Old Sep 25, 2011, 06:40 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by Alpha35 View Post
10,000,000,000,000,000,000,000,000,000,0 00,000,000,000,000,000,000,000,000,000,0 00,000,000,000,000,000,000,000,000,000,0 00,000,000,000
Uhhhh....is that binary, or Arabic?
There's only 10 kinds of people that understand this stuff, y'know.
Those who speak binary & those who don't.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 25, 2011, 06:50 AM
Earthbound Skyhound
Joined Jun 2011
[QUOTE=Papo_60;19413806]SH, not sure if we are on the same page or if I misunderstood you above. What I am saying is if you use the 3 wire bullet connectors shown below from HK for both the motor & ESC wires, then you do not need to unplug\replug any 2 wires. All you need to do is unplug the bullet connectors, rotate one connector 180 degrees & replug. By doing this, the 2 wires outside wires of the connector being rotated get reversed & the motor should run in the right direction.
OH! OK, I see where you's coming from. You were talking plugs, & I was talking connectors only.
Tho they add a bit of convenience, I couldn't see the justification for using those things however. Motors are usually a pretty permanent installation, so there's not that much convenience provided, considering the very few times that kind've plug would be utilized. Seems the time to solder 'em in place - & both halves - would take longer than you'd ever save over swapping out the 3 wires one-by-one. Then there's the added expense, the weight. Nossir....just can't see it.
Old Sep 25, 2011, 06:55 AM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Maybe V3 SS/Bixler???
Check this out boys.
http://www.hobbyking.com/hobbyking/s..._EPO_PNF_.html
ozair is offline Find More Posts by ozair
Old Sep 25, 2011, 07:07 AM
Earthbound Skyhound
Joined Jun 2011
Originally Posted by Gordks View Post
I can't imagine anyone ever forgetting the heat shrink tubing! But on those occasions when I have done that ... Good stuff.
Gord
You got an honest-to-gawd belly laff on that one, Gordo! Good way t' start the morning!
Yeah, I started to mention it comes in colors....but thought anyone shopping for it would surely find that out.
Can't think of a reason you wouldn't be able to get it in UK, but do know there's always that 'banned substance' thing so, y'never know.
From the amount of interest (responding posts) it looks like this has been a good tip. Glad to see that. Even better to know [the collective] "I" ain't the only one that's committed that folly, no? *LOL* We need to find a name for the omission act....make it a classic! The Bootoob Effect?
(Kinda fitting *ahem* it's a palindrome.)
Old Sep 25, 2011, 07:58 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Originally Posted by Papo_60 View Post
SH, just want to pass on some interesting info on my SS that I got from BH.
1) The male connectors on the motor wires were much smaller than 3.5mm, maybe 2mm max... I replace them with the 3.5mm bullet connectors from HK.
2) The motor leads on my BH SS were only 3" long. Had to pull them out through the opening at the bottom of the nacelle. I added enough wire (about 14") to fish down the channel & into the fuse. They were long enough so my wires ended up outside the canopy like yours to make the connecting process easier....
Not sure if all BH SS come with the "very" short motor wires but mine did & thought it was worth passing on to the group...
Ron
My SS was the same way on all counts. With mine, after I replaced the ends with 3.5's, I made an extension cable longer than I needed to reach the nose rather than adding onto the existing wires.
Also, I did not have any XT60 connectors to solder to the ESC when I got the plane so I just soldered the bullets on the ESC/battery wires. I still haven't gotten around to changing and it works fine as long as you make sure to color coordinate.
jrjr is offline Find More Posts by jrjr
Old Sep 25, 2011, 08:00 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Originally Posted by starhopper44 View Post
uhhhh....is that binary, or arabic?
:d:d:d
01000010 01101001 01101110 01100001 01110010 01111001 00111111 00100000 01111001 01101111 01110101 00100000 01101101 01100101 01100001 01101110 00100000 01101100 01101001 01101011 01100101 00100000 01110100 01101000 01101001 01110011 00111111
Old Sep 25, 2011, 08:06 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Very funny but a bit rude. There are young children that visit this thread.
Flypoppa is offline Find More Posts by Flypoppa
Old Sep 25, 2011, 08:08 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Ahhh so you are one of the ones that do NOT understand binary.
Old Sep 25, 2011, 08:11 AM
guroos is offline
Find More Posts by guroos
guroos's Avatar
Australia, NSW, Sydney
Joined Aug 2011
There's just ten things I don't understand about binary:
1. 0
2. 1
guroos is offline Find More Posts by guroos
Old Sep 25, 2011, 08:12 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
1. 0
2. 1
Thats only 2
Old Sep 25, 2011, 08:17 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
That illustration shows the external BEC plugged into the receiver with the signal and ground pins reversed! 'Tain't gonna work that way. Other than that it's a great illustration. Even shows the red lead pulled on the esc to receiver connector.
Gord
That pic was right off Castle Creations web site too. Never noticed it. Good job. I went back and fixed the pic as not to confuse StarStomper.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 25, 2011, 08:18 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Originally Posted by makind View Post
Im having the same motor, but im waiting for the plane since June. :-(
The motor will not fit inside the foam compartment?
This motor will fit inside the motor compartment(nacelle). In the photo below the top is the stock BL attached to the ply spacers (V1) and the bottom is a similar 2600 KV motor attached to the plastic spacers (V2).
Alternatively you can use the method suggested by jj604.
With my existing set up I found it more convinient to mount outside the nacelle, in the not too distant future I will mount it inside as well and see if there is any noticable difference in performance.
Old Sep 25, 2011, 08:22 AM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
This is such a great thread to participate in because on top of all the valuable information and knowledge one acquires you also get great entertainment value from the likes of Gene, FP and others.
Old Sep 25, 2011, 08:46 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Oh yes it is good entertainment at times.
I just had a PM accusing me of calling a party rude. I SAID THAT THE MESSAGE WAS A BIT RUDE. NOT THE PARTY PERSON.
Old Sep 25, 2011, 08:49 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I wonder if they do something like that in the UK? I shall have to do a Google. (I know what that is).
You do?
Prof100 is offline Find More Posts by Prof100
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
