Old Sep 01, 2011, 03:46 PM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Originally Posted by khaled_abobakr View Post
Hi ..
now after I'm almost finished with the intensive modifications/ reinforcements of the Bixler to make it ready for FPV... there is an important question ...
How can I do do maintenance without having to tear don the whole plane ??
The whole assembly is based on different types of glues and tapes .. so what happens if I need to exchange a servo for example or relocate the RX or the BEC to solve a noise issue ..
I've made a test and hot glues a servo wrapped in tape and a ribbon and then I tried to remove the servo from the scrap foam by pulling the ribbon .. and it won't budge .. !!
1-How can I open the fuselage without damaging the foam ??
2-How can I exchange servos without damaging the foam ??
Thanks a lot I really can use an advice here
Khaled
The ARF fuselage is apparently held together with just tape stickum. If you let the fuselage warm up for an hour in say 40C, the stickum is a little softer and the two fuselage halves can be slowly pried apart. Slowly is important.
Servos come out easier when warmed to 40C also and be as careful as possible. Slip the short leg of a strong L shaped wire under the servo and pull gently for a long time and see what happens.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Sep 01, 2011, 04:26 PM
ozair is offline
Find More Posts by ozair
Space is the answer
ozair's Avatar
Australia, VIC, Warneet
Joined Mar 2011
Originally Posted by ajbaker View Post
That motor is popular also. Given your skills and experience, I am sure you won't have any problems at all. Don't use anything larger than a 6x4E on that motor. Also, I suggest that you get a watt meter to avoid burning up LiPo's, motors, ESC's, etc. HERE is the one I recommend (if you can find the doggone thing anywhere).
AJ
AJ,
I just purchased and received this wattmeter from Ebay which appears to be identical to the Turnigy you always recommend from HK.
http://www.ebay.com.au/itm/280688648...84.m1423.l2649
Appearance the same, functions the same, manual the same, what are your thoughts.
I also got sick and tired of waiting for HK to bring it back in stock.
ozair is offline Find More Posts by ozair
Old Sep 01, 2011, 04:36 PM
ozair is offline
Space is the answer
ozair's Avatar
Joined Mar 2011
Originally Posted by jj604 View Post
I just built another EasyStar and put one of these in it.
I think it is an excellent solution. On 2S it performs pretty much identical to the stock EasyStarPermax or Bixler brushless with the stock prop. Change to 3S and/or a 6x4 and you have a very wide power range option. Just by changing the battery and prop you can go from stock docile trainer to a screamer.
Have you put one on a Bixler or SS yet.
I would be interested to see how you mounted it on the Easystar/Bix/SS if you have any photos.
Old Sep 01, 2011, 05:39 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Here's the pictures I put on the EasyStar thread. I really like the Speed 400 can mount for simplicity, rigidity and cooling. You can still remove the motor by accessing the screws through the cooling duct. Also it looks a lot nicer than the external mounts to me. You can make one in 3 minutes with a hammer screwdriver and file.
The EasyStar comes with a free Speed 400 mount, unfortunately the Bixler doesn't.
John
jj604 is online now Find More Posts by jj604
Old Sep 01, 2011, 06:06 PM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
Originally Posted by erkq View Post
Good on you! I've given up on the "fish-breath" fight. I figure we're RC enthusiasts here and etymology is OT. But it sure bugs me!
Yes... 'bated... as in short for abated... as in abated breath.... as in holding your breath. OK... there I did it. I should be good for another year or so. Thank you for your kind patience.
(Reference that li'l ROFL guy again)
Well, it was either that or yet another bad 'sushi' joke.
StarHopper44 is offline Find More Posts by StarHopper44
Old Sep 01, 2011, 06:10 PM
Earthbound Skyhound
Joined Jun 2011
Cliff
And don't (re your experiment) use as much hot-glue. It only takes a small dollop to hold 'em. You should be able to pop 'em off with persistent pressure using a wide bladed screwdriver or somesuch.
Old Sep 01, 2011, 06:24 PM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Or try a heated #11 blade hobby knife
jrjr is offline Find More Posts by jrjr
Old Sep 01, 2011, 07:38 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
John
Hey guys whats up with this new (old?) prop tips, whats is the function of these tips??
nakelp86 is offline Find More Posts by nakelp86
Old Sep 01, 2011, 08:58 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
That's an new EasyStar prop not a Bixler.
My Bixler prop has them too but not quite as pronounced. Just a bit of blurring in the copy process?
My guess is they are to manage or reduce tip vortices and improve efficiency and reduce noise.
Old Sep 01, 2011, 09:04 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Budy of mine has same kind of prop on his glider. And we could not figure it out.
Did you noticed lower noise??
Old Sep 01, 2011, 09:13 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Sorry, never actually compared it with a similar "conventional" prop of the same size.
Noise isn't really a big issue with EasyStars/SS/Bixlers using the 5" prop. On reflection it is probably an efficiency measure.
Combined with the slight reflex along the length of the blade, it has the side effect of generating a lot of entertaining posts on the correct way round to mount the prop though!
Old Sep 01, 2011, 09:24 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
LOL
I noticed it
Thx.
Old Sep 01, 2011, 10:58 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
LOL
I noticed it
Thx.
For some its easier to type a post ...than it is to use whats beween their ears....
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Earthbound Skyhound
Joined Jun 2011
...cut - redundant
Old Sep 01, 2011, 11:07 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Anyone knows where to get servo screws?
I saw the post somewhere but cant find it anymore.
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
