[QUOTE=ozair;19458285]
Lastly, (less thrust)....got it on backwards? Oh, and....no such thing as a pusher prop on a brushless motor (presumig that's what you've got); motor direction is reversible. (Page 1 is highly recommended reading - maybe you didn't see the sign on the door? It's our motto in fact. A must. De riguer. Or they'll boot you off the island. Well, not me, per se....but watch out for that 'G' guy.) |
Hope it comes through ![]() ![]() Jerry ( Sayers1 ) |
Your motor angle looks fine. In all the excitement of the maiden, did anyone check to see if the elevator servo was reversed on the TX? Remember, back of the elevator goes up when you pull the stick back.
Just kiddin'. I'm stumped. Got another prop you can try? That's not the stock one, is it? |
not reversed.sure when I find out what wrong it will be something stupid I did![]() Jerry ( sayers1) |
![]() ![]() ![]() (Good catch, really. After seein' the motor's ok, I'd almost bet on ya.) |
![]() ![]() ![]() No not stock prop APC 6X4E drilled out to fit stock hub ( have a prop addapter for it but can't get the stock one off. I know read the first post's in this thread & it tell's how BUT still won't come off. ![]() Jerry |
Hey, you got any way of measuring how much thrust you're getting? Got a gram scale? Any kind you can set on the floor, we'll make do. Put the plane straight up & down with its nose on the scale & zero it, & while lightly holding the fuse just in front of tail feathers, have someone run motor up to full throttle long enough for you to read the weight the scale's showing. Fully charged battery. Careful - don't let the prop bite ya! Tell us that & which battery, I'll run a test & see how they compare. |
Joined Sep 2011
haha ! no ! Quote:
PS : english is not my mother language
Bottom of wings and tail parallel to each other? Ailerons centered nicely in the neutral position? Have you tried a power off glide test over some tall grass to check the airframe? I know you know all this but sometimes covering the basics leads to finding a problem we all have over looked.
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
