Old Mar 28, 2011, 06:15 PM
2500GENE is offline
Find More Posts by 2500GENE
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
Originally Posted by belize pilot View Post
hi guys,
just flew 2 hours or so, beautiful calm but hot day here. i'm getting 20 min flights with batt volts of 3.7 or so per cell. i have the box stock BH ARF with the brushed motor, can i us the hi capacity 11.1 volt battery talked about a few pages ago?
What battery are you using now?
2500GENE is offline Find More Posts by 2500GENE
Old Mar 28, 2011, 06:19 PM
belize pilot is offline
Find More Posts by belize pilot
me n jr at BZE with his C-17
belize pilot's Avatar
Belize, Corozal, San Pedro
Joined Mar 2011
from the box; "7.4V 1600mAh Li-Po (brushed version)"
belize pilot is offline Find More Posts by belize pilot
Old Mar 28, 2011, 06:33 PM
2500GENE is offline
Why so serious?
2500GENE's Avatar
Joined Dec 2007
I don't have the brushed version or know what esc it comes with. But I have a few Easy Star motors and a Wild Hawk brushed motor and they are all 6 volt motors. With a 2 cell 7.2 lipo, it's already pushing it to 8.4 volts. (it says 7.2 or 7.4 but it charges to 8.4). A 3 cell charges to 12.6 volts and will power the motor for a bit but will wear it out very quickly,.
The best way to increase power is to upgrade to a brushless motor and esc.
If it's higher capacity your after the use a 2200 2 cell and position it in the plane as not to change the COG.
Old Mar 28, 2011, 07:44 PM
Joined Mar 2011
Thanks. I'm looking for longer flights and a heavier battery (wanna take out the washers). What will the brushless motor do for me?
Old Mar 28, 2011, 09:55 PM
FredS is offline
Find More Posts by FredS
Not Again !!
FredS's Avatar
Texas
Joined Dec 2006
A brushless motor tends to give more power and a longer run time .
I went playing in the wind again today 25 gusting to 35 put a little twist on it this time let me know what ya think . I had it sliding sideways and skidding in down wind turns . I actually had it flying backwards inverted but didnt get the ground in the picture . You can see where it ends it up though . Had a Blast !!
SkyS with Streamers.rm (6 min 0 sec)
FredS is offline Find More Posts by FredS
Old Mar 28, 2011, 11:27 PM
theothercliff is offline
Find More Posts by theothercliff
Much happier at LibrePilot!
Temple, GA, USA
Joined Jun 2009
Why do they say 3ch and 4ch? Do they all come with ailerons? I don't understand why they would be advertising 3ch if it is a 4ch RTF (unless they are trying to pull a fast one).
When you get the RTF (with radio and all) are all the servos pre-installed?
Does it have unlimited vertical with the brushless upgrade?
Cliff
theothercliff is offline Find More Posts by theothercliff
Old Mar 29, 2011, 01:34 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
How it works
1. When you get the RTF (with radio and all) are all the servos pre-installed?
2. Does it have unlimited vertical with the brushless upgrade?
Cliff
1. Yes.
2. No.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Mar 29, 2011, 01:35 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Well, it will help. But, a larger battery (1500mah) will do it for you.
AJ
Old Mar 29, 2011, 09:41 AM
Joined Mar 2011
http://www.youtube.com/watch?v=MAIJMgToktw&
feature=player_embedded
ay yi yi
"This video contains content from Sony Music Entertainment, who has blocked it in your country"
Old Mar 29, 2011, 09:43 AM
Joined Mar 2011
AJ
1500mah?
i have a 7.4V 1600mAh Li-Po.
Old Mar 29, 2011, 10:43 AM
yannc is offline
Find More Posts by yannc
Joined Jul 2008
Originally Posted by Prof100 View Post
The below works well. These are two garden variety cabinet latches. Works great.
Good idea. I just got this: http://www.aquafax.co.uk/html/produc...s.asp?ID=22001 and also a few of these cupboard child safety lock.
yannc is offline Find More Posts by yannc
Old Mar 29, 2011, 10:58 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
I like those you linked to in your post. They are nylon and MUCH lighter. Very good find.
Prof100 is offline Find More Posts by Prof100
Old Mar 29, 2011, 11:24 AM
yannc is offline
Joined Jul 2008
Yeah, I found them by looking for all sort of locks, hook, latches, catches, using Google Image.
They are called "double roller catch nylon" and you can find them on ebay.
Old Mar 29, 2011, 02:48 PM
ScottyDz is offline
Find More Posts by ScottyDz
Germany, BW, B÷blingen
Joined Mar 2011
FredS,
I liked your streamer video, but am more interested in the mods. Did you flush mount your battery on top.? Is the ESC exposed for cooling? Was this covered in any posts? Can you add a few photos?
Thanks.
ScottyDz
ScottyDz is offline Find More Posts by ScottyDz
Old Mar 29, 2011, 03:49 PM
FredS is offline
Not Again !!
FredS's Avatar
Texas
Joined Dec 2006
I used some of the mods from this thread . I put the ESC on top for cooling and convenience. that also allowed more room inside encase I needed a larger battery .
I use a Gene Ace 1300 3S with no other weight added and I do not use the washers either I use the stock brushless motor with a 6x4 apc prop .
I have to say AJ has done an outstanding job of keeping up with the mods he adds them to Post's #1 & #2 . I think between those two posts you could get all or most question's answered
Discussion Banana Hobby Sky Surfer Problems cavy92 Electric Plane Talk 59 Mar 23, 2016 08:10 PM
For Sale Cyber Sky Parachute (Sky Surfer) shv2sail Aircraft - Electric - Airplanes (FS/W) 6 May 28, 2013 02:14 AM
Discussion Sky Surfer nickwayne11c Electric Plane Talk 15 Nov 18, 2011 02:36 PM
Question Sky Surfer LiPo mod, help... Freight Dog Power Systems 0 Aug 17, 2006 01:45 PM
Swashplate Assembly with Center Ball; is this the swash with ball mod i want? tekforce Micro Helis 4 Feb 08, 2004 05:28 PM
