Old Sep 10, 2011, 08:55 AM
WombatControl is offline
Find More Posts by WombatControl
WombatControl's Avatar
Joined Jul 2011
Originally Posted by erkq View Post
The Bix comes with a motor and prop, and a nice one for being an el-cheapo IMHO. Yes, Dubro horns. And, get the Dubro press-on things that attach the control rods to the horns. The stock ones screw on instead of press on and I lost the rudder (fortunately not the elevator). I've been using those since 1979 and haven't had one let go yet. But I also use Locktite Blue on the set screw that holds the control rod.
For the hinges, I just used Blenderm. You can get it at your drug store or get "hinge tape" from Dubro. They slap their name and brand on Blendern. Tape is great and so much simpler than cutting in hinges. Just be careful to get it in the bevel of the hinge. I use a tapered pencil eraser to press it in. After writing all this, I think the first page has all this stuff?
You can also use 3M Extreme Packing Tape - which also can be used for reinforcement of the nose and the bottom of the fuse. It has fiberglass weaves into it - you have to be careful about flexing all the hinges so the tape doesn't restrict their movement, but that stuff is probably stronger than the foam itself...
WombatControl is offline Find More Posts by WombatControl
Old Sep 10, 2011, 09:09 AM
Papo_60 is offline
Find More Posts by Papo_60
USA, NY, Endicott
Joined Oct 2010
Originally Posted by StarHopper44 View Post
Nacelle?
nacelle [[nuhˈ-sel] n
(Engineering / Aeronautics)
1. a separate streamlined enclosure on an aircraft, not part of the fuselage, to accommodate an engine, passengers, cargo...etc.
2. the car of a balloon.
[from French: small boat, from Late Latin nāvicella, a diminutive of Latin nāvis ship]
Thanks fella, that's it. Kinda hard to do a search for something you completely forgot how to say or partially spell>>>> Thanks again,
Ron
Papo_60 is offline Find More Posts by Papo_60
Old Sep 10, 2011, 09:25 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
The problem with Extreme (as I see it) is its inherent thickness. It 'bumps' into itself in the hinge channel, restricting the available range. And it's kind've ugly. *LOL*
The advantages of Blenderm are several. First, it's barely over skin thickness and has a smooth finish. Much more flexible in any axis. Less stressful on the servos. It practically 'flows' down into and back up out of the hinge crevice. Sticks like skin, but removes easily if you want to (repositioning, replacing) without tearing away any foam -- I don't think its adhesive is a 'curing' type. The hardest part about it is gettin' a fingernail under a corner to peel it off - it lays that flat & smooth! And lastly, once applied & smoothed down, it's barely above invisible.
Just my 2, but I'd use Blenderm over Extreme (or anything else I've found thus far) 100:1 for hinge tape!
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 10, 2011, 09:30 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
+1
I like it too
jrjr is offline Find More Posts by jrjr
Papo_60 is offline
USA, NY, Endicott
Joined Oct 2010
Meanwhile, kinda OT but very relevant - re prop testing. For various motor/power etc data I know about watts & current draw & all that. But what kind've instrument is used for measuring thrust? And where, relevant to the plane or test bed, is whatever kind of sensor they used placed to take the readings? Is the sensor a pitot tube, or some kind of 'sail' arrangement, or what?? Any of you guys got this kind've stuff, and (with a po' boy's economy in mind) can make some recommendations for a testing setup?
TIA!
SH, here is some discussion on measuring thrust from another RCGroups thread. Looks kinda easy just using a digital scale. The motor & scale are attached via a piece of wood with the prop reversed (Post #3).... Guys seem really nice & supportive in this thread (even though posted awhile back), must be an RCGroups thing.....
This is a video on YouTube showing a similar setup but with a hanging scale:
Hope it helps, looks quite simple to setup & (hopefully) meets your po' boy's economy criteria???
Ron
Old Sep 10, 2011, 09:58 AM
Earthbound Skyhound
Joined Jun 2011
Ron
Yeahhhh, I know whut'cha mean. There's this word I can never remember when I need it.
It's .................................................. uhhhhhhh........
Oh, nevermind.
Old Sep 10, 2011, 10:24 AM
Earthbound Skyhound
Joined Jun 2011
Ron
Okeydoke.....I've got the idea now, so that'll do, guys. Unless someone knows a completely different, ie 'more standardized' method. If anyone has something else to add, please do it thru PM.
I'm shooting for being able to publish numbers like "With 'X' setup you'll get ## grams or oz of thrust" and the user can count on getting that number.
I'll have a look in that thread, & in UToob....see what else they might do.
One thing I wanta be able to do is use the plane itself as a testing vehicle. I see I can strap it to an easy-rolling deck on a smooth flat surface, with a loop to tie my scale (got one) onto....should be good to go.
THANX, y'all!!
Old Sep 10, 2011, 10:49 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I agree. Blenderm for hinges for all the reasons SH put forth... you just don't need the strength that 3M Extreme offers at a hinge. And then use 3M Extreme for reinforcements for landing. I WAS going to put it on the underside of my wings too to help keep them from flexing up, but after CA'ing CF strips into them they don't need nuthin' else! They are concrete... well... almost...
erkq is offline Find More Posts by erkq
Old Sep 10, 2011, 11:19 AM
khaled_abobakr is online now
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Does this look right to you ??
Hi ..
Your advice is greatly appreciated .. Does this look right to you ??
1-The motor angle ?
That angle is due to the stock form of the foam inside)
2-The motor mount .. ?
Shall I take two pieces so the motor gets inside a bit ??
Thanks a lot
Khaled
khaled_abobakr is online now Find More Posts by khaled_abobakr
Old Sep 10, 2011, 12:10 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by khaled_abobakr View Post
Hi ..
1-The motor angle ?
Thanks a lot
Khaled
1 That is the way it is meant to be, a good bit of both side thrust and down thrust built into the nacelle. (good word - thanks Starhopper)
2 The number of disks depends on the length of your motor. I put in three of those disks so that my motor just peaks out on one side. But it doesn't need to. I think two disks would have worked just as well. I have just 2mm clearance between the 6 inch prop and the top of the fuselage. Moving the motor forward (and down) would reduce that clearance slightly. But I wouldn't think it would be enough to cause interference. If there were slight interference it wouldn't last long. There would soon be a perfectly placed clearance groove in the top of the fuselage.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 10, 2011, 04:37 PM
Earthbound Skyhound
Joined Jun 2011
Gord
I would kindly disagree there, in part. Down thrust built into the nacelle, yes - and I believe endemic to the species....but side thrust, no. The nacelle has little to naught to do with side alignment - that's almost entirely motor mount positioning.
I believe that side-alignment is more happenstance and depends almost entirely upon the sloppiness of the assemblers at the factory. I'd hazard they squirt in some hot glue, plop a pre-assembled motor-&-mount into the glop with barely a glance towards alignment & move on to the next one, leaving the motor assembly to settle and cure wherever fortune leads it.
At least, I can tell you my Bix with a 15" ruler laid along the hull seam falls almost exactly along the entire protruding motor shaft and the corresponding trailing seam along the fuselage top, below. If there's any side thrust, it's less than a degree......and I'll note she flies straight without a notch of side trim required.
And I realize I might be in the distinct minority with that....but I got one of the lucky ones.
Old Sep 10, 2011, 06:04 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Hi ..
1-The motor angle ?
Thanks a lot
Khaled
You don't need to use the wood disc for a inrunner. They are for mounting a outrunner with long screws keeping the motor outside the nacelle, like the stock bl is. You can use Goop, epoxy, double sided carpet tape and a host of other adhesives to hold the motor in the nacelle. Insert the motor 3/4 to all the way and lock it down straight (left/right) and on the angle of the nacelle.
I assume that's a 2200 inrunner so you will use a 6 inch prop so clearance isn't a issue.
Is that a pusher prop? APC ep version?
2500GENE is offline Find More Posts by 2500GENE
Old Sep 10, 2011, 07:14 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I have used both. I prefer the Extreme tape. If it is too ugly for you then paint it.
There is a third tape which is 3M Storage tape. It's used routinely on 160 mph Ritewings for hinges. It's plus is it's very UV resitant if you store your planes in sun light.
Prof100 is online now Find More Posts by Prof100
Old Sep 10, 2011, 08:59 PM
Ole Joe is offline
Find More Posts by Ole Joe
Joined Oct 2007
[QUOTE=StarHopper44;19280103]I would kindly disagree there, in part. Down thrust built into the nacelle, yes - and I believe endemic to the species....but side thrust, no. The nacelle has little to naught to do with side alignment - that's almost entirely motor mount positioning.
The nacelle has "everything" to do with the alignment of the motor if it is installed correctly. I've have both a version 1 and 2 fuselage sitting in front of me and it is obvious to the most casual observer that the motor should have both down and side thrust due to the way the foam mounting lands internal to the nacelle are molded. I've also got both a Turnigy 2835 (inrunner) and the standard BL motor which comes with the SS. It is possible to install the standard BL motor which comes with the SS to have no side thrust due to the way the plywood motor mount is made. Matter of fact, you can rotate it in the nacelle to have either right or left thrust. If the 2835 is slipped into the nacelle it will definitely have side thrust to the left, (viewing from the back side of the prop) no matter how you rotate it in either version 1or 2 fuselage.
You got one that was assembled wrong but still flys OK, consider yourself lucky.
Ole Joe is offline Find More Posts by Ole Joe
Old Sep 11, 2011, 12:50 AM
rcg2020 is offline
Find More Posts by rcg2020
Joined Apr 2011
Will the clone Spektrum AR6100e receiver from Targethobby work with this plane or do I need the full range receiver?
rcg2020 is offline Find More Posts by rcg2020
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
