Old Sep 28, 2011, 10:16 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I still prefer Eagle Tree Systems
Originally Posted by StarHopper44 View Post
Have any of you guys used this in-flight voltage logger?:
http://www.hobbyking.com/hobbyking/s...dProduct=10348
Tho it's branded Hobby King, it's the same Model 'L1' logger made & sold by AEO RC, so what I'm wanting to find out would apply to either one.
I think you meant AERORC.com??? Maybe??
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 28, 2011, 12:37 PM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Originally Posted by ozair View Post
All I know is that I would have a bloody hard time trying to cut my ears off with nuts.
Mmmm... It's the other way around that gives me the willies.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Sep 28, 2011, 01:32 PM
elequin is offline
Find More Posts by elequin
Germany, BY, Nuremberg
Joined Sep 2011
Originally Posted by ua3xds View Post
Well we call those sticking out things 'ears' over here.
By the way the plane in the Czech review is normal Bixler not the one from the elequinís pictures.
That's true - the one I got has a clear canopy, and a totally different nacelle.
BTW, the ESC seems quite configurable. It's configurable for brake setting, battery type, low voltage cutoff mode, low voltage cutoff threshold, startup mode (normal/soft/super-soft), and timing.
I'm wondering, does anyone have a recommendation on the timing? I guess that'd be difficult, not knowing this particular motor (don't know if it's different).
Also, kinda weird (and probably a newbie mistake), but I bound it to my TX tonight, and ALL of the controls were reversed except for the throttle. Is this normal? I reversed on the TX and now everything is ok, but maybe I made a newbie mistake?
elequin is offline Find More Posts by elequin
Old Sep 28, 2011, 01:48 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
AJ
Nope....AEO RC (the circled star in their logo is actually the 'O')
http://www.aeorc.cn/english/?product-279.html
Now, when ya get there, compare their 'sale' price to the $TwennyBux I bought mine for this morning. Delivered.
I'm impressed by the EagleTree system....but from what I know (little) you buy that, then ya gotta buy all those sensors separately, yada yada yada....and the price gets way on up there. And eg, search HK for EagleTree and they only have that & the $81 HvyDuty unit....is all I saw & I don't even know where to get the sensors & other accs from.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 28, 2011, 01:52 PM
elequin is offline
Joined Sep 2011
Beta 1400 (Czech)
Ok, so I decided I needed to remove the top of the nacelle and take some photos. Um, isn't the SS usually an inrunner motor? This is an outrunner!
You can also see the metal screws along the top of the fuse.
Old Sep 28, 2011, 02:00 PM
Earthbound Skyhound
Joined Jun 2011
Originally Posted by elequin View Post
...Also, kinda weird (and probably a newbie mistake), but I bound it to my TX tonight, and ALL of the controls were reversed except for the throttle. Is this normal? I reversed on the TX and now everything is ok, but maybe I made a newbie mistake?
Where your servos plug into the receiver, is the darkest wire(s) - be they brown or black* - facing the nearest end of the receiver? Should be.
*(they're the ground wire of the 3)
Old Sep 28, 2011, 02:08 PM
elequin is offline
Joined Sep 2011
Where your servos plug into the receiver, is the darkest wire(s) - be they brown or black* - facing the nearest end of the receiver? Shouls be.
I tried reversing the servo plugs on the receiver, and then none of them would move at all.
Old Sep 28, 2011, 02:16 PM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Of course they will not. As the Star Shopper said the black wire is negative and will only work when plugged in the correct way.
Also it could be normal for the servos be reversed as it would depend how they were installed.
You took the simple option by reversing then with the TX.
Flypoppa is offline Find More Posts by Flypoppa
Old Sep 28, 2011, 02:34 PM
elequin is offline
Joined Sep 2011
Ah ok, thanks. That makes sense. I guess the servos were installed reversed, at least for my RX...(?) Ah well, it works now.
Old Sep 28, 2011, 03:09 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Look up E-logger and the newest V4 should be there. It may show $70 or so but if you're a platinum member, you can get it with the integrated connectors for $47. That's almost 20% less than buying from TowerHobbies or from ET directly.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Sep 28, 2011, 03:21 PM
protocol is offline
Find More Posts by protocol
watch the skies
protocol's Avatar
Canada, ON, Toronto
Joined May 2011
fwiw, Hobbypartz.com carries it as well, but OOS, and priced a little more than HK. I might pick one up if they get it in, or in my next HK order:
http://www.hobbypartz.com/88e-aevr10...-analyzer.html
protocol is offline Find More Posts by protocol
Old Sep 28, 2011, 03:26 PM
Papo_60 is offline
Find More Posts by Papo_60
USA, NY, Endicott
Joined Oct 2010
PayPal
Slightly OT but I am trying to buy some of the order for my SS.. I have tried a few times to pay for my HK order using PayPal. But when I get to the point where I need authorize pay through Paypal, it never completes the transaction??? Today I was ordering my next plane, a T-28 from Nitroplanes & the same thing happened. I am suspecting it may have something to do with completing the transaction through China??????
I use PayPal all the time on other sites with no such problem. Anyone else ever have or heard of this problem???? If so, would appreciate a PM. TIA
Ron
Papo_60 is offline Find More Posts by Papo_60
Old Sep 28, 2011, 03:33 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
The earlier versions were designed for inrunners. Yours is obviously not. It is meant for an outrunner from the start. I like the way they have run the motor wires down right away instead of going forward above the wing. It certainly looks related to the V1 and V2 models, but it is far different. Might be the V3 after all. Or from another manufacturer altogether, but I doubt that. I notice that, on the sight linked to earlier (http://www.rcm-pelikan.cz/index.php?...oduct&id=46837), the overall view is V1 yet all the smaller detail views are the latest. I can see from one of those views that the top half of that nacelle seems designed to be removable. A good idea. As far as the wing securing method goes, I like it. If you don't hit things with it is won't break. If you do, use glue.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 28, 2011, 03:44 PM
bhavikshah is offline
Find More Posts by bhavikshah
United Kingdom, England, London
Joined Feb 2009
2836 2350kv
Hi guys.
My very first post. Excellent forum and great people around. Have been reading the forums for a while now. Complete newbie to the hobby but have been interested in planes and rc stuff since childhood. would have been into the hobby much earlier if it was not for med school. anyhows, my first few steps....
Finally spent a bit of cash on a bixler kit.
What i'm worried about is the motor that I have ordered. Its the turnigy 2836 2350. I have read earlier dicussion about the motor but it appears no one has tried it yet. I wonder why. is it no good? Will i be able to mount it with minor mods to the pod?
Your advice would be much appreciated.
bhavik
bhavikshah is offline Find More Posts by bhavikshah
Old Sep 28, 2011, 05:54 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Thanks for the photos elequin, that nacelle is now great for trying different motors without too much trouble, a lot more thought has gone into the design of this one than the V1/2/Bix. I also think that the wing mounting method is good, very convinient.
Both V1/2 and the Bixler are outrunners, the innrunner is only a modification that many have made as they were not happy with the stock outrunner.
As a matter of interest what is the CG stated in the manual for this one?
Can you confirm who the manufacturer is, is it J-Power from China, someone else from China or a Czech manufacturer?
ozair is offline Find More Posts by ozair
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
