Old Aug 13, 2010, 06:13 PM
awzook is offline
Find More Posts by awzook
Heartland of America
Joined May 2010
Order Date: 08/13/2010
Order Number: bh18-101961
Well Looks like i am joining the club. Decided to go ahead and buy the Surfer and wait for the P-38.
awzook is offline Find More Posts by awzook
Old Aug 13, 2010, 10:37 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
I am sure you will love it.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Aug 13, 2010, 10:47 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I finished up the other plane I was building so I can now move on to the Skysurfer. I suppose I should charge the batteries for my digital camera and capture the build.
I need a collet for the motor. The smallest I have is 3 mm. Who carries 2.3 mm prop collets?
Prof100 is offline Find More Posts by Prof100
Old Aug 13, 2010, 11:33 PM
Mr.Pibb is offline
Find More Posts by Mr.Pibb
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
Originally Posted by Prof100 View Post
I was warned the stock spar may break in aerobatic flight. Some have used a larger tube which requires opening up the hole in the wing. I chose to strengthen by buying 3/16" or .188" carbon fiber tube that slides right into the stock spar. Glue in with Gorilla glue and you now have a super stiff spar.
I bought the 3/16" or .188 Carbon Fiber tube at my local kite shop -- Kites and Fun Things. They have a website.
Below are the pictures.
Ditto on this. I found that a 5mm OD CF tube from HobbyKing fit inside the stock spar perfectly. I just had to cut a couple inches off of the 5mm tube. Super stiff now...
Mr.Pibb is offline Find More Posts by Mr.Pibb
Site Sponsor
Old Aug 13, 2010, 11:36 PM
awzook is offline
Joined May 2010
http://secure.hobbyzone.com/catalog/.../EFLM1921.html
Will this help?
Old Aug 13, 2010, 11:53 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I can't tell what diameter shaft it fits. I am looking for one with 2.3 mm hole.
Old Aug 13, 2010, 11:58 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Hmm, the tube that fits mine is .188 inch or 4.76 mm. So much for J Power using the same CF supplier or the same size CF. Did you measure the HK CF tube with a caliper or is that what they said it was?
Old Aug 14, 2010, 12:03 AM
awzook is offline
Joined May 2010
I think in the name it says 2.3mm. Guess it wouldn't hurt to email them for info.
Old Aug 14, 2010, 12:11 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
The link you sent to me didn't have that information. I backed up one level with all the adapters and it does say 2.3 mm. That will work.
I still used the stock adapter with APC 6x4 E prop. I just reamed out the prop with a prop reamer.
Old Aug 14, 2010, 10:39 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Wing retention
I liked bradsears use of 3M Command Strips so I picked up some at my local hardware.
Clean the surface with rubbing alcohol and stick on to surface. Hold firm for 30 seconds. Wait 1 hour to build adhesion. And bingo you have a hook for a rubber band.
The dowels on the side prevent eating into the foam when wrapping the rubber bands around the corner.
This setup really works. That is, it holds the wings in place but if whacked the wings will deflect.
Old Aug 14, 2010, 06:48 PM
flyvertigo is offline
Find More Posts by flyvertigo
flyvertigo
Orlando FL
Joined Aug 2009
Nice job. I like that even better than the Velcro I used on mine.
I will use that idea on the WH in the upgrade shop.
Jim
flyvertigo is offline Find More Posts by flyvertigo
Old Aug 14, 2010, 07:10 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Jim
Jim,
It's just so simple and lightweight.
Bill
Old Aug 14, 2010, 07:17 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Control horns and tape hinges
The control horns, as noted by everybody who has one, are pretty flimsy so I replaced mine with Dubro nylon control horns. Cat. No. 237. I cut off the last two positions to match the throw on servos.
The foam hinges are stiff and will eventually fail. I used 3M Extreme tape to hinge the ailerons after working the stiffness out of the foam.
Old Aug 14, 2010, 08:05 PM
Mr.Pibb is offline
Mr.Pibb's Avatar
Lewis Center, OH
Joined Jun 2006
That's just what HK says it is. I'll have to measure it to see if it is 5mm or smaller.
Site Sponsor
Old Aug 14, 2010, 08:32 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Who knows what you'll get in these kits or from China. You and I may have two different size wall thickness in the CF tubes that came with our kit.
Bill
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 03:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 03:36 PM
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 56 Nov 02, 2010 03:49 AM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 02:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 06:28 PM
