![]() ![]() But seriously....so what was the black stuff??? . |
New Zealand
Joined Apr 2011
I think your old WMP use older basic codecs that your pc could handle. When upgraded it also loaded a newer codec library that is taxing your hardware. On the un-install you change the software but not the codecs. Codecs are loaded with the system, not WMP. If you were to load FFDSHOW, it will give you most codecs you need with the option of turning off those you don't. It would be trial and error until you got just what is needed and nothing more. Running a older, slower and smaller ram pc with video is always tough but possible with most formats though full screen viewing may not be possible. When you view YouTube vids or Vimeo vids here or on their site you are not using WMP so they are not effected. If you first download then view a vid file, then that uses your default player which appears to be WMP. |
Flanders, NJ USA
Joined Jan 2001
Has anyone used carbon rod for pushrods in the standard skysurfer ver 2.0 tubes? Seems like this place has sizes that would work
http://www.cstsales.com/carbon_rods.html If so what did you do for connections? Thanks! |
just maidened my bixler, only got a few minutes as rain rolled in (weather channel lied) Plane flies really well but is going to take a little getting used to as the controls feel very lazy compared to what i am used to.
i think my only complaint is a couple times at lower power/power off the plane will go into a steep climb and stall for no apparent reason, i caught it a couple times and leveled it out but almost lost it once as well. i also noticed that at full throttle the plane tracks great no dip or anything like the motor thrust was set perfect from the factory |
...should give ya some clues. |
video of the maiden, landing was a little rough i wasnt paying attention to the wind and came in cross wind...did another landing after this and greased it no problem into the wind.
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
