USA, NY, Endicott
Joined Oct 2010
![]() Ron |
USA, NY, Endicott
Joined Oct 2010
![]() Ron |
The LP used a esc and rx in one unit. Some like it but it has it's problems also. The RX is a 27mhz toy radio. (The BNF version is Spektrum 2.4 compatible) They come with 5 wire servos and only work with its RX/ESC box. (except the BNF) Uses a 480 brushed motor with a gearbox. It's a great flying plane. I have 2 modified ones. One uses a E-Flite park 450 on a DX5e and the other a E-Flite Park 480 on 72mhz. With your experience I would suggest building one from parts. My blog has the directions and part numbers. Only, instead of the brushed set up I would suggest going brushless from the start. http://www.rcgroups.com/forums/showthread.php?t=1214571 Adding ailerons is a common mod that is simple to do. That' enough ot on this thread. We can pick up the discussion over at the SC thread they gave you links to. EDIT: I just saw you were getting it from a friend. Nice. But it will need to be upgrade after you fly it for 10 minutes or so. ![]() Also, as much as I like my SCs, check out the Multiplex Fun Cub also. Comes as a kit with ailerons and flaps. It needs it's upgrades too but another nice kit. Prof and aj have one. |
USA, NY, Endicott
Joined Oct 2010
![]() ![]() ![]() Ron |
![]() Too bad, I like the way she holds a plane. Found it on Craigs list, WS = 100", and I got it for a song I might add. If only I could carry a tune...... |
USA
Joined May 2010
Thanks erkq.
also, I forgot to ask, can you give me a LINK for a upgraded control hinges/Control horns ie.... Dubro? I read that the included ones' are not safe at all, prone to future failure..... p.s. seems like the inrunner motors (~2000-2200kv) motors are all out of stock???? :-( |
| Thread Tools | |
| For Sale Cyber Sky Parachute (Sky Surfer) | shv2sail | Aircraft - Electric - Airplanes (FS/W) | 6 | May 28, 2013 02:14 AM |
| Discussion Sky Surfer | nickwayne11c | Electric Plane Talk | 15 | Nov 18, 2011 02:36 PM |
| Discussion Banana Hobby Sky Surfer Problems | cavy92 | Electric Plane Talk | 56 | Nov 02, 2010 02:49 AM |
| Question Sky Surfer LiPo mod, help... | Freight Dog | Power Systems | 0 | Aug 17, 2006 01:45 PM |
| Swashplate Assembly with Center Ball; is this the swash with ball mod i want? | tekforce | Micro Helis | 4 | Feb 08, 2004 05:28 PM |
