Old Sep 26, 2011, 08:27 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by snookfin View Post
Has anyone cut the wings down on their SkyS? I'm thinking about removing the last 6" or so from each wing tip. Cutting it straight to the outside edge of the aileron.
I figure this will cut down on the stability, but I'm hoping it will allow the plane to roll better. Thoughts?
I haven't seen it done on this plane but it's been done on other, similar designs. The plane will roll like high speed drill.
Have fun.
Prof100 is online now Find More Posts by Prof100
Old Sep 26, 2011, 09:13 PM
Jerry Campbell is offline
Find More Posts by Jerry Campbell
Jerry Campbell's Avatar
United States, OR, Blodgett
Joined Apr 2011
Tail Assembly ?
Hi Friends,
I've looked thru this thread but if the info is here I missed it.
I'm hoping there is a way to assemble the tail on a Bixler so it can be taken apart for transport. Has anyone found a way to do that?
Jerry
Jerry Campbell is offline Find More Posts by Jerry Campbell
Old Sep 26, 2011, 09:46 PM
Prof100's Avatar
Joined Jul 2007
Originally Posted by Jerry Campbell View Post
Hi Friends,
Jerry
Jerry,
If you used the thread search function and searched for "removable tail" you would have found this video. At 52 seconds you see the removable tail.
HobbyKing Bixler aka SkySurfer Mods, Maiden and Reboxing (8 min 3 sec)
Old Sep 26, 2011, 09:47 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Originally Posted by StarHopper44 View Post
Well, one woohoo for the day at least -- found out what's wrong with my Vado-cam!
Firmware upgrade fixed it right up! *knock knock*
Looking for some ideas (serious only, please) on how-to-film flights hands free....reason's hopefully obvious. What kinda rigs you guys rigged up??
BIG thanx in advance.
Here's what I do. It's my hat cam using a Jazz HD camera. I'm uploading a shot right now of my maiden but unfortunately, I forgot to check the camera angle beforehand so it's pointing a tad low. I can adjust the camera angle pretty easily.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Sep 26, 2011, 09:54 PM
Prof100's Avatar
Joined Jul 2007
Inquiring minds want to know how you keep your hat from tipping forward with that 5.5 ounce camera hanging off the front of the bill of the cap. I have a couple of Jazz HD cams too, but darn, you are defying physics unless you have the back of the cap hooked to your shirt. Please explain.
Old Sep 26, 2011, 09:55 PM
johnwohl is offline
Find More Posts by johnwohl
United States, ND, Fargo
Joined Aug 2007
when replacing the control horns on the ailerons with new dubro ones, the pins on both stock clevis' broke. i've tried twice to get replacements from my lhs with no success so far (both too large an opening for the wire). does anyone know what size or part # the replacements would be? my LHS stocks dubro and great planes hardware.
johnwohl is offline Find More Posts by johnwohl
Old Sep 26, 2011, 10:43 PM
Prof100's Avatar
Joined Jul 2007
What do you mean by "pins"? Dubro come with screws. If you mean screws I have never seen them sell control horn screws. You'd be better off just buying some new packages of control horns.
Old Sep 26, 2011, 10:55 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I think he meant the pin in the clevis.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 26, 2011, 11:05 PM
Prof100's Avatar
Joined Jul 2007
AJ
AJ,
I want a refund on my speed reading course. I missed the magic word clevis.
Bill
Old Sep 26, 2011, 11:20 PM
johnwohl is offline
Joined Aug 2007
i don't know if I'll be able to make it to the hobby store tomorrow so I took the clevis' that were too large at the connection with the threaded control arms and filled the holes with epoxy. i'll wait until morning and hopefully I should be able to thread the control arms through the epoxy, and if needed, put a bit fore and aft to hold thier position after adjustment. i'll let you all know if that works. otherwise, please let me know what other clevis' will fit properly.
Old Sep 27, 2011, 02:18 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by Papo_60 View Post
Only reason I can think of for why you would want to reverse a motor shaft is if you cut it to reduce overall lenght you may want to have the factory finished end out front to fit the prop over??? Is there any other reason that would be helpful to know about???? TIA
Ron
Edit: I saw in some later posts that reversing the motor shaft will change the motor to a pusher, & another post says the Turnigy IIRC motor, has to be reversed. If the motor is BL, can't you just reverse the motor direction by reversing two leads???
There most be an advantage to reversing the shaft but not sure exactly why? Also, why do some motors make this a must if you are going to use it as a pusher?? Thanks again,
Ron
I think it's usually necessitated by which end the mounting's on & type of mount used (or needed to fit the vehicle) -- ie, so you can mount one end & have output shaft coming out the other. It's prolly more applicable to RC cars & such than planes.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 27, 2011, 02:20 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
It's close, but you can see a sliver of the blue background between the black & orange, so there's a gap in there....& look carefully & you'll see where the removed red crosses under the black so, might be perspective & could'a been better drawn but I think it's right. Compare to relative positions of the 2 black wires (see blowup):
Shouldn't confuse anyone anyway....all ya do is remove the red & just leave other two in place where they are.
You know, I am starting to loose faith in Castle. Now that you have blown that image up I can see that they have the ESC plugged into channel 1 on the receiver! You would think they would be a little more accurate with their illustrations.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 27, 2011, 02:39 AM
Earthbound Skyhound
Joined Jun 2011
You don't wanta lose the adjustability of your clevis, so get some pushrods with threads that'll fit the closest-size DuBro clevis your shop has, & clip the other end of the rod off to appropriate length to enable this trick.
You'll prolly have to clip off your old rod too. Slip a section of heat-shrink tubing on the rod, add some CA, slip the new rod alongside & slide the tube up to cover both, & heat it. This guy is using an 'L' bend rod to make rods out of carbon fiber rod, but it shows the principal:
How To Make a Carbon Control Rod (4 min 52 sec)
Yassir....that's the principal of the local high school thair, showin' the principle I's talkin' about.
Old Sep 27, 2011, 02:45 AM
Earthbound Skyhound
Joined Jun 2011
Gord
I do....DO, Ah say, b'lieve that's just for illustrative purposes, like sayin' 'Socket A' & 'Socket B'. And a 2-ch receiver? From Castle? C'mon!
Old Sep 27, 2011, 03:00 AM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Ron
Ron
Ron it is all to do with how you wish to mount the motor. Obviously in any motor the rotating part where the 3 control wires come out of MUST be fixed and stationary otherwise you are in real trouble. This becomes a primary constraint when mounting.
Now does the shaft of the motor you wish to mount come out of the cable end or the other end and how do you want to mount the motor inside the nacelle(fuse) or outside?
They say a picture tells a thousand words so below the gold motor is mounted outside the nacelle whilst the black motor is mounted inside the nacelle. Now what happens if you want to mount the gold motor inside the nacelle and the black motor outside the nacelle. The only way to do this is to reverse the motor shafts given the mounting system that I have.
Hope this helps.
ozair is offline Find More Posts by ozair
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 7 Aug 23, 2016 09:41 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
