Old Sep 15, 2010, 10:59 PM
kman24 is offline
Find More Posts by kman24
Addicted To Flying Foam
kman24's Avatar
United States, NE, Bennington
Joined Jan 2010
Originally Posted by Prof100 View Post
Hobbyking Turnigy 60 LED green surface mount LEDs on a 3S. Do you think they are bright enough?
Bill
You better wear your sunglasses when you got those babies on
KMan
kman24 is offline Find More Posts by kman24
Old Sep 15, 2010, 11:04 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
KMan
Kman,
My teeth still have green glow to them.
Bill
Prof100 is offline Find More Posts by Prof100
Old Sep 16, 2010, 11:23 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Light layout on Skysurfer
I cut and soldered a pattern of LED strips that I will use on the Skysurfer. I used 26 gage wire to solder the strips back toether (parallel). Power is a 3S.
Sorry about the color shift and blurring. The LEDs are son of gun to photograph. When finished there will be red set of lights on the other side and white lights on the fuselage with red flashing light on the tail.
BTW, the lights are taped on the left wing, it should be the right, I just didn't want to remove and re-tape.
Old Sep 17, 2010, 01:18 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I received the brushed Skysurfer from BH. It was returned kit that BH sold to me because I just wanted the foam. It arrived today minus the wings. Ooops, I guess BH not quite yet a well oiled machine.
Saralyn was called and she has requested the wings be sent.
That said, I did pull the brushed motor but in doing so the two halves of the fuselage were glued together so poorly I totally separated them. Brushed motor and ESC are out. The six washers are much easier to remove this way. I used AJ's hot water technique. In fact, hot tap water softened up the hot glue and I pulled the washers easily. Here are some pictures.
Old Sep 17, 2010, 03:13 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
That is definitely bright enough! When you connect to a 3s lipoly battery up to those lights, do you connect it to the balance charging connector? If so, do they make a male connector that you are using that you use to interface, or do you have another way of doing that.
KMan
Old Sep 17, 2010, 03:34 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
KMan
Kman,
I simply soldered up a Dean's male plug to test them out. You could use the balance leads for power if you have female balance tap lying around I am just going to solder in a female JST connector in the power lead that goes to the ESC and use a male connector on the lights. Each LED system has to be powered per its design voltage. The 60 LED strip uses a 3S pack. There is small resistor in every 3 LEDs. You cut them at that interval and use thin gage stranded wire to solder the strips to together.
For wire, you can buy 25' roll of stranded wire for $5 plus shipping. I got some 26 gage from work but bought a couple of rolls on line at powerwerx.com since my hobby is mine, not the company i work for on a daily basis. Some guys harvest the wire from phone lines and left over PCs. You don't need a lot but you do want lightweight and flexible stranded wire.
Bill
Old Sep 17, 2010, 03:42 PM
kman24 is offline
kman24's Avatar
Joined Jan 2010
Kman,
Bill
Gotcha! I hope to get some more evening flights in this weekend. I just don't think my camera will make for very good videos when it is pitch dark out. We'll see.
Old Sep 17, 2010, 06:58 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Don't bother. I took video of one nightflyer and it really wasn't very good. It takes an explanation to understand what's on the video.
Old Sep 19, 2010, 10:49 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Couple of backyard videos
First is on board.
http://www.youtube.com/watch?v=Kn6wHg8OR5g
Second is the hat cam.
Skysurfer hat cam backyard flying and short field landings. 9-19-10 (6 min 17 sec)
Lighting was delayed due a weekend of honey do's. We'll get them installed this week.
Bill
Old Sep 19, 2010, 11:16 PM
Alpha35 is offline
Find More Posts by Alpha35
Joined Feb 2008
I how many UFO sighting stories y'all are generating with your nite flying?
GeneH
Alpha35 is offline Find More Posts by Alpha35
Old Sep 19, 2010, 11:20 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
GeneH
I am sure it will have some people wondering what it is. They won't be able to find me since I am hidden from the road and I don't plan on wearing any lights.
Old Sep 19, 2010, 11:59 PM
Alpha35 is offline
Joined Feb 2008
Next thing you know, you will have the UFO Hunters TV show dudes snooping
around trying to solve the mystery of the "Canton Lights".
Old Sep 20, 2010, 12:04 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I will have to wear my Darth Vader helmet.
Old Sep 20, 2010, 02:35 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I built the internet!!!
Thanks for the props. But the credit for this great way to remove the washers goes totally to flyvertigo. I could never take credit for his (or anyone else's) idea. HERE is his post.
But, let me tell you about how I designed and built the internet........
AJ
P.S. I will be back home is a week or so. I have been in Europe for the last two weeks and I am having fabulous time. Internet availibility is scarce or very, very expensive (up to 1 euro a minute).
ajbaker is offline Find More Posts by ajbaker
Old Sep 20, 2010, 03:55 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
Flyvertigo,
Thanks for the idea to remove the washers.
AJ,
Sorry, it was Al Gore who invented the internet.
Hurry home, we miss you.
Bill
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
