Old Sep 06, 2011, 01:00 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by erkq View Post
Oh, good. I'm glad I'm not the only girlie girl around here.
The only girlies' here use gyros.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 06, 2011, 02:56 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
AJ
AJ... That's my line. but you recently said that you use one for a tail heavy model. As Gene once called me.... You 'tart'...
Flypoppa is offline Find More Posts by Flypoppa
Old Sep 06, 2011, 03:16 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Guilty, as charged. 2500GENE is only guilty of only one thing - EVERYTHING.
AJ
Old Sep 06, 2011, 06:45 AM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
question,
once the fuselage is glued together,
how hard is it to change out the elevator and rudder servos (version 1 SkySurfer).
....looks impossible because its' buried deep inside the fuselage....
rclab1 is offline Find More Posts by rclab1
Old Sep 06, 2011, 06:53 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
Originally Posted by rclab1 View Post
question,
Are you talking about a kit where you install the initial servos and then glue up the fuse? If so, when you glue up the fuse use only spaced out spots of glue (like that packaged with the GWS kits or rubber cement) and then tape the seams. This would allow an "easy open" with a #11 Xacto knife or razor blade if it becomes necessary.
Aeronca
aeronca is offline Find More Posts by aeronca
Old Sep 06, 2011, 06:58 AM
rclab1 is offline
USA
Joined May 2010
aeronca,
thanks for the reply.
What if the Plane was all assembled from factory,
will I have to pry open with hobby knife like you said to
change out the stock elevator and rudder servos?
I dont want to cut out a lot of foam :-)
p.s.
I want to replace those 2 servos with micro Metal ones.
Old Sep 06, 2011, 07:08 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
aeronca,
p.s.
I've not had to split one of these fuelages yet, but I would assume a razor blade or Xacto #11 knife carefully run precisely along the seam would work. Do several "light" passes to make the slice cleanly and eliminate tear-out. Be careful of any wires (if possible) that may be glued or taped along the inside of the seam. However, even if you cut the insulation on a wire attached to something you don't want to remove, it would be easy to fix.
Good luck!
Aeronca
Old Sep 06, 2011, 08:05 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
If it's factory installed servos, you should be able to reach inside thru the cockpit with a wide-bladed flat screwdriver & pop 'em loose using steady persistent pressure -- they're only hot glued in. And only a small half-pea-sized dollop applied & quickly popped in will hold the replacement securely. Some like to wrap the servo with blue painter's tape first to give a little better 'bite' for the glue, but I'd reserve that for units you have better access to for easier future removal. The trick here is just enough glue to hold while they're working, but not so much as to make removal difficult.
And let me add - if you're replacing just to install better servos, & have had no failures? I'm using the stock supplied units & so far at least, they're performing flawlessly! (Of course with my typical luck...soon's I brag on 'em they'll go sour, & I should start praying the plane survives and the Tx doesn't explode in my hands.)
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 06, 2011, 08:14 AM
Spaticus is offline
Find More Posts by Spaticus
Parts of it still up a tree!
Spaticus's Avatar
Australia, VIC, Croydon Hills
Joined Jul 2011
Hi folks,
Ordered a Bixler from the Aus warehouse a few weeks back (even though it was on back order). They arrived in the warehouse this week and received confirmation that it was being shipped today! Think I have read through this entire thread since placing the order and I am looking forward to the build and especially the maiden. Thanks for all the advice!
Mark
Spaticus is offline Find More Posts by Spaticus
Old Sep 06, 2011, 09:42 AM
StoneTemplePilot is offline
Find More Posts by StoneTemplePilot
Somewhere in the Vasoline
StoneTemplePilot's Avatar
United States, TN, Greeneville
Joined Jul 2011
My elevator servo lasted about 30 flights before it just quit working on me. Now that I know whats its like to lose an elevator in flight I would recommend everyone atleast put a quality servo on the elevator. I guess you could make it home with no rudder or 1 aileron missing. But that Elevator is kinda important LOL. I was lucky not to wreck the plane
StoneTemplePilot is offline Find More Posts by StoneTemplePilot
Old Sep 06, 2011, 11:42 AM
Earthbound Skyhound
Joined Jun 2011
Kewl! But in all honesty you gotta admit, same thing could've happened with World's Greatest Servo!
(There, that oughta fuel the fires for the bone-pickers!) *LOL*
Bu-u-u-u-ttt....note to self: Change servo after 29 flights.
(Just to be on the safe side, don'tcha know.)
Old Sep 06, 2011, 12:23 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
We don't trust the wing spar. We don't trust the control horns. We don't trust the foam where it hinges without tape. We don't trust the double sided tape holding the spar covers on the wing. Hell, we don't even trust the decals from coming off.
Why would we then trust the stock servos?
2500GENE is offline Find More Posts by 2500GENE
Old Sep 06, 2011, 12:33 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
This is a great post! What the hell are we doing with this thing??? It can be a great little bird, though... potential!
erkq is online now Find More Posts by erkq
Old Sep 06, 2011, 12:38 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
It's a real nice hunk of foam. Just buy the kit version and put the good stuff in.
Old Sep 06, 2011, 03:02 PM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Well I now have 4 spare servos, 2 push rods, a 1900kv motor, ect. Hardware that came off my ARTF Bixler. Yep I shure should have got the kit version.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
