Old Sep 07, 2011, 06:35 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Originally Posted by andybris View Post
Hi,
total newbie here, I just bought a Bixler and forgot to buy glue, can i use a hot glue gun to glue on tail, control horns etc on epp foam? as i already have one.
Sorry if it has all been asked before...
You can, yes however it weighs more than other bonding solutions. Medium CA is said to be the lightest and you could also use Foam Tac (got mine from the net) or Quick Grip from Wal Mart.
jrjr is offline Find More Posts by jrjr
Old Sep 07, 2011, 06:42 AM
captainstack is offline
Find More Posts by captainstack
Joined Jun 2011
So the answer to my post on post number 8293 would be yes its ok?
captainstack is offline Find More Posts by captainstack
Old Sep 07, 2011, 06:53 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Yes you can. It is always a good idea to try and keep the weight down in a plane though. Thus the responses. For a few bucks you can pick up some medium CA and you will find this useful throughout your RC flying hobby - but do as you please..... hot glue will be ok as long as you don't over do it I think.
Watch out storing the plane in a hot car as it can loosen up hot glue.
Old Sep 07, 2011, 06:56 AM
Joined Jun 2011
Oh cool i just picked up a couple of bottles of this
http://www.hobbyking.com/hobbyking/s...idProduct=7173
So should be all sweet?
Old Sep 07, 2011, 07:05 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Haven't tried HK's CA. Let us know how it works out.
Old Sep 07, 2011, 07:15 AM
andybris is offline
Find More Posts by andybris
Joined Jun 2011
i am in Brisbane Australia, so not sure if they are available....
andybris is offline Find More Posts by andybris
Old Sep 07, 2011, 07:42 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Sorry, got you 2 guys confused
Old Sep 07, 2011, 08:27 AM
Spaticus is offline
Find More Posts by Spaticus
Parts of it still up a tree!
Spaticus's Avatar
Australia, VIC, Croydon Hills
Joined Jul 2011
Originally Posted by flyvertigo View Post
I tried every combination with a programming card including different timing.
Anybody have any more ideas?
I'm sure I could fly the plane with the jumpy idle. I'm concerned about eventual failure of the speed controller.
Has anyone used one with this condition?
http://www.youtube.com/watch?v=Ob1a8...layer_embedded
Jim
Not sure if it has been mentioned but if there is a failure in one of your three motor to esc plugs or the solder has broken down the pulsing will occur. I would check these linkages for continuity.
Mark
Spaticus is offline Find More Posts by Spaticus
Old Sep 07, 2011, 10:17 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
... and you could also use Foam Tac (got mine from the net) or Quick Grip from Wal Mart.
By the way, JrJr....that instruction on the Foam-Tac's back label that says (after spreading on both parts) to "3. Allow surface to air dry for 10-20 minutes..." is DEFINITELY a booboo! It should say 10-20 seconds, as evidenced by its actual use.
Someone asked this before; don't remember seeing an answer then but I hadn't received mine at the time, to try. Wind blew my Bix off the table Sunday & broke off the tip of the right horiz-stab's trailing edge. Dab o' Foam-Tac = good as new, & we were flying it <10 minutes later.
I also used it to tack my Bix's extension-tube (from spray can) rudder pushrod guide to top front edge of the horiz-stab....just a 'dot' and the tube's locked in solid, with less deformation (and mess) than the DuBro rod guide would've entailed. Good stuff! Thanks for telling us about it.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 07, 2011, 10:24 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Someone asked this before; don't remember seeing an answer then but I hadn't received mine at the time, to try. Wind blew my Bix off the table Sunday & broke off the tip of the right horiz-stab's trailing edge. Dab o' Foam-Tac = good as new, & we were flying it <10 minutes later. Good stuff! Thanks for telling us about it.
I never waited more than a few seconds. I apply the stuff, make contact with the 2 surfaces, pull them apart and wait maybe 5-10 seconds then put them together.
On these EPO planes I have found it works best for me if I remove the shine from the foam. There have been some instances where no glue would stick without doing that even though I cleaned with 95% Iso alcohol. Light sanding with like a 220 grit and a quick Alky wipe and its a permanent attachment every time. Breaks don't need sanding as its virgin foam with no form release on it.
Yea the foam tac is good stuff but the quick grip is just as good and can be found locally in these parts at Wally World in the craft section.
Old Sep 07, 2011, 10:42 AM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Mark
I will check to make sure I have good electrical connections.
Thanks, jim
flyvertigo is offline Find More Posts by flyvertigo
Earthbound Skyhound
Joined Jun 2011
The very reason I don't like using the stuff! The surprising ease with which the nose weights were loosened using 'hot & not very' water only reinforces that point for me.
Old Sep 07, 2011, 11:18 AM
juanlargo is offline
Find More Posts by juanlargo
Joined Aug 2011
Why you don't use the gap filling CA glue for the sky surfer.
juanlargo is offline Find More Posts by juanlargo
Reply With Quote  (Disabled)
Old Sep 07, 2011, 11:51 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Oh Gawrsh!!! I just blushed all over m'self!!
Let me think about it and, I'll likely PM you for further discussion. That good?
Yes. However, posting to your own blog is not any different than posting here. Also, folks can post any thoughts to your blog just like they can here. The difference is that you can delete and block any post or poster that is offensive. Pretty cool actually.
Take a look at Prof100's blog. His is very nicely organized. You can take a look at mine, too. But, the focus of my blog was to just document that I have all the planes that I say I have.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 07, 2011, 04:57 PM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
Just a quick check - the Skysurfer from ReadyMadeRC is basically the same airframe as this one?
Nevermind - it is. I normally read the first post too
I bought the PNP Brushless version but want to install some different servos and my FPV gear. Will split the seam on the fuse tonight gently and source some hooks for the wings in the morning.
banzi28 is offline Find More Posts by banzi28
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
