Old Oct 11, 2011, 04:24 PM
bradsears is offline
Find More Posts by bradsears
Here because of FPV
bradsears's Avatar
Toronto
Joined Jul 2010
Originally Posted by SARG5 View Post
Out of line.
What I did on mine was to cut under the hoz. stab. on the LEFT SIDE, enough to let it pull back down to get things level. It worked.
SARG5
Hi. Thanks for the answer. I'll give it a try. This sounds much safer than what I was imagining.
bradsears is offline Find More Posts by bradsears
Old Oct 11, 2011, 04:45 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
just got my bixler today...though its raining out and i just picked up forza4 so probably wont touch it tonight
shadow102 is offline Find More Posts by shadow102
Old Oct 11, 2011, 05:49 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
I'm holding out for fiveza5.
2500GENE is offline Find More Posts by 2500GENE
Old Oct 11, 2011, 05:53 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
You're usually a funny guy. But we all take a swing and a miss sometime...
erkq is online now Find More Posts by erkq
Old Oct 11, 2011, 06:57 PM
shadow102's Avatar
Joined Mar 2011
sadly not the first time i heard that today
i did hook my esc and receiver up to the bixler though when i had a couple minutes along with putting on the 6x4 prop. Might fire up the hot glue gun later and attach the tail section and control horns
Old Oct 11, 2011, 07:13 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
Slow night.
Had no idea what a forza4 was.
Gotta love google.
Old Oct 11, 2011, 07:14 PM
Papo_60 is offline
Find More Posts by Papo_60
USA, NY, Endicott
Joined Oct 2010
I finally completed the build with mods on my SkyS (like AJ's rec. here) and the COG comes out at 60mm with a 2200mah bat up in the nose. Completed about a doz mods. About 50% complete with my build log but have 2 questions I could use some advise on:
  1. What picture editor do you use to print captions under the pictures.
  2. Same ? for video editing. I want to take Profs' advise, keep the video about 3 to 4 min & add some music so you don't have to listen to just the motor all the time.
TIA guys, appreciate any suggestions. I have attached one picture of my SkyS on my HM COG stand. I plan to add front & back air scoops as soon as I decide what I am going to use.
Ron
Papo_60 is offline Find More Posts by Papo_60
Old Oct 11, 2011, 07:16 PM
erkq is online now
Joined Dec 2010
Ron
Nice! You must be single.
Old Oct 11, 2011, 07:44 PM
shadow102's Avatar
Joined Mar 2011
tail assembly is together and the CA it drying on the 3mm spar in the bottom of the fuse...now to get the pesky washers out of the nose....really dont want to cut a hole or deal with hot water right now so that may be tomorrow
Old Oct 11, 2011, 07:47 PM
erkq is online now
Joined Dec 2010
The hot water method is really very simple... surprisingly easy.
Old Oct 11, 2011, 08:54 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Yup, hot water works great. That's what I did, despite being a little wary of it, it worked well.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Oct 11, 2011, 09:00 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Ron
Ron,
I don't know who you are asking but I do use Google's free picasa3. See attached video captured jpeg with text from Picasa3 editor. You can add text anywhere and any size with the color you prefer.
Prof100 is offline Find More Posts by Prof100
Old Oct 11, 2011, 11:53 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
RPM Sensor
Originally Posted by StarHopper44 View Post
<big snip> the Good thing the club was havin' a cookout - only thing that kept me at the field!
This is what I was shared with you. I use 3.5mm plugs. But, of course, you can used anything you like.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Oct 12, 2011, 12:54 AM
ua3xds is offline
Find More Posts by ua3xds
Serge
ua3xds's Avatar
Россия, Калужская область, город Калуга
Joined Jun 2011
To bradsears: I did not bother. Just compensated the slope with ailerons in the opposite direction.
To Papo_60
I use http://www.bsplayer.com just press "P" while video is running very handy. Or stop the video for a closer look and then press "P"
To shadow102: I use my lady's hear dryer blowing inside the fuse and hooking the washes with a bike spoke.
ua3xds is offline Find More Posts by ua3xds
Old Oct 12, 2011, 01:28 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
removed post
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
