Old Aug 19, 2011, 03:00 AM
Flypoppa is offline
Find More Posts by Flypoppa
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
Rattles. It seems that for a bigginer you have cracked it, well done.
I also love the bit of the tree rescue.
Flypoppa is offline Find More Posts by Flypoppa
Old Aug 19, 2011, 03:17 AM
yannc is offline
Find More Posts by yannc
Joined Jul 2008
FY21 Installed
I have installed a FY21 (stabilization and RTL but no OSD) on the SS and I love it! I'm not flying FPV but I wanted a "safety net" because I always try to go higher and further. I tested it yesterday and this thing is just unreal. This will be fantastic for AP, I will hopefully post some nice videos soon.
One question I have is related to the ESC. Even though the FY21 is not that big, it did add some weight (under the wing, right on the CG).
After 20 min flying, the ESC got very hot as the sticky part of the velcro melted.
This is the ESC I'm using:
What is the recommendation? Wire the ESC outside the plane for better cooling?
Another question I have is related to the CG. Beside the battery, I can't put anything in the front canopy because it makes the plane nose heavy. I have to stuff the Rx and ESC on the left of the servos to make my plane level on 60mm CG. My plane is a V2. Am I the only one with this problem? At the moment, it is fine but for instance I couldn't put a Go Pro HD on the canopy, it will have to be on the wing (causing a lot of drag) if I want to keep my plane level...
yannc is offline Find More Posts by yannc
Old Aug 19, 2011, 05:40 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
Originally Posted by Rattles View Post
Hi all,
It's been a week of firsts, my maiden bixler flight, my first RC plane flight and now my first post on RC groups.
I
First time videoing an rc plane? First time climbing a tree to retrieve your plane?
Good job on keeping it in the air. Some folks take much much longer than that! You will have it down pat in no time from the looks. As far as porpoising goes, AJ used to recommend 72 mm for the Bix but I see now he has changed that to 60 for all versions. Not sure why the change. Anyway, if yours is balanced at 60 you should be just fine and it's probably a matter of a little over control.
If you are using a programmable radio.you might consider using some expo. That tames things down around center stick but still has full deflection at the extremities. Futaba and JR are inverse in their settings on expo so be sure of what you are doing before flying it with that.
Welcome to the wonderful world of RC. Shine up that credit card and hold on.
jrjr is offline Find More Posts by jrjr
Old Aug 19, 2011, 05:46 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
Yep you could do that and it would certainly be the best solution cooling wise. Ducts in the nose and rear works for me though.
Somewhere in this thread there was pictures of an access hatch cut into the bottom back under the wing. That would be an option too. Putting the battery back there would free up nose weight for other stuff. Whatever way you do it it has to balance out to be successful.
Found the thread HERE
Old Aug 19, 2011, 05:57 AM
StarHopper44 is offline
Find More Posts by StarHopper44
Earthbound Skyhound
StarHopper44's Avatar
United States, NC, Richlands
Joined Jun 2011
ZFW - the real number
We've talked quite a bit about AUW or All Up Weights; let's talk some about ZFW.
The largest weight changing factor as I see it is the particular LiPo pack we choose, & that is a weight variable, and widely so. A better comparitive figure for gauging what our individual construction methods & mods added or saved would be our respective ZFW's or Zero Fuel Weights -- that being our AUW without the battery.
Why:
When I had my Bix ready to fly, as a lark I put 'er on the scale without the battery & was pretty shocked to find I was already well over the 650g Recommended Flying Weight (or RFW) published under Specs on the Bixler's ad page at HobbyKing. It made me go back & review all the mods I'd done, & found nothing out of the ordinary that would've put me there - I even re-weighed to double check & yep, the first weighing was confirmed. I presume the 650g RFW is with the stock supplied 1300mAh LiPo (which weighs 111g), meaning my battery-less ZFW is even more overweight!
So, I'm very interested in hearing how others' builds 'weighed in'. We have no way of knowing exactly what the Specified 650g weight entails (for one thing, it's a suspiciously "nice round" figure), but we can still use that as a Benchmark.
To summate, I'm asking others to rig their finished plane to flying config'n without your battery & weigh it. To cover our individual variables, please post your model of plane, ZFW, and perhaps include all the inividual thing(s) you did that affected your ZFW by more than 3-5 grams.
By the way, I weighed about everything as it came out of box so if anyone needs an 'unmodded' weight to figure against, just ask and I can probably supply it; eg stock 6mm wing spar weighed 11g; adding 4mm reinforcing spar w/epoxy added 5.5g bringing total to 16.5g.
I'll get it started:
Bixler (Ver 1); ZFW 512g for +57g over RFW.
Mods: Removed 55g nose weights, Added 5.5g wing reinforcing spar
How's yours stack up?
StarHopper44 is offline Find More Posts by StarHopper44
Old Aug 19, 2011, 06:03 AM
yannc is offline
Joined Jul 2008
That's great, thanks for that. What I might do as well is fly without the cockpit to allow more air inside.
Why:
To summate, I'm asking others to rig their plane to flying config without your battery & weigh it. To cover our individual variables, please post your model of plane, ZFW, and perhaps list any inividual thing(s) you did that affected your ZFW by more than 3-5 grams.
Interesting thread. I'll weight mine and report out. I have a 2200mah and a FY21AP on board. End goal is FPV but I like taking my time and adding one bit after the other.
Old Aug 19, 2011, 06:08 AM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Anyway, if someone would check theirs & let me know what they see, it'd really ease my mind.
TIA guys!
OMG, you got Farads leaking out of your Fixed Capacitor Bank!
Hide the wife, hide the kids........
2500GENE is offline Find More Posts by 2500GENE
Old Aug 19, 2011, 06:43 AM
Flypoppa is offline
Me a long time ago
Flypoppa's Avatar
London N.E. UK
Joined Jan 2007
That's not Farads it looks like hot glue... Apply cold water to the leak.
Old Aug 19, 2011, 07:26 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
No, that stuff is Final Farad Flux Finishing Factor.
FFFFF for those acronym freaks.
(It locks in your Farads)
Farad=
Old Aug 19, 2011, 07:27 AM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
With all the talk about the ESC heating up in the fuse, has anyone tried installing an external BEC and disabling the linear one on the ESC and see if that makes a difference in the heat within the fuse? I bet that extra 5-7g from the extra UBEC may bring down temps in the fuse if the ESC is installed inside.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Aug 19, 2011, 07:32 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
I did that from the get go yea, and have no heat issues. Also have cooling ducts.
Old Aug 19, 2011, 07:55 AM
messir is offline
Find More Posts by messir
Joined Jul 2008
Sorry guys if I ask same question.
Want buy Bixler, pls tell me:
1. whicg prop saver need for that.
2. Which ubec will good for ESC like on top of the thread.
3. Where can buy 3 mm fiber carbon tube.
If possyble give links on all of that.
messir is offline Find More Posts by messir
Old Aug 19, 2011, 08:08 AM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
I've attached some closeups & a macro of my overheated ESC showing something that concerns me - namely the 'beige' colored goo that looks like some kind of melted plastic covering the center 'can' object in the center & the component off to its side. I'm wondering if something inside might've melted out & hardened, or if this is something used during the assembly process like heat-sync paste or brush-on insulation or something. The main thing that makes me feel it's factory-related is the small, hook-shaped 'thread' you see isolated atop that black wire.
Would someone(s) please take a closeup look at your ESC on that double-can end & see if you see anything like that 'up in there' on yours?
Everything seems to be okay operationally, but I get a vague feeling the motor doesn't qui-i-i-i-i-te 'ramp up' as crisply as before when I peg the throttle. Maybe it's just my memory - I didn't really run the motor much before flying it....maybe 4-5 times & only a few quick seconds on each check.
TIA guys!
That is a type of rubber glue, used to reduce vibration. Without it, those capacitors wiggle back and forth with engine vibration and the leads eventually break.
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Aug 19, 2011, 08:15 AM
Temple, GA, USA
Joined Jun 2009
I've seen another advantage to having a very experienced pilot like (my) Mike Fox at your side when you're in learning stage like me. I'm in awe of their observational skills & the little things they pick up on & just mention casually - there's a world of learning in those comments alone. For instance, don't know if you caught it in my video, but with one quip he explained something I'd seen dozens of times in other videos without picking up on the cause -- that when you 'gas' it the thrust angle has a tendency to push the plane down at first. To you Old Pro's that might come as natural as hair on your arm, but methinks it's something to keep well in mind while learning to fly the SS & Bix's.
Not that I'm pushing for more views on my videos, but I'd suggest other 'noobs' might gain something by going back & re-watching, and ramping up the audio (after my 'announcement outburst *LOL* - that still embarasses me) so's you can hear the things Mike says. Like I alluded - there's lessons to be had. And they couldn't come from a better pilot!
Also want to mention one other thing - speaking of 'observational'. At one point (off-video) when I's flying, the Bix got a little far out over that cornfield & I turned it to bring it closer. At the point where it was coming head on, with that knifeblade-thin profile against the clouds in the background - I absolutely LOST IT from my view - it was just plain invisible!!
My first reaction was to circle the area with my eyes where I'd last seen it, trying to project in my mind where it was headed & looking frantically along that route. Just as I started getting the queasy feeling of it suddenly reappearing right in front of my face I happened to think to ease back on the stick, & as it climbed out of its path she suddenly reappeared, right where I'd been looking. Whole thing happened in only a brief few seconds, but scared the livin' crap out of me just that quickly. *LOL*
I still can't get over the feeling of when I first lost it....it ain't a good one!
This learning thing's gonna be quite an adventure!
#1 on the newbie list is "get an instructor if you can, even if you have to drive a ways"
A seasoned RC pilot has a mental picture of what the airplane is doing and flies the mental picture. If you are a long way out and flying perpendicular and you bank slightly to come back, you may not be able to tell whether the plane is slightly banked toward your or away from you, but you know that you banked it towards you. You are flying your mental picture.
Cliff
Old Aug 19, 2011, 08:32 AM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
After 20 min flying, the ESC got very hot.....
Another question I have is related to the CG..
Cooling: use external switching BEC or UBEC. Install small small scoops NACA ducts up front and vent aft to move air through the fuse.
CG: I assume you removed the superfluous ballast in the nose. When I fly my camera on the nose I use a 1300mAh battery, when I don't it's a 2200mAh battery.
QUESTION FOR OLD TIMERS: I've been toying with putting one of the ballast washers on each wingtip to retard my camera plane's tendency to roll this way and that. Any thoughts on the efficacy of such a practice?
scott page is offline Find More Posts by scott page
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
