http://www.youtube.com/watch?NR=1&v=D4UKWvTHX1I Different guy, longer version:
Joined Jun 2011
Hey guys,
Two questions: 1. Are people using prop savers on their Bixlers or not really needed since this is a pusher prop? 2. Any links for adding gyros to a Bixler? Thanks, Steve www.ilovefpv.com |
[QUOTE=StarHopper44;19425036]Check this, see if it'll be a help:
http://www.youtube.com/watch?NR=1&v=D4UKWvTHX1I Different guy, longer version: Thanks SH, but Captain Atomics(CA) version is much better than RCFoamFighters(RCFF). CA gives proper details on grub screw and C-clip but RCFF do not. |
Anyway, this so called young checkout clerk just did not want to hurt your fealings mate.
United States, CA, Sebastopol
Joined Dec 2010
I'm tall, handsome and was a serious cyclist at the time. Chicks dig me. I'm also modest. It was also in Santa Cruz, CA., where "natural" age is preferred. |
![]() And only girlies (or imitations) try to tell a guy how he oughta be dressin' out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
P.S. Is the cir clip really needed? Not if you have grub screws. P.P.S. The Bixler motor has not got a cir clip. |
Joined Oct 2007
My standard Bixler BL motor HAS a cir clip, no grub screws. I was going to replace the motor shaft with a 3mm hardened drill blank, but found that the original shaft is a press fit to the 'bell' of the motor and not easily removed, i.e., without probable damage to the bell itself. I ended up simply cutting off the orignal shaft at the point that it steps down from 3mm to 2.1mm and used a collet style 3mm prop adapter.
| Thread Tools | |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 5 | Feb 05, 2010 06:57 PM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
