Old Sep 05, 2011, 12:41 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Gordks View Post
At our field the morning works well, but the evening is not recommended because there are a couple of bears in the patch of woods 500 feet away off to the left.
Griz? EEeek... I'm a little girl when it comes to griz... I backpack in black bear country, no prob... but I wouldn't be caught dead (haha) anywhere near a griz.
erkq is offline Find More Posts by erkq
Old Sep 05, 2011, 12:47 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
At our field the morning works well, but the evening is not recommended because there are a couple of bears in the patch of woods 500 feet away off to the left. They spend time in the hazelnut groves off to the right and the corn fields behind us. In the morning there are always a number of fliers so the they just ignore us. In the evening a flier would likely be alone and, while staring up at his plane, would not see a bear approaching.
Gord
That's what spotters are for..... spotters with a 44mag.
jrjr is offline Find More Posts by jrjr
Old Sep 05, 2011, 12:54 PM
erkq is offline
Joined Dec 2010
Yeah, man... right... something big. 22's are ridiculous against a bear. They just ricochet off their skull and piss 'em off unless you get a lucky shot.
I'm griz-phobic. Polar bear are even worse. To a griz, you're an enemy. To a polar bear, you're food.
Old Sep 05, 2011, 03:11 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
,,,,corrected :-)
rclab1 is offline Find More Posts by rclab1
Old Sep 05, 2011, 03:37 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
The Bixler and Hawk Sky
OK, in my builds of the Hawk Sky and The Bixler I have discovered a somewhat different approach to aileron connection. Each plane uses seperate servos for each of the ailerons, but the Hawk Sky has a double pin-set on one 3-wire connector for the ailerons where The Bixler uses a Y cable. Same result, just a different method of connection. Also, the motor wires are quite long on the Hawk Sky, especially when combining the lengths attached to the motor and the ones to which they connect coming out of the fuse. It makes for a challenge to hide them in the fuselage/motor pylon of the Hawk Sky.
aeronca is offline Find More Posts by aeronca
Old Sep 05, 2011, 05:36 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Not griz, just black bear. The griz are further north. If they were griz I would never fly there!
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 05, 2011, 05:55 PM
erkq is offline
Joined Dec 2010
Gord
Oh, good. I'm glad I'm not the only girlie girl around here.
Old Sep 05, 2011, 06:24 PM
guroos is offline
Find More Posts by guroos
guroos's Avatar
Australia, NSW, Sydney
Joined Aug 2011
I won't go back to the park I first tried 'cause I pissed off a couple of magpies...does that count, lol.
guroos is offline Find More Posts by guroos
Old Sep 05, 2011, 07:10 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by guroos View Post
i won't go back to the park i first tried 'cause i pissed off a couple of magpies...does that count, lol.
Nevermore!!
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 05, 2011, 07:25 PM
Gordks is offline
Joined Mar 2010
oh, good. I'm glad i'm not the only girlie girl around here.
Discretion is the better part of valor.
Good enough! Ya gotta watch them darned magpies. And ravens too!
Nasty CROW strikes Speedo thermo.avi (4 min 58 sec)
Gord
Old Sep 05, 2011, 07:35 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Originally Posted by 2500GENE View Post
Hopefully he'll be back on his medication before making that report.
He is probably just real excited about his new planes and gets easily confused.
I get like that too.
That feeling goes away after a while...then you have to get another new plane.
And on and on and......
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old Sep 05, 2011, 08:14 PM
flyvertigo
Orlando FL
Joined Aug 2009
Speed controller issue
I got this speed controller months ago and just got around recently to testing it.
I know that the problem is with the controller and not the motor.
The question is...can this SC be used without causing the plane to crash at some point?
It only runs like that at very slow speed. It reacts normally at all other speeds.
MVI 0019 (0 min 54 sec)
Jim
Old Sep 05, 2011, 08:40 PM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Jim
Try different timing
Programming-Tarot Pentium 40A ESC for Brushless Motors (3 min 16 sec)
Old Sep 05, 2011, 08:41 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
This is not necessarily true. Oxygen is just one possible element of oxygenation. There can be others. Just think of dynamite or solid rocket propellant. From what I see of these demonstrations, the LiPo batteries have their own internal oxygenation.
Ok...Dynamite explodes when detonated , but will burn just like wood...
Solid rockets liberate their own oxygen when burning
Lipo's dont have their own oxygen you can see that by watching the vids on you tube....nothing BURNS without oxygen
this is why some of the lipo's dont burn if the container is nearly sealed only allowing the inflamable gas to escape...chek out the second lipo in this vid
LiPo fire (1 min 51 sec)
cheers from down under
Ian
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Sep 06, 2011, 12:49 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by G550Ted View Post
I shakes out between 60 and 65mm. I have to add that I have a 2836 inrunner in the nacelle and swapped the tail control rods to heavier Dubros, both of which add aft weight. I have found that a CG approaching 70mm or even further aft makes for some lousy pitch stability and is not suitable for a good flying model.
Ted
Got it. It makes sense now. Thank you for your feedback.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
