Old Sep 08, 2011, 07:17 AM
Toffe87 is offline
Find More Posts by Toffe87
Joined Jul 2011
Originally Posted by ajbaker View Post
The ESC in this plane runs too hot IMO. So, I moved it to the outside of the plane. On my next arf, I will probably run it on top of the plane in a nicely cut pocket for it. For this plane, it was the quickest way to do it. I will add this post to Page #1 also. If someone else does it another way, I will add theirs, too.
AJ
I like that way of doing it, this is my way just as you said put a pocket on top. Also cut the channel down for the main wires, the other wires could also be shortend and put into that main channel for the motor wires so its hidden. Just take care of the piece to cover that channel or else you just can leave it as cooling. Using velcro under esc, the wires holds it down good enough but a little extra is always ok
Toffe87 is offline Find More Posts by Toffe87
Old Sep 08, 2011, 07:31 AM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
This plane is specifically designed for FPV (V1 mostly) and that additional weight should not be a problem. Make sure you have a lanyard attached to the motor just in case.
AJ
Heheheheh - not a bad idea actually I was going to mount my future gopro with the servocity pan/tilt on my Skywalker, but I might give it a shot on this first and then save the Skywalker for next spring.
I don't think the 450 or 480 have high enough RPM for this plane though. I can't fit a 11x5.5e onto the Skysurfer (well, I can, but I won't have a tail!) so I need a motor that is good for FPV. I have the stock one which I can try to repair I guess.
banzi28 is offline Find More Posts by banzi28
Old Sep 08, 2011, 07:33 AM
Bob A is offline
Find More Posts by Bob A
United States, IA, Keosauqua
Joined Sep 2010
I bought the eneloop 4 battery charger with 4 batteries plus another pack of 4 batterys for 30 some $. I have made as many as 20 10 min. flights before recharging but usually recharge after 10-12 flights. Anyone know if it's best for max battery life to recharge more frequently? (after 20 flights it took almost 8 hrs to recharge)
Bob
Bob A is offline Find More Posts by Bob A
Old Sep 08, 2011, 08:59 AM
mandevil is offline
Find More Posts by mandevil
mandevil's Avatar
Joined Jun 2011
Which motor
I'm readying myself for ordering parts for building my new Bixler. Unfortunately, I'm still unsure about what motor to use. The original is 2620 at 1950 kV. Since I will be ordering other stuff from Hobby King, I'd rather like to order the motor from there as well. The closest thing I found there is Turning 2826 2200 KV, but that has Imax at 34 Amps, so I would need 40 A ESC. And the power seems to be overkill for this plane, even when it carries GoPro camera. The other suggested option is AXN FloaterJet replacement motor, which seems about right (and has long wire leads, which is a plus).
Is there any other option, preferably orderable from Hobby King?
mandevil is offline Find More Posts by mandevil
Old Sep 08, 2011, 09:19 AM
StarHopper44 is offline
Find More Posts by StarHopper44
United States, NC, Richlands
Joined Jun 2011
Originally Posted by jrjr View Post
And then throw them out after one use.
I have Tenergy AA nimh cells that are 5 years old and still work fine. I do cycle them over the winter occasionally but no rigid schedule... just when I think of it. However, this winter I plan to fly inside. Buy once, use for a loooong time. Can't do that with your alky's. My old matched sub c packs from car racing have turned into receiver packs on larger planes, starter power for nitro planes, etc. They just keep going and going and going.... lol
The thing is, and basically my point here, if a set of 8 lasts 3 months, which I well expect.....even if they only last me 2 months, we're talking about only an $8.16 yearly cost. One use or not*, any way you look at it that just ain't much cost! Plus, I'm not gonna be out there flying EVERY weekend. (Cold weather, rain etc.) Compare that $8.16 to the 1-buy cost of ~$40, and there's your 5-year supply, not even figuring the cost of your recharger into the equation, and the electricity to run it.
*Which they wouldn't be (re one use) as, I swap batteries out of 'critical' appliances while there's still good juice left, & use them to power like, flashlights, clocks...anything with low-energy demands.
YMMV and I got no problems with that....but it works for me!
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 08, 2011, 10:43 AM
dmoshiloh is offline
Find More Posts by dmoshiloh
United States, TN, Oakland
Joined Sep 2008
I can't get the prop adapter off my Bixler. I've tried heating it with a soldering iron, hot water, and even wd-40, but it just won't come off. To those who have been successful, how much force did you have to use? I just don't want to bend the shaft. I'm about ready to drill out the 6X4 prop I have and be done with it.
dmoshiloh is offline Find More Posts by dmoshiloh
Old Sep 08, 2011, 10:50 AM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Did you try the method described on page 1 post 3 item 3?
flyvertigo is offline Find More Posts by flyvertigo
Old Sep 08, 2011, 10:58 AM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
I suppose it is probably a wash as far as cost goes in the long run. The new rechargeables seem to keep going for ever, although that was not the case with some of the older versions. Convenience would seem to be on the side of the standard throw away batteries but that shuffling of batteries from critical use to non critical use sounds like a hassle to me. I would rather just stick them in the charger when they are getting weak and have fresh batteries next time I need them.
The thing that really decides it for me is that I just hate anything 'throw away'. When I think of the energy spent in mining the materials and then processing them to produce the batteries, and then even more in reprocessing them again in recycling (you are not just throwing them in the trash I hope) I just can't use single use batteries anymore. It's a green thing to me. Like you said, YMMV.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 08, 2011, 11:02 AM
Joined Sep 2008
Yes, I tried that after heating the adapter etc.
Old Sep 08, 2011, 11:48 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I have a couple of 72mhz xmitters and planes in the garage that I use to fly my "front yard" evening planes. I have Alkaline cells in them and they are still working after 2+years and 100+ flights. One use..... Hmmmm. I don't think so. That is a little too pessimistic for me.
This is one of those areas that has many "right" answers. All choices have their pros and cons. Personally, for my SkyS planes, I use LiPo's in of my transmitters with a voltage drop diode and a low cell alarm. Down side - When LVC goes off on the liPo, there is no such thing as getting one more flight - with the other choices, I can get at least one more flight. The big upside-I only charge them once a month if I fly a LOT. If I took an average over a year, I charge them (3 xmitters) once every 4 months. I have not tried Enloops or Tenergy yet (I thought they were the same thing). But, there seems to be no downside to them. Maybe someone else knows one.
AJ
P.S. Went flying today. BEAUTIFUL. But, I cannot find my camera or I would have a flight video. I think someone took it from my flight box. As usual, though, "If it isn't on video, it didn't happen".
ajbaker is offline Find More Posts by ajbaker
Old Sep 08, 2011, 12:15 PM
Joined Jun 2011
Grab a 17/64 drill, pop it in your drill press & have at it, dude.
Then balance the prop & slap it on -- there ain't a thang wrong with the stock adapter.
Old Sep 08, 2011, 12:17 PM
Joined Jun 2011
AJ
Was Gene anywhere around?
Old Sep 08, 2011, 12:25 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Good point. I am not sure. But, I am suspicious now.
AJ
Old Sep 08, 2011, 01:02 PM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
Check out www.headsuprc.com. They will take care you WELL.
SARG5
SARG5 is offline Find More Posts by SARG5
Old Sep 08, 2011, 03:21 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
FWIW, regarding "rechargeable or alkaline batteries", I switched 2 years ago to Powerex AA NiMh 2700mAh batteries. I use them in just about everything I own that requires AA batteries including LED flashlights, transister radios, my R/C transmitters, a scanner, two Canon cameras (A-590 IS & SX-10 IS), and two CO detectors. For charging I use a MAHA 8-cell charger that can Fast charge, Soft charge, or "balance" charge 8 cells at a time. I started with the charger and 8 cells and have added 32 cells over the 2 years because I found them so convenient and long lasting on a charge. I would say on average I charge them roughly 5 times per year, maybe more often for the batteries in my cameras and less often for the radios and CO detectors. This may or may not be the least expensive way to go, but I never have to wonder if I have enough alkalines in the house.
aeronca is offline Find More Posts by aeronca
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
