Old Sep 06, 2011, 07:01 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Originally Posted by StarHopper44 View Post
Did you try narrowing the throttle input range (PWM)?
My 109's default is 1.2-1.8ms; I haven't changed that but perhaps you could shut off the lower end by raising to 1.3, if it allows that.
I might be way off base....just a shot in the dark but sounds logical & won't hurt to try.
On mine it's in 4th menu, FWIW.
You may have something there....worth a look.
thanks,
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old Sep 06, 2011, 07:12 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Now that sounds interesting.
2500GENE is offline Find More Posts by 2500GENE
Old Sep 06, 2011, 07:29 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by flyvertigo View Post
Something is wrong with the idle but it works fine once it is moved from idle.
Jim
Jim,
Have you tried setting throttle range?
Go to page four of the Hobbywing manual I attached -- Throttle Range.
Bill
Prof100 is offline Find More Posts by Prof100
Old Sep 06, 2011, 08:03 PM
flyvertigo
Orlando FL
Joined Aug 2009
Originally Posted by Prof100 View Post
Jim,
Bill
I will do that. I'm going to have to wait till the weekend.
I don't want to give up on the ESC yet.
Jim
Old Sep 06, 2011, 08:22 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Jim
Don't give up on the ESC. Any time I get a odd throttle range with a new ESC I perform the throttle range calibration. I run Hobbywing ESCs all the time.
Bill
Old Sep 06, 2011, 08:37 PM
0000jamie0000 is offline
Find More Posts by 0000jamie0000
Joined Sep 2011
help !!! im new to Rc world and i cant get my HK6df to bind? any help would be greatly appreciated. there my be something wrong with my receiver. i found a video on youtube of a guy setting up his but it was in Spanish. any ways mine does every thing his does but the receiver does not make any sound when powered up? maybe its bad. his looks exactly the same as mine.
0000jamie0000 is offline Find More Posts by 0000jamie0000
Old Sep 06, 2011, 08:43 PM
Joined Sep 2011
help if you dont mind i just bout the HK6df Tx and Rx hey is the receiver supposed to make sound when you power it up? i cant get mine to bind it will blink and when you hold the buttin on the tX and power it on the light stopes blinking on the Rx and when i pull the bind wire out the light does not come back on????
Old Sep 06, 2011, 08:56 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
This happens all the time. It is usually caused by the ESC being plugged in backward into the receiver, throttle is reversed, or throttle trim at idle it set too high.
Did you bind the receiver to the TX?
Old Sep 06, 2011, 09:39 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
Originally Posted by 2500GENE View Post
I won't pay a dime over 13 bucks.
I just pulled mine out of my RTF. I'll sell you both for $20. That's a savings of $6 for both!
healthyfatboy is offline Find More Posts by healthyfatboy
Old Sep 07, 2011, 01:40 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Didn't you get an Owner's Manual with your HK6DF? The bind instructions are printed on the back of its 1-sheet.
I posted the bind instructions several days ago for someone who asked, and at his request I made him a copy. Since then, I found the manual is posted under the Files tab on HK's product page for the HK6DF. Here's a link....be sure you follow it to the letter (with one exception), and it should work.
http://www.hobbyking.com/hobbyking/s...5X88665X37.pdf
That exception: on step 4 where it reads "Holding the bind switch in the up position now switch on the transmitter" should read "While PRESSING the bind button, switch on the transmitter".
Those instructions also tell you what indicators signal each step's responses, so you'll know you're proceeding correctly.
One additional thing, in case you don't know where to connect the bind plug -- it goes into the Rx socket with only 2 pins -- which is farthest away (opposite end) from the #1 socket.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 07, 2011, 01:43 AM
Earthbound Skyhound
Joined Jun 2011
Jim
OR....you could try setting the throttle range!
Old Sep 07, 2011, 01:56 AM
Earthbound Skyhound
Joined Jun 2011
Originally Posted by ajbaker View Post
+1. You said it better than I could have. Well done. In fact, I have been meaning to compliment you on your many fine posts with excellent suggestions. You are definitely the most ambitious and positive person on the thread IMO. I do have a suggestion for you, though. Please consider putting all you fine suggestions in your own blog and label it as specifically for the Bix/SkyS. You have so many great ideas that I (for one) would like to see you post them in one place and refer to your blog here. I would not take any offense to you doing that and it would help a LOT of folks that read the thread. Thanks for your consideration and keep up the great work.
AJ
Oh Gawrsh!!! I just blushed all over m'self!!
Thanks for your kind words, AJ....but I'm basically just returning the favor and giving back things you great bunch of guys either gave me, or I found somewhere because of your stimulation of my interest. Yes, I'll confess I'm excited by this li'l plane & the portal it's provided into this exciting world, and I guess it shows. I just hope (as I sometimes worry) I'm not having TOO much to say, & that some don't feel like I'm hogging too much page space.
Most of my input is based on spontaniety....someone writes something & it makes me think of a fitting response, and I reply. I'm afraid even with my writing experience, I don't have much of an idea as to how a blog should be organized....no editors around to help with that *LOL*. Let me think about it and, I'll likely PM you for further discussion. That good?
Old Sep 07, 2011, 02:53 AM
captainstack is offline
Find More Posts by captainstack
Joined Jun 2011
Hi guys
Can someone tell me if the HK medium CA glue is ok to be used on the Bixler?
captainstack is offline Find More Posts by captainstack
Old Sep 07, 2011, 06:29 AM
andybris is offline
Find More Posts by andybris
Joined Jun 2011
hot glue gun
Hi,
total newbie here, I just bought a Bixler and forgot to buy glue, can i use a hot glue gun to glue on tail, control horns etc on epp foam? as i already have one.
Sorry if it has all been asked before...
andybris is offline Find More Posts by andybris
Old Sep 07, 2011, 06:33 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by andybris View Post
Hi,
Sure, hot glue (low to medium temp) will work fine. However, it is as heavy as epoxy.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
