Old Sep 11, 2011, 06:30 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by 2500GENE View Post
If side thrust was critical on our SS or Ez's then those using pusher props would have a problem since they need to reverse the motors rotation. ................
The light bulb just went on. Thanks for bringing that up. I had completely overlooked it. I will have to get a pusher prop and try it to see if I can see the difference. And, to my surprise, the little black prop I got in the kit is not a pusher prop. I would have expected them to include a pusher.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 11, 2011, 07:02 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Gord
Pusher props are for models that use 2 motors to offset torque. One prop is a normal and the other a pusher, like a Multiplex Twin Star. They work fine on our type set ups but are not necessary.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 11, 2011, 08:20 PM
forevercat is offline
Find More Posts by forevercat
*crunch*
forevercat's Avatar
United States, CA, Saratoga
Joined Aug 2010
tempted to order a SS (bixler) from hobbyking for aerial video purposes. could this carry a GoPro hero camera with an 1600 mah 3s on the stock brushless setup? thanks!
forevercat is offline Find More Posts by forevercat
Old Sep 11, 2011, 08:31 PM
squishy654 is offline
Find More Posts by squishy654
squishy654's Avatar
United States, CA, Sacramento
Joined Jun 2010
flying my bixler around
Bixler, beginner RC airplane (4 min 23 sec)
squishy654 is offline Find More Posts by squishy654
Old Sep 11, 2011, 08:44 PM
moon12 is offline
Find More Posts by moon12
United States, TX, Harlingen
Joined Sep 2009
UPDATE: Bixler off the water
a short vid of bixler water take-off and landing:
Bixler water take off and landing (2 min 19 sec)
video from the plane:
Bixler off the water (5 min 48 sec)
This is a great little versatile plane!!
harry
moon12 is offline Find More Posts by moon12
Old Sep 11, 2011, 09:07 PM
jj604 is offline
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Harry, what floats did you use?
Any pictures of the set up?
John
jj604 is offline Find More Posts by jj604
Old Sep 11, 2011, 10:42 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Here is great article on Electric Flying by Ken Meyers who flies at my Flying Club.
Enjoy.
http://homepage.mac.com/kmyersefo/e-...-basics.htm#TX
Prof100 is online now Find More Posts by Prof100
Old Sep 12, 2011, 02:33 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Motor cage and wing housing failure !!
Hi ...
I have the kit version of the Bixler, and I've seen some photos of Motor cage and wing housing failures ..
1- Is the 3M extreme fiber tape enough to prevent this when used to cover the whole wing housing and motor cage sections ??
2- Do I need to implant CF reinforcements from the inside to make sure this section is solidly attached tot he fuselage ??
I'm gonna use my Bixler for FPV... and I want to use the CF material wisely to avoid noise and interference issues
Thanks a lot for your help
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Sep 12, 2011, 03:36 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Originally Posted by preston91 View Post
my canopy has come off during the last 3 launches after about 100 flights ( don't know whats going on. but as a result my motor shaft is bent so I need a replacement motor. Banana hobby wants $25 plus $15 shipping for $40 total!!. can I get a comparable motor somewhere else cheaper??
thanks
Paul
See post 8018. This is the replacement motor that I use.
Flypoppa is offline Find More Posts by Flypoppa
Old Sep 12, 2011, 04:14 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
Ive upgraded the supplied control horns to these.
joel0407 is offline Find More Posts by joel0407
Old Sep 12, 2011, 04:18 AM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
I still have a bit of setup to go and I'm still waiting for a Eagle Tree Guardian Stablizer.
Old Sep 12, 2011, 06:30 AM
andybris is offline
Find More Posts by andybris
Joined Jun 2011
cg for bixler arf 2200 battery
looking for cg for bixler with 2200 battery?
andybris is offline Find More Posts by andybris
Old Sep 12, 2011, 07:05 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
CG is no different regardless of the battery you use.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Sep 12, 2011, 07:41 AM
andybris is offline
Joined Jun 2011
so cg is?
Old Sep 12, 2011, 08:11 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Originally Posted by andybris View Post
so cg is?
Page 1/ post 2/Assembly Tips and Build Logs
jrjr is offline Find More Posts by jrjr
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
