Posted by Flypoppa View Post
Too late.... Seen it. Yea little girl. If you can't fly it like a man/boy then stick a gyro on it.
Now, now Malcolm, behave
I knew I should have PM'd AJ rather than post, but I really was hoping that you would not see it.
ozair is offline Find More Posts by ozair
Old Oct 15, 2011, 01:03 AM
Space is the answer
ozair's Avatar
Joined Mar 2011
Thanks to Gene and AJ for gyro info.
After what FP said I am still trying to decide whether to use them or not
Old Oct 15, 2011, 01:06 AM
Space is the answer
ozair's Avatar
Joined Mar 2011
Thanks for that.
Old Oct 15, 2011, 03:49 AM
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
That's a lie.
Ok so I ain't had a bath for a few years. (got a king size shower). I change my pants and socks when the old ones disintegrate and put the new ones over the top of them.
Yes I am old but smell of fresh salmon.
Flypoppa is online now Find More Posts by Flypoppa
Old Oct 15, 2011, 04:59 AM
United States, WI, Eau Claire
Joined May 2011
The 3900 would be a rocket but flying fpv isn't about that. You want thrust and reliability. Spinning a high kv motor to get thrust and power will create more vibration and rf interference which is what you want to stay away from flying FPV. I don't think sending $200. worth of fpv gear up and away trusting a $15 motor and $12 esc is a good gamble. Others will disagree and that is fine.
I like the E-Flite Six series inrunners. 2200kv or 2700kv.
http://www.horizonhobby.com/Products...rodID=EFLM2005
http://www.horizonhobby.com/Products...rodID=EFLM2000
and a E-flite ESC. (lower RF noise then most).
Also a Dimension Engineering UBEC. (very low rf noise)
Hitec hs 55 servos for low rf noise. (HTX 900s are very noisy rf wise and draw twice what the hs does)
As you may know rf interference will degrade you VTX down link.
If your getting into FPV the you may as well get the stuff that causes the least problems now because you will want it later. All the cheap-o stuff works fine on a non FPV plane but you're not in Kansas anymore..
It all depends on what you want from FPV.
My FPV skysurfer is already built and flown last weekend for the first time. Did really well, but it's a tad underpowered with the stock motor and extra weight. I've already swapped out the stock ESC and servos (one stripped on the bench the first power up of the plane - shockingly bad quality control) and made a custom mount so I can mount regular outrunners to the Skysurfer.
This is my "learning FPV" plane so I'm not looking to drop a ton on it. I have a Skywalker waiting for that
banzi28 is offline Find More Posts by banzi28
Old Oct 15, 2011, 05:16 AM
Joined May 2011
Originally Posted by ajbaker View Post
There are several motors that would be very suitable for FPV. The most bang for the buck is THIS one.
If cash flow allows, THIS is the one I recommend.
AJ
I think I'm going to go with Dan's motor, simply because it has so many other uses after I've graduated from this starter FPV plane.
Old Oct 15, 2011, 07:39 AM
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Someone mentioned a "servo cycler" they bought on eBay. I am not sure it was someone from this thread, but if it was, could you post a link?
Much appreciated!
Aeronca
aeronca is online now Find More Posts by aeronca
Old Oct 15, 2011, 07:47 AM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
There are lots of them. This one from Hobby King is good value ,works well, and has good functionality for 8 bucks. And it's in stock (unbelievable but true).
http://www.hobbyking.com/hobbyking/s...dProduct=11780
jj604 is offline Find More Posts by jj604
Old Oct 15, 2011, 08:24 AM
Earthbound Skyhound
Joined Jun 2011
I've not been able to wrap my head around what real good a servo tester is. Connect it, and it works or it don't.....and ain't that about it?
Old Oct 15, 2011, 08:32 AM
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Some have more features than others. Also, there is the issue of quality. Cardboard case vs plastic/metal, etc., and most of all longevity. How long before the magic smoke appears.
My HK tester (in metal case http://www.hobbyking.com/hobbyking/s...%5FTester.html) just quit working and I think I'll give that one a look.
Ted
Old Oct 15, 2011, 08:35 AM
aeronca's Avatar
Joined Oct 2003
From what I've been able to gather, cycling what appears to be a marginal servo for 5-15 minutes or so can "break it in" and work out a really good gear mesh, and that results in a smooth operating ditty from what originally appeared to be a marginal piece of equipment. Running an automatic cycler for this amount of time sure beats sittin' there moving the sticks.
Aeronca
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 02:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
